Old 01-12-2002, 02:07 PM   #1
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
Default I am perplex about the ecu reset
My check engine light came on in my 2001 rs. So I was searching on the board and found 2 ways to do it. I like the hole idea of find the green and black plugs and putting them together. I found the green plug easy. But the black plug I could only find 1. So I started to look around and in that same harness there are two black wires with connectors on the ends taped together touching. So what is that is that my plug I am looking for? Is the plug gone?
2.5rsMI is offline   Reply With Quote
Old 01-12-2002, 02:16 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Just take the negative lead off your battery for 30 minutes, start the car up and let it come up to temp, then shut it off.
You really shouldn't just clear the CEL without getting the code read first. You'll have no idea what the problem was in the first place.
supermarkus is offline   Reply With Quote
Old 01-12-2002, 02:19 PM   #3
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
I forgot one thing. I didnt let the gas cap click on the last fill up. So its gotta be that I hope.
Old 01-12-2002, 03:59 PM   #4
Pat Green
Member#: 5818
2002 WRX, '72 510
V is for Victory, Hippie!
Cool
Actually, Shiv from Vishnu showed me an easier way to do it. Just take off your negative battery cable and step on the brakes. Instant reset!
Pat Green is offline   Reply With Quote
Old 01-12-2002, 09:01 PM   #5
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
that really works?
SQUAD_907 is offline   Reply With Quote
Old 01-13-2002, 03:16 PM   #6
Joel Gat, 1.8L
Member#: 32
Hello,
I showed that trick to Shiv Basically, once you remove the negative terminal, you want to remove any residual current - like any capacitance in the ecu. Hitting the brake lights up the tail lights and drains the remaining capacitance. Voila, ecu is out of power and is reset. That works on MOST car brands.
Joel Gat
Crew Chief
Sheehan Motor Racing
http://www.teamSMR.com
Joel Gat, 1.8L is offline   Reply With Quote
Old 01-13-2002, 07:15 PM   #7
Jung918
Member#: 10969
you are the man...!!!
Jung918 is offline   Reply With Quote
Old 01-14-2002, 07:11 PM   #8
WRX Pilot
Member#: 3487
Thumbs up I love this board!
.......and I was just about to do a big search to find out how to reset my cel! This sounds like it would work on my wrx, or atleast it should.
WRX Pilot is offline   Reply With Quote
Old 01-14-2002, 11:00 PM   #9
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
It was my gas cap. I reset it and it never came back on.
Old 01-21-2002, 04:23 PM   #10
Jung918
Member#: 10969
Has anyone reset their ecu by taking the neg off and pressing the brakes?
Old 01-22-2002, 12:28 PM   #11
WRX Pilot
Member#: 3487
Thumbs up
Yes, and it works great.
Still trying to figure out what to do about the ECU... Speedwagon Legacy Forum 1 11-16-2007 11:00 AM
If the battery dies does the ECU reset? dpk777 Newbies & FAQs 9 11-08-2007 05:56 PM
How Do You Know If the ECU Reset shenyingwu Newbies & FAQs 16 12-30-2004 10:09 PM
Clear me up on the ECU reset! Matt Monson Technical Forum Archive 13 07-20-2000 09:36 PM
