Old 01-12-2002, 11:30 AM   #1
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Default Cold air intake through foglight openings
To answer etam's question yes I have thought of that. I want to get some rounds for the inner grille area and use the opening on the passenger side for a intake. I would mesh the area on both sides. I think it would work great plus look good too.
HIHO is offline   Reply With Quote
Old 01-13-2002, 12:39 PM   #2
sovereignmk1
Member#: 11858
1998 Silver Legacy
I'd kinda be afraid of sucking up stuff with an intake down their the way and what I drive through
/Mark
sovereignmk1 is offline   Reply With Quote
Old 01-13-2002, 05:31 PM   #3
HIHO
Member#: 7624
BD5; family sedan
What are you afraid of sucking up? I dont drive in deep water so I don't think it would be a problem. Heck I was thinking about it and with the silencer removed and the foglight hole open I am sucking alot more air than usual. The air would shoot up the fender area and be sucked into the stock air box.
Old 01-13-2002, 05:55 PM   #4
sovereignmk1
Member#: 11858
1998 Silver Legacy
It's not so much deep water or Snow but Small birds, furry forest creatures along the roads to fishing spots traveling @ high velocities down those dirt roads that might get inadvertantly put in harms way
Where's the silencer?
/Mark
Old 01-13-2002, 06:20 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Yeah, I've kinda got a setup like that. For now what I've done is fabricate some mesh to fit in the opening, using the foglight mounting screws to hold it in place. I put some rubber edge protector stuff around the mesh so it wouldn't chafe the bumper skin. During last summer and fall, while it was still warm, I removed the passenger side foglight and mounted the mesh in there. After the autocross season was over, I put the foglight back in, just in case the weather called for it during the winter. That, and I won't really have a need to try to get cooler air in there. What I'd like to do is get some good aftermarket foglights, and mount them in the bottom center part of the bumber (down below where I've got my Hella's mounted). Anything would be an improvement over the factory lights. They're not worth much anyway. I'm not sure about leaving the driver side open. I'm afraid it would act like a big parachute in the fender well, unless I could find some use for all that air (brake cooling?). Anyway, here's a pic of it. It's not a good shot of the mesh or anything, but you get the idea. Sorry it's so big. It's from the local SCCA website. I could take some closeup pics if anybody wants to see it better.
richeich is offline   Reply With Quote
Old 01-13-2002, 08:08 PM   #6
HIHO
Member#: 7624
BD5; family sedan
Yeah the mesh would keep out birds, squirrels, ect. I am going to run some of that black gutter water pipe through there. I will make some kind of catch to place behind the fog opening out of fiber glass.
Old 01-13-2002, 09:57 PM   #7
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
I don't really thing you'd see any gains, and perhaps see some loss at WOT, with a setup like that. You'd have to add a fair amount of length, and some pretty serious bends, to the intake to scoop from the foglight opening. I think that would more than offset any gains you would see from the cooler air. Length, and velocity are far more critical than the density differences of a few degrees.
gavin is offline   Reply With Quote
Old 01-13-2002, 10:16 PM   #8
HIHO
Member#: 7624
BD5; family sedan
I don't see it that way. I have the stock air box with a panel filter. The intake into it is only as big as the hole in the box. So there won't be any length added to the intake. It will just direct air to the hole in the air box. There won't be any big bends because I would use a flexible hose. I figure the gutter pipe is about 4" so that will bring plenty of air to the box. It is basiclly a cold air intake that goes into the air box. I have seen alot of cold air intakes that are smaller. That is just my opinion.
Old 01-13-2002, 11:07 PM   #9
etam
Member#: 439
www
brake cooling duct on both side and cool air to air box is what I am thinking.. another project next few weeks
I got a set of Hella 550ff fog light in place of the stock fog.. I will try to get some photos.
etam
etam is offline   Reply With Quote
Old 01-14-2002, 08:07 AM   #10
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Weapon-R ram air kit
Installed it last summer...work really nice...just install the ram air shield to the dragon filter and run the flexible hose through the right fender down to the right OEM foglight, which has been removed, and has been replaced with Raybrig's Type 100 HID driving lights...Then just mount Weapon-R's inlet in back of the light. Then I mount Catz 5" SR spot lights in the center air dam, but this has nothing to do with the intake!
http://www.raybrigusa.com/html/hid_series.html#hid-type-100
http://www.fet-usa.com/products/sr.html
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 01-14-2002, 08:44 AM   #11
etam
Member#: 439
www
how much are those raybrig? 4300k? what's the size? I guess for sure it fits in the fog light place? 4"? 3"?
Old 01-14-2002, 08:15 PM   #12
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
How are you routing from the foglight opening to the airbox?? The stock intake routes into the fender well, then terminates behind the pass side headlight. The foglight opening is a good foot below the headlight, and you would have to have some near 90-degree bends, even with flexible hose, up and around the engine. There isn't a straight shot from the light opening, to the airbox.
Old 01-14-2002, 08:23 PM   #13
HIHO
Member#: 7624
BD5; family sedan
Before you correct me you need to go out and look at your engine compartment. I can stick my hand in through the foglight opening and touch the airbox opening. It is a totally strait shot.
Old 01-14-2002, 08:33 PM   #14
HIHO
Member#: 7624
BD5; family sedan
Arm is going in through the foglight opening. It is a totally strait shot.
Old 01-14-2002, 08:59 PM   #15
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I wouldn't argue with HIHO on that one.
-S
monovich is offline   Reply With Quote
Old 01-15-2002, 07:25 AM   #16
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default RAYBRIG
etam- Those Raybrig Type 100 HID are 3" in diameter and the Catz SR are alomost 5" in diameter
CRAZY KEN
Water Through The Cold Air Intake??? 07BlUEbaru South West Impreza Club Forum -- SWIC 35 07-28-2007 04:04 AM
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 01:46 AM
Opinions on cold-air intake or no cold-air? gldenchld Tri-State Area Forum 7 11-06-2002 07:55 PM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-20-2002 12:27 AM
