Old 01-12-2002, 01:06 PM   #1
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Unhappy Pass. Rear Rubbing Noise??
Our '98 Legacy L Wagon, automatic, AWD, 2.2, ABS developed a rubbing noise from the right (passengers side) rear wheel area yesterday. I have tried using the E-brake a couple of time to see if it was hanging-up but no fix. We had the tires rotated about a week ago, the rear brakes were done by the dealer about 15,000 miles ago. We did drive it in some pretty bad conditions in Northern Mich., Canada, and Buffalo, NY fully loaded about two weeks ago. The car is has "500 miles" left on the Limited drivetrain warranty so if it's a rear wheel bearing or a covered part I want to get it addressed while it is still under warranty! Thanks
shortlid is offline   Reply With Quote
Old 01-12-2002, 01:09 PM   #2
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default Allways
It does it all the time accelerating, decelrating. it is more pronounced at slow speeds but I think it is still there at high speed also. It does not clunck just rubs. I does not change with turns either but, it is a rear wheel?
Old 01-13-2002, 06:26 AM   #3
Bagheera85
Member#: 13365
1991 Legacy Wagon GT
Dark Red
Does the pitch change with the speed of the vehicle? And is it kind of like a grinding noise?
Bagheera85 is offline   Reply With Quote
Old 01-13-2002, 06:30 PM   #4
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default Kind of
It gets fainter with speed but thet is probibly just it is harder to hear it with the speed, wind, enigne, driveline, etc.?? but, it is still there at speed just more noiticeable when going slower.
Old 01-13-2002, 07:45 PM   #5
Bagheera85
Member#: 13365
Dark Red
I had a wheel bearing go bad on my Legacy. Made a grinding like noise, and the pitch would change slightly with speed(got a little higher the faster I went). I had a mechanic find out what the noise was, and he used a screwdriver(I think) to probe my wheel bearing for sound while the wheel were moving(on a lift). So, you could try that. If you can get it on a lift, have someone put it in gear and hit the gas a little bit. Should be able to narrow it down then. Just remember, BE CAREFUL as the wheels will be turning, and they WON'T yield to you.
Old 01-13-2002, 08:54 PM   #6
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default Miles??
How many miles id you legacy have on iyt when the bearing failed?? Was it front or back?? What trim you have GT, OUTBACK, L, Brighton??? Do you know the asue of the failure, Thanks
Old 01-14-2002, 12:22 AM   #7
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default Heard it at stand still?
I was just driving the car and it made the noise while at a complete STOP??? That rules out bearings and brakes??? What the $#@% is IT!! I took off the wheel flushed the whole assembley with water. Checked the brakes, and the rear diff.??
Old 01-14-2002, 02:58 AM   #8
Bagheera85
Member#: 13365
Dark Red
Well, mine wasn't due to any kind of plain failure, it was caused by my front left wheel going through a concrete drainage ditch. Bent the wheel, control arm, steering linkage, and screwed the wheel bearing.
Old 01-14-2002, 09:12 AM   #9
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default That will do it
Yep that will do it, I was wondering if you had a bad impact to the bearing like you discribed or it just failed. So, I guess the Legacy bearing is good your just took a hit. But, now it rubbs without the car moving????
Old 01-17-2002, 12:45 AM   #10
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default pads
the dealer said it wa the rear pads that were bad and charged me $300 to replace them!!
Old 01-17-2002, 03:40 AM   #11
sovereignmk1
Member#: 11858
1998 Silver Legacy
I had a bearing go out as well. Of course myself beaing at fault as I took on a curb "hidden" under some snow. Also managed to break a speed sensor somehow and that caused the ABS to kick in everytime when braking to a stop(under 5mph). The bearing made a whawhawhawha sound that got faster/slower depending on speed. Took me a while to figure that one out.
/Mark
sovereignmk1 is offline   Reply With Quote
Odd grinding, rubbing noise from right rear area... Hagbard Brakes, Steering & Suspension 1 07-28-2005 01:27 PM
Rubbing noise coming from rear-right of STi special-k-STile Transmission (AT/MT) & Driveline 3 05-28-2004 11:21 PM
Any ideas? rubbing noise from rear pass side HoG General Community 2 02-20-2003 10:14 PM
Rubbing noise from rear HoG Newbies & FAQs 0 02-20-2003 06:16 PM
Rubbing from Pass. Rear shortlid Transmission (AT/MT) & Driveline 3 01-14-2002 06:42 PM
