Old 01-12-2002, 07:08 PM   #1
toobee1
Member#: 7439
Blaze Yellow
Default WRX develops chirp noise?
My 4500 mile old WRX developed a chirping noise when you mildly rev the engine. The chirp noise is actually heard when the engine finally settles back down to normal idle rpm after a rev. The dealer has recently changed out a bad cam sensor which had caused a CEL. Other than take the car back to the dealer or dumb bird jokes, does anyone have any helpful experience correcting this problem? Would a ECU reset do any good?
toobee1 is offline   Reply With Quote
Old 01-12-2002, 09:50 PM   #2
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
you might have a boost leak. An ECU reset would do nothing.
ChrisW is offline   Reply With Quote
Old 01-12-2002, 10:07 PM   #3
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
I hear it too sometimes in the same conditions stated. Car feels fine, could it be an exhuast leak?
Jay
illmatic is offline   Reply With Quote
Old 01-12-2002, 10:32 PM   #4
cygnusz
Member#: 8566
2002 WRX TXS Stg 1
WR Blue
Default me too
Squeaky chirp when idle reving in the garage after driving home. Tap and release the gas pedal quickly from idle to hear it in the engine compartment. Not too worried it runs great. If I find it, I'll post it. 11,000miles now.
cygnusz is offline   Reply With Quote
Old 01-13-2002, 10:49 AM   #5
z0s0
Member#: 7146
2015 Forester XT
Same here.
z0s0 is offline   Reply With Quote
Old 01-13-2002, 09:40 PM   #6
02RS
Member#: 8638
2002 WRX Sedan
mine does it too i only have like 530 miles on mine.
John
Extra Cripsy RS
Aspen White WRX
02RS is offline   Reply With Quote
Old 01-13-2002, 09:45 PM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default the noise comes out of the muffler
The stock muffler can make that noise.
talk to steve_d. he has the same thing, as do I.
I noticed it after removing the pre-muffler resonator but not sure if it was coincidental. The chirp happens under light revving as the needle is around 1500rpms.
nhluhr is offline   Reply With Quote
Old 04-27-2002, 11:32 PM   #8
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
Default Any resolution?
Has there been any resolution to this? I had a chirping noise which actually sounded almost exactly like a cricket. It has since developed into a dull clicking noise. It is most noticeable at idle.
Cheers, Joe
veloLexus is offline   Reply With Quote
Old 04-28-2002, 12:12 AM   #9
blarg
Member#: 17811
blue
see if your belts are loose...if you had major work done recently maybe they didn't tighten the belt right when they were done.
blarg is offline   Reply With Quote
Old 04-28-2002, 08:44 PM   #10
BamBooI
Member#: 10945
2006 Evolution IX
It is the stock exhaust. Sounds like a small chirp.
BamBooI is offline   Reply With Quote
Old 04-28-2002, 10:25 PM   #11
ninrex
Member#: 9851
'07 WRX Wagon
I noticed the same thing and got right down under the car while having someone lightly rev it. The noise was most loud right at the exhaust tip. It wasn't the hangers or anything on the outside of the exhaust, but seemed to be coming from the inside. So was it really coming from the muffler? I doubt it. But why would the wastegate be opening at such a low rpm (~3000) under no load? I really don't think that's it.
ninrex is offline   Reply With Quote
Old 04-28-2002, 10:52 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
it's NOT the wastegate.
it's just the stock muffler.
Old 04-28-2002, 11:43 PM   #13
titsataki
Member#: 4402
I have it as well. I do have the stock exchaust. It did not have it when I had my M2 exchaust. I thought it was a leak but the car runs fine.
cheers
Nick
titsataki is offline   Reply With Quote
Old 04-28-2002, 11:48 PM   #14
ninrex
Member#: 9851
'07 WRX Wagon
I'd tend to agree with you, but any speculation on why the muffler would be chirping?
