Old 09-15-2007, 12:30 PM   #1
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Default Weight reduction; it works.
Last weekend a few friends and I removed the front and rear bumpers from my '05 STi, along with the subframe. Total weight removed: 88.2 lbs
I have 74 passes at the track in the STi, in all kinds of temperature/humidity/barometric pressure, and I take copious notes.
Here's a screen-cap of my times from last night...
60' / 330' / 594' / 8th ET / 8th MPH
From previous runs under nearly identical conditions I can say I definitely averaged a mid 8.1, but this time I averaged a mid 8.0, so there's no question in my mind that the weight-loss helped tremendously (remember, this is only an 8th mile).
The very best part was running 11 times (most with no cool-down whatsoever, and within 3 minutes of each other), and 9 of them being 8.0 runs. Bracket-racers, eat your heart out...lol. I beat every Camaro/Firebird/Mustang at the track except 2, and by the end of the night they were all crowded around my car like mourners at their own funeral .
Mods: Helix catted down-pipe + professional tune (Jorge / RiftsWRX).
UltimateLurker is offline   Reply With Quote
Old 09-15-2007, 12:36 PM   #2
JustinsWRX
Member#: 72735
Hows the car handle with the subframe removed? I've already removed the front and rear bumper beams and was thinking about removing subframe aswell but wasn't sure how it would effect the handling. Thanks
JustinsWRX is offline   Reply With Quote
Old 09-15-2007, 12:48 PM   #3
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
I honestly can't tell any difference at all, I'm sure there is some if you're cornering super aggressively, but I corner at 7-10ths at most.
Old 09-15-2007, 04:35 PM   #4
pharo
Member#: 79266
2005 05 Sti
the slow color
OO this is very interesting. So did you remove the front and rear bumper beams as well? Also, do you think it is due to the fact that the weight removed was on the outer edge of the car that it made more of a difference.
I think it would be interesting to see how much the jack + rear spare (roughly 33 lbs) and having 4 gallons of gas (since each gallon weighs between 5.8-6.5 lbs).
Thanks for posting this up, as I have been feeling this might be an interesting route to try.
pharo is offline   Reply With Quote
Old 09-15-2007, 05:02 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
sure it works man.. ive tried to do everything i can for weight reduction in my car without losing my interior. or radio. i did ditch the a/c though.
your notes are very copious.. nice driving!
did you remove the whole bumper?
PaulRex is offline   Reply With Quote
Old 09-15-2007, 07:33 PM   #6
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Pharo: I removed the re-bars and styrofoam. As far as the difference, it didn't help my 60' at all, but as I went down the track the engine simply had less weight to haul, so my time was better, and my trap was faster. Since the car is AWD, I think any sort of weight removal is good, and the less the car weighs the more difference each weight-reduction mod makes (PTWR). I've removed 136.2 lbs from the car in total, and there is a huge difference from stock.
Paul: The re-bars.
Here's a couple pix for you guys.
Rear re-bar with styrofoam
Front re-bar with styrofoam
Subframe
Bolts for everything
Old 09-15-2007, 07:38 PM   #7
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
In doing this removal I had to fabricate a small bracket for the rear bumper-cover to keep it from flapping at the very bottom, as 3 clips that hold it steady go into the re-bar itself. The two on the sides can be held by a couple of zip-ties, no problem, but the one in the middle looks like this now...
The bracket is made from one of those blank slot covers from the back of a computer , hey it was the perfect size, and aluminum!
Old 09-15-2007, 08:41 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
^ nice.. I wouldnt daily drive my rex like that, but for the track that is sweet. i have thought about a jdm front bumper beam though, you should consider that as a more permanent solution. at least for the front bumper.
ive gotten my rex down under 3,000lbs. without me in it and 1/4tank of gas! about 2960lbs. last time i checked, but ive added coilovers since then maybe its lighter now.. but my rims are alittle bit heavier now so maybe not lol. i still want to add a lightweight battery, and considering the front bumper beam.
paul
Old 09-15-2007, 09:36 PM   #9
Earl
Member#: 95044
Best et 12.07
Best trap 116.1 mph
I usually just take a dump before a trip to the strip and loose about 10lbs. LOL
Just keep an eye out for tank driving soccer moms on her cell phone in the rear view mirror Drew.
Earl is offline   Reply With Quote
Old 09-15-2007, 11:01 PM   #10
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
I'm pretty lucky, I drive 2.5 miles to work, and the car rarely sees the Interstate. Of course, an accident can happen anywhere, but that's the chance I'm taking.
Old 09-15-2007, 11:28 PM   #11
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Wow - that's awesome info.
