Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-13-2007, 12:39 PM   #1
Tirpitz56
Member#: 77728
2001 Impreza RS
Default STI DBW Problems during swap HELP
I am currently getting a swap done at east coast swappers and they are having a problem getting the throttle to work. They say it will start and idle but when you give it the gas nothing happens. They swapped the the pedal out already and nothing changed and they swapped the ecu and nothing changed. It is an 04 sti harness with an 05 sti motor and they checked all the wiring and said it was good along with the voltages. Is the last thing to do is change out the throttle body or can it be something else. This is the first time they have had this problem but I was hoping someone else had this problem.
Tirpitz56 is offline   Reply With Quote
Old 09-27-2007, 04:37 PM   #2
Tirpitz56
Member#: 77728
2001 Impreza RS
bump. someone help
Old 09-27-2007, 04:51 PM   #3
ovedrivex
Member#: 116774
1997 Project GC8
i thought the throttle was mechanical and not electrical.( i may be wrong i havnt actually started my swap yet so i have no experience yet.) so if its mechanical wouldnt you just adjust the cable?
ovedrivex is offline   Reply With Quote
Old 09-27-2007, 04:59 PM   #4
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
you sure it's not the throttle body actuator?
latinskllz is offline   Reply With Quote
Old 09-27-2007, 08:06 PM   #5
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Negative, The throttle on all usdm sti's are drive by wire, which means that it is all done electronically instead of with a throttle cable like the older subaru's.
flystiguy14 is offline   Reply With Quote
Old 10-01-2007, 08:39 PM   #6
06subiguy
Member#: 119389
2006 SUBARU
OBSIDIAN BLACK PEARL
ive had problems with the pins in the connector. taking them on and off will loosen up the pins and you wont have good connections. i usually pull the pins out 1 at a time and bend the tabs back into possition. i have done this several times on stock sti's and it has fixed the problem. same thing with the pins at the ecm.
06subiguy is offline   Reply With Quote
Old 10-02-2007, 03:15 PM   #7
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Sounds like a good idea but he did say that ecs was getting voltages no?
Sti DBW Throttle Body help Ayanamieve Southern California Impreza Club Forum -- SCIC 0 05-02-2008 09:23 PM
STI DBW swap problem snowcrzy Subaru Conversions 13 08-17-2007 05:11 AM
Hydra Dbw Problem El Gato Other Engine Management 2 03-27-2006 11:10 AM
04 sti into 02 wrx issues airbag sensors and dbw gas pedal mount help!!!!!!! boostinwrx Subaru Conversions 2 02-28-2006 11:22 AM
fuel problem with ver 7 motor swap,help!! momentum Subaru Conversions 34 01-01-2005 11:03 PM
