Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 09-14-2007, 04:33 PM   #1
InfamousDX
Member#: 25413
Question How to put a 2007 usdm sti 6 speed into my 2003 WRX
Searched but to no avail. If it's somewhere, sorry for posting this.
So lemme lay it out simple. 2007 usdm sti 6 speed transmission. 2003 wrx. What will I need to complete this swap WHILST keeping the stock r160?
I only ask about these specific years because I read the 07 usdm sti rear diff is 3.54 just like WRX's now so this swap should be easier than in the past. Thanks all.
Old 09-17-2007, 12:20 PM   #2
InfamousDX
Member#: 25413
just bumping this up in hopes for some insight.
Old 09-17-2007, 12:30 PM   #3
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
is the 07 sti tanny the same as the 06? if so you will be able to keep your r160 if you drive a bugeye
AWDWRXLOVER is online now   Reply With Quote
Old 09-17-2007, 09:14 PM   #4
InfamousDX
Member#: 25413
Did you do the swap? What do I need from the sti - tranny, linkage, shifter, clutch + flywheel setup... anything else?
Old 09-18-2007, 06:29 AM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
depends on which swap you do. i went full out. 5x114 hubs,r180, brembos front and rear etc. if you want to keep stock brakes you will need shorter drive shaft(auto), 04 sti axle front stubs w/ clips. there are several good sticky thread w/ links to other swpa threads that are very useful. read up and get a plan and budget before you start buying parts.
there are little things you will need to, fly wheel bolts for example, wrx has less than sti.
Old 09-18-2007, 11:47 AM   #6
InfamousDX
Member#: 25413
I've been reading and I've successfully done an 04 sti into a wrx, but I thought the 07 was slightly different.
I plan on keeping the WRX rear brakes (have 2 pots w/kartboy adapters) and alerady have 04 sti brembo fronts with my factory WRX axles. I plan on keeping the r160 as well so i guess the auto DS is in order.
Old 09-19-2007, 05:50 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
bookmarking this as I am also interested in this swap with the good 07 ratios. I can't imagine how much one will cost right now though
rjrutzky is offline   Reply With Quote
Old 09-19-2007, 10:55 PM   #8
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Just wondering, how did the wiring harnesses match up? I know mine will be different being an 04 6 Speed but i don't know if i will have to hard wire it in...
Jpizzzle is offline   Reply With Quote
Old 10-16-2007, 08:05 PM   #9
InfamousDX
Member#: 25413
bump.
Old 10-17-2007, 12:45 PM   #10
MrSlowbaru
Member#: 129231
2005 wrx
cgm
to the top, somewhere i heard that the 07 trannys are more of a drop in affair than the 06's were.
i want to confirm
MrSlowbaru is offline   Reply With Quote
Old 10-18-2007, 12:06 AM   #11
speedracer500
Member#: 6167
2002 WRX Big build
06 STi built, 00 L wagon
I have an 2007 sti limited tranny in my 02 WRX using stock R160 diff. Contact east coast swappers (http://eastcoastswappers.com/) (they did my install). There is a kit that they use to mate the drive shaft and axles to the tranny.
speedracer500 is offline   Reply With Quote
Old 10-27-2007, 01:54 AM   #12
speedracer500
Member#: 6167
2002 WRX Big build
bump.
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 792 10-01-2014 08:58 PM
How To - Swap a 2004 USDM STi Steering Wheel into a 2002 WRX Rizzo314 Interior & Exterior Modification 115 10-01-2014 02:17 PM
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 03:02 PM
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 11:04 PM
USDM STI 6-speed into USDM WRX? hobbzz Transmission (AT/MT) & Driveline 12 01-12-2003 04:26 AM
