Old 01-12-2002, 09:56 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default how to test a coil pack?
So.... how do you figure out if a coil pack is bad? Tests anyone?
-B
Midwayman is offline   Reply With Quote
Old 01-12-2002, 11:36 PM   #2
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
To check for an igniter voltage signal to the coil pack, remove the electrical connector from the coil pack. Connect a 12 volt test light to the battery positive terminal. Make sure it is an LED (Light Emitting Diode) type test light. Touch the test light probe to each of the outside terminals of the coil pack connector in turn as an assistant cranks the engine over with the starter. See if the test light blinks as the igniter provides the trigger signal to the coil pack. If the test light does not blink, there is a problem with the igniter, crankshaft sensor, ECU or related wiring.
To check the ignition coil's primary resistance, with the ignition off, disconnect the three-terminal connector from the coil. Connect an ohmmeter across terminals 1 and 2. This will test the 1-2 coil pack. Next connect the ohmmeter across terminals 2 and 3. This will test the 3-4 coil pack. The resistance should be between 0.63 and 0.77 ohms.
To check the ignition coil's secondary resistance, connect an ohmmeter between the companion cylinder coil towers. First test cylinder numbers 1 and 2, then cylinders 3 and 4. The resistance should be between 10.4 and 15.6 k-ohms (?)
Richard L. is offline   Reply With Quote
Old 01-13-2002, 06:14 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
brian FYI testing the coil itself will honestly tell ya dick...i have seen coils be bad and test perfect and be firing thru the casing. Do you think you have a bad coil?? i'd be curious. Gimme a ring.
jeremy
Old 05-10-2012, 05:43 PM   #4
nfisheremti
Member#: 69459
2015 2.0 hatch
crystal white
are those resistances good for all scoobie coils? i have a 99 impreza l, with the n/a 2.2 (ej22 i believe). its misfiring on 3 and 4. i noticed they are both fed by the same coil, so i wanted to test this first before throwing money into it.
thanks.
nfisheremti is offline   Reply With Quote
2000 RS: How to unplug the coil pack Rallly2000 Newbies & FAQs 0 03-22-2010 12:58 PM
how to test coils? Terrh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-09-2009 08:22 PM
How to test Coil Packs Subie.Dude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-09-2009 10:12 PM
How To Test Coil Pack WiredWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2004 07:44 PM
Instructions on how to install OEM gauge pack jbogli Electrical & Lighting 2 03-14-2003 12:02 PM
