Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 01-12-2002, 04:25 PM   #1
no_rex_yet
Member Sales Rating: (7)
Member#: 7351
04 330cic
Default Vishnu crank pulley
Posted this in the Forced Induction thread, but thought it'd be worthwhile to have it here too for easier seaches.
I took the plunge and had the Vishnu installed (tried it myself but couldn't get the damn thing off), and I LOVE IT!
No problems hitting the 7k redline (my engine is stock except for ITG filter). The engine now revs much more naturally and evenly, in contrast to stock where it would bog below 3k rpm and then finally rev up. I can pull easier out of 2nd gear "rolling stops," and drive easily in 5th gear at 45-50 mph (whereas b/f, it would lug until I reached 50-55 mph). I can barely notice dimming of lights at idle, but only with my fogs on concurrently. Much, much less dimming than when I had AEM pullies on my old Honda. I have to really try to look for it to notice.
Also, my shop mentioned that they've seen people (or person) with a crank pulley problem when the bolt has not been torqued enough on the install. The pulley will wobble and transmit vibration that eventually destroys the block This appeared in only one case however, I think. So, make sure you torque them down! Not sure what the spec is though.
In any case, this is an awsome mod that greatly increases drivability. Keeping my fingers crossed that nothing bad results from it
no_rex_yet is offline   Reply With Quote
Old 01-14-2002, 12:41 AM   #2
girl
Member#: 7768
yup. now it's time to take the plunge for the rest of the stage0. u wont regret it
girl is offline   Reply With Quote
Old 01-14-2002, 01:01 AM   #3
nhluhr
John Wayne Toilet Paper
Member Sales Rating: (22)
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I also have a Vishnu underdrive pulley and my sentiments are just as above: Feels great! Easy to install!
Only gripe is that the provided 850-length belt for the PS and Alternator is a bit hard to get on but can be done given some patience and hard work (get a friend to help roll the belt on).
Once fitted, all is well.
nhluhr is offline   Reply With Quote
Old 02-13-2002, 03:52 PM   #4
cmaj7
Member Sales Rating: (1)
Member#: 12677
2002 Subaru WRX
WR Blue
Default Vishnu
I also installed a Vishnu Underdrive pulley. Biggest difference I notice is better engine response and power comes on much more smoothly.
cmaj7 is offline   Reply With Quote
Old 02-25-2002, 02:10 PM   #5
Ben R.
Member#: 15578
Default Re: Vishnu crank pulley
keep in mind that crank bolts are made to strech a certin amount. You do not want to over torque the bolt as that will sometimes make the bolt snap while in use.
Ben R. is offline   Reply With Quote
Old 02-27-2002, 07:46 PM   #6
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
How much is just the pulley?
What IS the torque spec for the crank pulley bolt?
Si2WRX is offline   Reply With Quote
Old 03-05-2002, 08:34 PM   #7
roadr8cer2
Member#: 12736
white
Question vishnu pulleys worth it?
Wondering if any one noticed power gains from this mod alone?
roadr8cer2 is offline   Reply With Quote
Old 03-05-2002, 09:16 PM   #8
2OHOH2WRX
Member#: 11888
Yes, there is a small but noticeable difference in the way the car idles and revs up.
BTW, this should be posted in one of the technical forums, like Factory Forced Induction... after a search, because I'm certain that this topic has been mauled to death by now
2OHOH2WRX is offline   Reply With Quote
Old 03-06-2002, 02:07 PM   #9
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
About 95 lbs.
Narcisse91 is offline   Reply With Quote
Old 03-21-2002, 10:19 PM   #10
Redleader
Member#: 14430
'02 WRX Wagon WRB
STi swap luvin it!!!
I after puttting my Vishnu pulley on I notice a very nice improvement in torque!
Sometimes I wonder if the nuts is on there right because when the engine is running the nut looks like it is wobbling but the pulley rotating smoothly. Could I have a bent or asymmetrical nut?
Redleader
Redleader is offline   Reply With Quote
Old 03-22-2002, 09:31 AM   #11
no_rex_yet
Member#: 7351
04 330cic
The wobbly nut thing is normal. There's some paint or something on it that makes it look like it's wobbly. It's not
Old 03-22-2002, 12:39 PM   #12
Redleader
Member#: 14430
'02 WRX Wagon WRB
Thanks! I was a little worried. I don't want main bearing probs.
Redleader
Vishnu crank pulley for sale SubaRA Private 'For Sale' Classifieds 0 03-23-2004 04:23 PM
vishnu crank pulley SubaRA Private 'For Sale' Classifieds 1 03-17-2004 09:26 AM
Vishnu Crank Pulley, Install and Review Hotrodguru Texas Impreza Club Forum -- TXIC 7 01-20-2004 12:57 PM
For Sale: Vishnu Crank Pulley Zephyr Private 'For Sale' Classifieds 4 01-07-2004 10:10 AM
FS: Vishnu Crank Pulley Egan Private 'For Sale' Classifieds 4 08-13-2003 06:24 PM
