Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Closed Thread
Old 09-12-2007, 12:20 PM   #1
BlueMan05
Member#: 129934
2015 STi LE
Wrb
Default bov question
im going to be getting tuned by xx tuning on friday and wanted to know if its a good idea to get a new bov? im currently running a stock bov and probably will be tuned around 22psi. will the stock bov hold?
thanks
kevin
BlueMan05 is offline
Old 09-12-2007, 12:24 PM   #2
kcook
Member#: 78074
2005 STi
yes u should be fine. im running the stock bov on 21 psi daily. have been for about 19k mi
kcook is offline
Old 09-12-2007, 12:33 PM   #3
BlueMan05
Member#: 129934
2015 STi LE
Wrb
i was hoping to be tuned for the most psi as possible but im affraid the bov is going to max out also worried about maxing out the 740cc injectors
Old 09-12-2007, 12:39 PM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
im tuned at 19 psi and mine didnt hold so i just crushed the top
bhhamblin is offline
Old 09-12-2007, 12:44 PM   #5
BlueMan05
Member#: 129934
2015 STi LE
Wrb
how do you crush it?
Old 09-12-2007, 01:02 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
There is a search button over here-------------------------------------^
ANSWER = HAMMER
Right on the top of the BOV
Guys have been doing this on DSM's for a long time.
http://www.dsm.org/archives/1999/09/...03.txt/15.html
Phatron is offline
Old 09-12-2007, 01:08 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I took a 3/8" socket entension and hit it with a hammer. I indented mine a little less than 1/4".
wcbjr is offline
Old 09-12-2007, 01:09 PM   #8
Gfunk720
Member#: 42549
E92 M3 M\\\
2017 Outback Limited
I run 21.5 psi on mine and it holds fine
What setup you running to max out the 740's?
Gfunk720 is offline
Old 09-12-2007, 01:09 PM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Oh, and wrong forum.
wcbjr is offline
Old 09-12-2007, 01:15 PM   #10
BlueMan05
Member#: 129934
2015 STi LE
Wrb
i want to run more boost and if i need a aftermarket bov thats what i need to know.
APS 3 turbo back exhaust
Cobb access port protuned by XX Tuning
Perrin turbo inlet pipe
Perrin Front Mount Intercooler
Perrin coolant over-flow can
Perrin full equal length header
Perrin up-pipe
Perrin upper and lower radiator hoses
Kartboy Short throw shifter
Kartboy front and rear shifter bushings
Kartboy shift knob
Snow Performance Stage 2 Meth Kit
Aps short ram intake
Fp Green internal wastegate turbo charger
Deatsch 740cc fuel injectors
NGK 1 step colder spark plugs
ACT 2600lb pressure plate w/street disc
Autometer carbon fiber boost gauge
Autometer gauge pod
Old 09-12-2007, 01:25 PM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
With all that money spent, just go grab a TiAL or Forge or something.
wcbjr is offline
Old 09-12-2007, 01:42 PM   #12
BlueMan05
Member#: 129934
2015 STi LE
Wrb
i was think forged or perrin i dunno gotta find one by friday
Old 09-12-2007, 01:56 PM   #13
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Just remove the BPV and block it off for tuning until you can buy another one.
wcbjr is offline
Old 09-12-2007, 04:38 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
You better get a race gas tune with that green too, dont stop at 22 psi.
Phatron is offline
Old 09-12-2007, 07:11 PM   #15
BlueMan05
Member#: 129934
2015 STi LE
Wrb
im getting a new bov..... heres what was suggested.... aps 50/50, turbo smart dual port or full recirculate, and forge. looks like the shop only has the aps 50/50 and turbo smart full recirculate. does anyone know if ill need a boost controller or can the cobb tune that good?
kevin
Old 09-12-2007, 07:12 PM   #16
BlueMan05
Member#: 129934
2015 STi LE
Wrb
also someone local is selling a perrin recirculate one....
kevin
Old 09-12-2007, 08:33 PM   #17
BlueMan05
Member#: 129934
2015 STi LE
Wrb
picked up a perrin signature series for 185... is that a pretty good one?
kevin
Old 09-12-2007, 11:40 PM   #18
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
I use the greddy rs and fully recirc it.....holds really well......and it is adjustable.....
Jeremy05sti is offline
Old 09-13-2007, 12:02 AM   #19
fourmicah
Member#: 128760
2017 STI
kevin
I personally don't like Perrin Products, but you seem to have all of their stuff already so why not. I think the APS or the Forge would be a better choice.
fourmicah is offline
Old 09-13-2007, 12:46 AM   #20
BlueMan05
Member#: 129934
2015 STi LE
Wrb
can the cobb control my boost up 24 psi or so?
Old 09-13-2007, 10:01 AM   #21
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default On pump...
I want to say you might see low 80% duty cycles on your 740cc injectors with that setup on the street. Meth will just drop that...or if you add more boost make it break even.
Race gas will change the situation with more boost but I don't think you will max the injectors.
740's can support some fairly serious power.
Sounds like a great setup.
I run an APS BOV on my 20G setup and it seems to hold just fine. If I were you I would get something you can adjust without a hammer.
I do love adjustability.
R.
BlackEyeII is offline
Old 09-13-2007, 10:40 AM   #22
teesutt
Member#: 127940
Evil shenanigans
you may need a boost control solenoid for that much psi. the GM or Grainger will be suitable.
teesutt is offline
Old 09-13-2007, 10:44 AM   #23
BlueMan05
Member#: 129934
2015 STi LE
Wrb
i guess we'll see what he saysd on friday on the dyno
Old 09-13-2007, 10:55 AM   #24
2.0Tawd
Member#: 92415
2011 OBP WRX
I know this isn't a classified forum but i am located in storrs, ct only 25 minutes from XX and am returning my car to stock this afternoon and will have a turbosmart dual port bov for sale. I bought it at XX in April so it has only been used for approx: 4k miles. Its in excellent shape and have everything it came with whether you want to run 100% atmospheric, 50/50, or completely recirculating. New plus tax your looking at $290 and i would sell mine for much less and would meet up before you go for the tune if you would want to. pm if you are interested. good luck with the tune either way thats an awesome list of mods you have.
2.0Tawd is offline
Old 09-13-2007, 11:04 AM   #25
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
here's a thought...ask your tuner what he recommends.
- He will tell you if you need a BOV...which you don't...I ran 28psi on a 30R with the stocker.
- He will tell you if your 740's will be enough...which they will be
- He will tell you if you need another boost controller or boost solenoid....which you won't, the Protuner software will tune the boost just fine.
SloRice is offline
Closed Thread
HKS SSQV BOV Question...Not another BOV thread o2sys General Community 6 09-17-2010 08:04 PM
VTA BOV Question and Catch Can Question...Kinda Urgent FocusdSound Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-16-2008 11:14 AM
Modding a BOV ~ A different type of BOV question Sausage Newbies & FAQs 38 08-07-2006 06:40 AM
BoV Question... DannyGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 10:44 AM
BOV question imprezive General Forum Archive 6 10-15-2000 05:53 PM
