Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 09-15-2007, 11:19 AM   #1
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Default New to WRX, engine noises and other questions
Pardon my newbie ignorance. I'm looking at used WRXs and test drove my first one yesterday.
I expected a turbo "whirring" noise, but I did not expect the hissing sounds that were also there. Are these normal? What is the cause?
Also, is the WRX hood fiberglass? The one I drove sure didn't feel like metal.
What are weak points to look for in a 75K+ mileage car?
Is the AWD system robust?
Thanks
mmiller2002 is offline   Reply With Quote
Old 09-15-2007, 11:29 AM   #2
jamesnobrakes
Member#: 140999
2004 WRX Wagon
You can't hear the turbo because there's a turbo-silencer box in the right fender. An aftermarket intake will let you hear it, but you have to be very carefull because most aftermarket intakes will screw up the MAF sensor, which will cause problems. I use the SPT one and I like it.
The hood is aluminum.
jamesnobrakes is offline   Reply With Quote
Old 09-15-2007, 11:49 AM   #3
SilverSubaab
Member#: 88288
2014 VW GLI
Hard to tell what is normal or questionable on the internet, especially concerning a Subaru/WRX. You will hear turbo spool sounds, but I would have any car you are interested in inspected by a local Subaru dealer or someone you trust who knows Subaru.
SilverSubaab is online now   Reply With Quote
Old 09-15-2007, 11:57 AM   #4
CynicX
Member#: 48199
06 WRX
The hood is aluminum....dents fairly easily (I have MINOR hail damage) but its really light....
CynicX is offline   Reply With Quote
Old 09-15-2007, 02:48 PM   #5
mmiller2002
Member#: 159286
Thanks.
I did hear the subdued turbo whine. Is the popping/hiss sound the wastegate blow-off valve? Is there a way to make it quieter?
What's the polished cylindrical thing mounted on the front of the intercooler?
Old 09-15-2007, 02:55 PM   #6
SurfWagon
Member#: 156861
2002 Wagon
mbp, evo3/e85
I would assume that you're talking about the blow off valve. The stocker isn't really polished, but many aftermarkets are....look to see if there is a hose that runs out of it that's about 1" thick. If it doesn't have one, I would bet it's an atmospheric BOV and that would sure create some of the noises you heard. Sounds cool, but messes with AFR unless there is some form of engine management.
SurfWagon is offline   Reply With Quote
Old 09-15-2007, 05:51 PM   #7
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Never mind.
Old 09-15-2007, 06:23 PM   #8
rkramer
Member#: 118209
2015 WRX Limitec
it 'sounds' like that car has numerous mods, at least a bov and maybe aftermarket hood? i wouldn't go anywhere close to a modded wrx with high mileage, you are probably getting someone else's problem that they unloaded. ANY used wrx you buy should be in bone stock condition, at least powertrain wise... Take a good high res picture of the entire engine bay and post it on here if you really want to know.
Old 09-15-2007, 06:51 PM   #9
Gas.I.Lean
Member#: 159033
'02 WRX
Midnight Black Pearl
I had the same sounds with my stock wrx, the turbo "whine" is not as easy to hear as one expects. You hear more of a sucking lower "wurrr" with the snorkus in place. The hood is light, aluminum as stated above, fiber glass or carbon is easy to tell. Tapping or just touching should tell you, fiberglass is warm to the touch and sounds hollow. Aluminum stays cool as its metal and the sound is metallic also.
Gas.I.Lean is offline   Reply With Quote
Old 09-16-2007, 09:34 AM   #10
mmiller2002
Member#: 159286
Thanks for the input. I'm not interested in buying this particular car, but it was my first WRX drive, so I'm trying to learn the ropes in case I want to buy one. The thing that concerns me about WRXs compared to the other models I'm looking for is that they seem to be attract lots of owners that have "hacked" things just for show or cool sounds. I'll bet that I'm a bit older than the average WRX owner, and can wait for the right car to come along.
Another general question, did all WRX's come with a rear wing?
Thanks for the great info!
2.5 RS w/143k miles - creaking noise and other stuff jpodlasek66 Service & Maintenance 0 10-05-2007 03:17 PM
What do a new engine, headlights, and other misc bits equal? Pictures. 02R6 Member's Car Gallery 25 09-22-2004 07:55 PM
Mods from WRX and other questions StiDreams STi Forum Archive 1 05-02-2003 07:31 PM
Difference between AWD and 4WD? And other questions... AWD987 Newbies & FAQs 7 01-16-2003 12:00 AM
Rattles, road noise, and other strange noises ggiles@clarionnet.com Car Audio, Video & Security 1 11-15-2001 10:01 AM
