#1 |
Member#: 2436
Vehicle:2001 Impreza 2.5RS Aspen White |
Hello everyone. Anyone have a scangauge II with a swapped RS?
I just got mine yesterday and the screen goes out after driving for a bit. I've tried different modes and PID's. No luck I have a 2001 RS swapped to a 2003 WRX. Post your mode configs. swapped or not. Thanks Rob
#2 |
Member#: 118209
Vehicle:2002 WRX Sedan |
does it do it consistently? mine will shut itself off maybe 1 out 10 trips.. no idea why, it just does.
#3 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
funky. i don't think i have had an issue with it turning off. its always comes on when i turn on the car. I have had it on for several 8hr trips with no issues with it.
did you buy this from me? Shane |
#4 |
Member#: 2436
Yup i bought it from you.
I drove to work with it today, it shut off on me a couple of times. |
#5 |
Member#: 140712
SCIC
let me call them and see what i can do. as i don't think it should do that.
Shane |
#6 |
Member#: 140712
SCIC
ok, they said you need to change the mode to "supported mode" there is a little blurb in the back of the manual that tells you about this issue. apparently with some subarus it will do this, and changing it to "supported mode" fixes this. Hope this helps
here is what the manual says. they also said some random 01 and other years are also affected by this. Pressing the top buttons will change between ALL and SUPPORTED. Most vehicles use ALL which is the factory default. But some vehicles will not work properly unless SUPPORTED is used. This is the case for 1995 to 1999 Subaru vehicles. If the ScanGaugeII connects but then goes to sleep after showing little or no data on the GAUGE display, change this to SUPPORTED and press SAVE. |
| Thread Tools | |
| Display Modes | |
| ScanGauge II XGauge Commands that work with Subarus | MConte05 | Engine Management & Tuning | 25 | 01-18-2011 07:25 PM |
| ScanGauge II Sale | MyRuRex | General Community | 29 | 05-28-2009 09:48 AM |
| ScanGauge II | claycron | Interior/Dressup/Audio & Security | 10 | 02-27-2009 02:10 PM |
| WTB: Scangauge II | evan_impreza | Private 'Wanted' Classifieds | 1 | 08-19-2008 10:53 PM |
| Scangauge II mounting? | Eyedoc Orlando | Interior & Exterior Modification | 6 | 05-21-2007 03:13 PM |
