Old 01-12-2002, 07:34 PM   #1
scoobi02
Member#: 14045
99 Forester
White like virgin snow
Default boost gauge problem
I just installed an autometer boost gauge (mechanical) and I am reading a vacuum of about 14 at idle and the only time I see boost is when I get the engine spun up to 3000 + RPM's and then it is about only 5lbs. I connected it to the BOV hose as I have seen on this site with a brass T. I used a 6in vacuum hose and then an adapter so I could run the autometer nylon tube the rest of the way to the gauge. I tried a search and didn't find anything. Any help would be appreciated.
scoobi02 is offline   Reply With Quote
Old 01-12-2002, 08:08 PM   #2
BullsWRX
Member#: 12097
2003 Ford Mustang GT
Dark Shadow Grey
Sounds like their is something pinching your nylon hose probably... Cause the vac is too low and so it the boost.
After I installed my boost gauge I had the hose pinched completely off (ooops) and my gauge never moved off zero. Just check your hose to your gauge, unless you feel like there might be a leak at the T. Did you use teflon tape on the brass parts? I dunno, just some things to look at. I connected my boost gauge at the same place and I see 20 vac and 14 boost.
BullsWRX is offline   Reply With Quote
Boost and boost gauge problem BajaT05 Baja Forum 19 03-24-2005 08:24 PM
boost gauge problem! acting strange and low boost seasons Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-07-2005 02:42 AM
Boost gauge problems AK_2002_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-29-2002 09:58 AM
Boost gauge problem, need some help! datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-15-2001 10:01 PM
Boost Gauge Problem BurtonCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-12-2001 09:02 AM