Old 04-28-2002, 11:55 PM   #15
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
I'm a little skeptical that it's the muffler as there's no sound coming from the back of (or underneath) the car. In addition this sound is cyclical. Think of a cricket and apply some negative varispeed (for you non-audio geeks that means slow the recording down ) and that is what I hear. If it was the muffler I would expect it to happen on most WRX's and I would expect it to be more of a constant sound (like George Jetson's... car???). In additnion this chirping sometimes manifests itself as a dull clicking. The belt theory sounds the most plausible.
I'm tellin' ya, my car has a major identity crisis. It thinks it's a freakin' cricket. I don't know of many crickets that hang out in fields where the ground is like pavement and the grass and trees look like orange triangular cylindrical like things. At least it doesn't hop.
Joe
Old 04-29-2002, 12:31 AM   #16
BamBooI
Member#: 10945
2006 Evolution IX
mine only does it when i rev to like 1k rpms and let off
Old 04-29-2002, 01:07 AM   #17
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
mine only does it at 1500rpms while letting off.
with my glasspack, i don't hear the chirping (of course, i don't hear much of anything besides the exhaust noise with that thing). I am under the impression it's some kind of airflow thing in the stock muffler... The ticking noise others are hearing i think is something different.
I DO have a George Jetson sound too, but that's because I'm catless and I hear the turbo fins chopping the exhaust at around 3krpms under light acceleration.
Old 04-29-2002, 04:51 AM   #18
crayon
Member#: 16073
2002 WRX Sport Wagon
WR Blue
Mines chirping too. Throttle blips to 1500 rpms when car is warm, chirps on the way back down to idle.
I'm leaning towards an exhaust leak or exhaust hanger as the cause.
Someone found a loose metal wiring harness connector that was scraping on the floorpan as the cause of his. Acutally wore throught the undercoat and was metal on metal.
crayon is offline   Reply With Quote
Old 04-29-2002, 09:07 AM   #19
BamBooI
Member#: 10945
2006 Evolution IX
Where is this harness?
Old 04-29-2002, 01:07 PM   #20
crayon
Member#: 16073
WR Blue
From what I understand, 2nd hand, it is between the tranny and floorboard.
Old 04-29-2002, 03:48 PM   #21
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
same problem. rev to 1500 then let it chirp all the way back to idle.
im guessing its an exhaust leak, cause i developed one after installing stage zero.
any other guesses on the fix to this prob?
Penguinking is offline   Reply With Quote
Old 05-06-2002, 12:46 PM   #22
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
Its not an exhaust leak or the stock muffler.
I had it with the stock exhaust since I bought the car.
I had it with the turboXS turbo-back exhaust (except louder)
and I have it now with the turboXS turbo back and upipe.
I dont consider it a problem
elgorey is offline   Reply With Quote
Old 05-06-2002, 01:37 PM   #23
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
yeah, but do you still know whats causing the problem? is it backflow from teh exhaust or something like that?
Old 05-06-2002, 03:18 PM   #24
elgorey
Member#: 4374
06 Titan,99,94 SM
although Im just guessing like everybody else (and adding to the confusion) my assumption is that it is something similar or related to the backfiring that most tuned cars exhibit.
Old 05-06-2002, 04:47 PM   #25
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
...but the car doesn't backfire when you rev it to 2k and then let it drop to idle well at least that doesn't happen w/ my car
What is that Chirping Noise from Front engine on a 2007 Wrx Sti bluesti888 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-09-2010 09:23 PM
Chirping noise...help! Boujie Transmission (AT/MT) & Driveline 7 06-09-2003 12:25 PM
installed up-pipe, now hearing a strange chirping noise? Rallye-fan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-07-2003 12:12 AM
Fluttering chirp noise @70mph and up anyone? munkis Normally Aspirated Powertrain 2 01-31-2002 06:54 PM
Chirpping noise coming from right front tire? ImprezedRS Brakes, Steering & Suspension 1 08-21-2001 01:44 PM
