Old 09-13-2007, 11:07 AM   #1
recruitX
Member#: 151838
02 WRX
Default Tranny leaking at axle
I lifted my car up yesterday and noticed that my tranny has developed a small leak were the driveers side axle goes into the tranny. From what I have read, it seams like it is the seal. How hard is it to replace this seal? Would I have to take apart the tranny? Or could I just yank out the axle and do it from there?
recruitX is offline   Reply With Quote
Old 09-15-2007, 04:19 PM   #2
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
Pull the Axle, there should be no need to remove the tranny, the o-ring and seal are about 18 dollars from a subaru dealer.
neo277 is offline   Reply With Quote
Old 09-16-2007, 08:45 AM   #3
gotsol
Member#: 17346
08 Cayman S
is it tranny fluid or axle grease? Both can show up in the same area
gotsol is offline   Reply With Quote
Old 09-16-2007, 01:17 PM   #4
recruitX
Member#: 151838
02 WRX
It looks like a little of both. But there is definatly tranny trickling down the side.
Old 09-17-2007, 11:06 AM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
See below. I made a mistake
Tim Sanderson is offline   Reply With Quote
Old 09-17-2007, 11:13 AM   #6
Feign
Member#: 68604
06 STi
Good info Tim.
How about part numbers for the necessary items?
Feign is offline   Reply With Quote
Old 09-17-2007, 11:29 AM   #7
recruitX
Member#: 151838
02 WRX
Hey tim,
So this procedure would not work on my car? http://forums.nasioc.com/forums/show....php?t=1097344
Is it because its a different construction?
Old 09-17-2007, 11:30 AM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Originally Posted by Feign View Post
Good info Tim.
806730042 Oil Seal
806984040 O Ring
Old 09-17-2007, 11:35 AM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Well S.O.A.B!
I just checked a couple transmissions I have laying around and you can remove them externally.
Boy was I wrong.
Small tranny leak at shifter linkage PeterJ Transmission (AT/MT) & Driveline 18 11-16-2012 07:38 PM
tranny leak jaywrx Transmission (AT/MT) & Driveline 7 04-27-2011 03:02 AM
Tranny Leak after installing brand new Axle Seals?? Please help nine7oh Transmission (AT/MT) & Driveline 7 08-20-2009 02:17 AM
Recent Six Speed swap, fluid leak. Not Axles NSandman95 Transmission (AT/MT) & Driveline 3 06-25-2009 12:23 PM
