Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 09-13-2007, 02:56 PM   #1
breakfasteatre
Member#: 131662
1996 Legacy LS
Default 05 sti suspension in bg, possible?
I know for a fact that 04 sti struts and springs fit with sti tophats, but what about 05 sti struts and springs?
and on the same topic, what about sti swaybars? Im sure the rear fits but the front probably doesnt, correct?
i searched but it seems that people have only installed 04 sti suspension, and that there is no real answer about 05+
breakfasteatre is offline   Reply With Quote
Old 09-13-2007, 02:59 PM   #2
lgt2000
Member#: 140073
2005 LGT
Red
the front sway bar will definetly not fit because its made to bolt on to a turbo crossmember. As far as the rear, it wont bolt on becuase the legacy's trunk is deeper but you could cut into the trunk some and make it fit
lgt2000 is offline   Reply With Quote
Old 09-13-2007, 04:54 PM   #3
jamal
Member#: 71875
98 2.5GT
my wheels fit
The STI rear swaybar is wider and uses different endlinks and lateral links. I hear they work on newer Foresters though.
As for the struts, in 05 the wheel bearings were upgraded and the front hub/knuckle changed.
jamal is offline   Reply With Quote
Old 09-13-2007, 05:12 PM   #4
breakfasteatre
Member#: 131662
1996 Legacy LS
so what are you saying, that 05+ struts and springs wont fit?
yeah i should have figured about the swaybar since the sti has a wider track than my legacy, i was just guessing earlier.
Old 09-13-2007, 05:51 PM   #5
jamal
Member#: 71875
98 2.5GT
my wheels fit
no. The part on the knuckle where the strut mounts is wider and the bolts are spaced farther apart.
http://forums.nasioc.com/forums/show....php?t=1303381
Old 09-17-2007, 02:59 AM   #6
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
this may help (or be repost) I cannot recall source or vouch for validity or if they apply to USDM (Assuming they are JDM figures)
JoKerNZ is offline   Reply With Quote
05 sti suspension in 04 wrx?? Supra95 Brakes, Steering & Suspension 3 11-27-2006 02:25 AM
05 STi suspension in something other than an STI SubeSTIle South West Impreza Club Forum -- SWIC 6 07-12-2006 08:07 PM
stock 05 STi suspension VS stock 05 RS suspension erikm Brakes, Steering & Suspension 5 03-15-2006 10:55 AM
Using 05 USDM STI Suspension in 02-04 WRX kahtep Brakes, Steering & Suspension 15 01-02-2006 10:57 PM
05 Sti Seats in 03 WRX, Possible? newsman Interior & Exterior Modification 5 08-25-2004 04:27 PM