I'm a firm believer in weight reduction. I'm in the process of trying to do mods to remove weight from my MY07. I have about 60 lbs off now and I haven't even taken out the heavy azz spare tire, tools, and jack. That would put me roughly at 100 lbs for a track day.
SilverSurfer04STi is offline   Reply With Quote
Old 09-16-2007, 12:57 AM   #12
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
ah interesting. I've got subframe and the front support off but haven't thought of the rear support. I'll give it a try sometime, though I don't want the fuel tank to be exploding the next time I get rearended
verc is offline   Reply With Quote
Old 09-16-2007, 12:58 AM   #13
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
I was about to say! "hey that bracket looks familiar..."
Old 09-16-2007, 02:00 AM   #14
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
wtg on the weight reduction :thumbsup:
xdrian is offline   Reply With Quote
Old 09-16-2007, 02:01 AM   #15
xdrian
Member#: 104200
828 WHP BUGEYE
get the weight of the subframe bolts too, i know those are at least another pound
Old 09-16-2007, 09:23 AM   #16
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Old 09-16-2007, 05:57 PM   #17
B16A2NR
Member#: 88676
Throw in an Odyssey / Braille Battery and lose even more with little sacrifice in cost and no sacrifice in safety or stability.
B16A2NR is offline   Reply With Quote
Old 09-16-2007, 07:17 PM   #18
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
I wish I could, but it gets pretty damn cold here, and those things won't hold up to it.
Man, I knew weight-reduction worked, I just didn't think 88 lbs would drop a 10th off of my 8th mile time. I guess I should have paid more attention to anorexicsti.
Old 09-16-2007, 07:38 PM   #19
dug-e-fresh
Member#: 4568
10.7 @ 136, 1.72 C16
11.9 @ 120, 1.89 93
I've been running the same Braille in my car for 3 years now... no issues. And Maryland winters are 10-30 degree winters.
I will say this though... don't by FROM braille... braille batteries are motorcyle batteries they relabel and resell for double the price. Do a search... there's TONS of info on this out there.
BTW- in the drag racing world, its commonly known that ~100lbs = ~0.1 seconds... so you just proved something we already knew
That said, I'd replace the front brace with a GTSpec unit or something similar... VERY nice unit.
def
dug-e-fresh is offline   Reply With Quote
Old 09-16-2007, 07:44 PM   #20
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
This is great.. For a race car. I dont sugget anyone do this on a street car. Those bumper beams and that subframe could save your life or your passengers life. You never know when that Starbucks drinking, cell phone talking, Socker mom is going to plow through an intersection and nail you. Or worse a head on.
Clark
AZScoobie is offline   Reply With Quote
Old 09-16-2007, 10:29 PM   #21
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Thanks for the info
Actually, the old rule that dropping 100 lbs takes .1 off of your ¼ ET is pure folly. 100 lbs is meaningless without context. Think about it, taking 100 lbs off of a 5,000 lb Bently will have a lot less of an effect than taking that same 100 lbs off of an Elise, it's all about power-to-weight ratio. For how heavy the STi is, I didn't expect it to be such a large improvement, but I'm certainly happy with the outcome.
Old 09-16-2007, 10:31 PM   #22
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Clark
While I appreciate your concern, I believe the beams and subframe do little, and know for a fact that the car was designed without them. I'm sure they help, but only to a minimal extent.
Old 09-16-2007, 10:59 PM   #23
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
the bumper beams do a lot actually... look at any subaru with a FMIC that has been in a fender bender. You can total the car at 10mph without that front bumper beam.
boozy04 is offline   Reply With Quote
Old 09-16-2007, 11:41 PM   #24
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
are you kidding?
Old 09-17-2007, 12:09 AM   #25
LastResort
Member#: 99289
I know the impreza in other countries has a different bumper beam, but that's far from being designed with nothing. And I don't get the subframe comment at all.
LastResort is offline   Reply With Quote
Has anyone used Alli for weight loss? Does it work? HB_Dad Off-Topic 59 11-25-2010 11:30 AM
How does a Cobb Accessport work and will it work with my parts? Twin_Cities_WRX General Community 5 03-08-2009 01:39 AM
How does a Cobb Accessport work and will it work with my parts? Twin_Cities_WRX Newbies & FAQs 2 03-07-2009 07:22 PM
Guy at working trying this strategy to get teh wimmen, will it work? Cjchaps Off-Topic 8 07-20-2007 05:14 PM
If you could eat one food item and never gain weight from it. cwb124 Off-Topic 43 12-15-2005 12:57 PM
Message Board Statistics All times are GMT -4. The time now is 01:29 AM.
