Old 09-15-2007, 06:40 PM   #1
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Default vf22 ewg 05 wrx tuned and dyno'd today :)
Finally got my car on the dyno today for some fine tuning.
Made 280whp @ 18psi in over 100 degree heat on 91 octane. My tuner told me I will be in the 300whp range come winter. Will post a dyno sheet tonight if I can.
Mods are as follows:
2005 WRX @ 49k miles
TGV deletes
IHI vf22 turbo with thermotec wrapped exhaust side
Tial 38mm external wastegate venting to atmosphere
Tsudo catless downpipe
Greddy Evo2
Turbo XS uppipe
STi tmic with SPT heatshield
Perrin silicone turbo inlet
Perrin silicone intake charge pipe
COBB short ram intake with SPT heatshield
STi pink injectors
Greddy Profec B Spec II
I think thats all for power mods, but I am sure im forgetting something
---edit---
v8eaterWRX is offline   Reply With Quote
Old 09-15-2007, 07:17 PM   #2
WRblueX_Guy
Member#: 53247
Nice. Do you have any pictures of the Cobb intake with the SPT heatshield?
WRblueX_Guy is offline   Reply With Quote
Old 09-15-2007, 07:55 PM   #3
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Thank you! I have some at home. Ill load one up for ya this evening
Old 09-15-2007, 08:07 PM   #4
1BDREX
Member#: 153047
04 WRX
do meth
1BDREX is offline   Reply With Quote
Old 09-16-2007, 09:46 AM   #5
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
dyno graph?
Edit: just relized that your going to post it later.....
Old 09-16-2007, 09:49 AM   #6
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
How much TQ?
I'm Slow is offline   Reply With Quote
Old 09-16-2007, 11:54 AM   #7
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
sure youll get more power if you keep everything constant and just reduce the temperature. Does AZ get different fuel in the winter like they do up here near NY? I know they switch to oxidized fuel in the winter which negates some of the gain we get from colder air. Although the cold also eliminates heat soak, and thus reduces lag quite a bit
WRXDriftR is offline   Reply With Quote
Old 09-16-2007, 04:28 PM   #8
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Ya we get different gas too, but its not that bad really.
As for the wtq I cannot remember. The only dyno sheet I have right now is the base line when the car got on the dyno before tuning. I believe that it is 269whp/240wtq prior to the tuning. My tuner should be getting me the post tuning dyno sheet soon I hope (they dont have a printer for the dyno )
Old 09-23-2007, 10:56 PM   #9
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
what did your injector duty cycles look like?
clemsonteg is offline   Reply With Quote
Old 09-24-2007, 01:00 AM   #10
slvrwrx04
Member#: 58058
2014 STI Sedan
Satin White Pearl
what are the torque numbers?
slvrwrx04 is offline   Reply With Quote
Old 09-24-2007, 01:56 AM   #11
bstoehr83
Member#: 59698
2004 wrx VF39 w/meth
93 STI 91 MR2
get meth and a fmic
bstoehr83 is offline   Reply With Quote
Old 09-24-2007, 10:59 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
assuming you're not "injector limited," adding oxygen to the fuel will INCREASE potential power output. the highest output fuels in the world have lots of oxygen in them. in any engine, oxygen is always the dearest commodity.
what reduces your ability to make more power in the winter is the fact that winter gas is formulated with a much higher volatility so that it will vaporize in the cold ambient air temps. unfortunately this means it has a higher knock sensitivity.
Old 09-24-2007, 01:11 PM   #13
mattyk04
Member#: 104256
2005 STI
meth ftw. and jealous of your ewg
nice numbers!
-matt
mattyk04 is offline   Reply With Quote
Old 09-24-2007, 01:38 PM   #14
Crazy D
Member#: 35927
02 wrx
Originally Posted by bstoehr83 View Post
get meth and a fmic
I agree with the meth,but fmic with a vf22 personally better to stay tmic.
Crazy D is offline   Reply With Quote
Old 09-26-2007, 06:41 PM   #15
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
^not really, with the heat that car will see in AZ....the car is better off with the fmic imo
Old 10-01-2007, 02:18 PM   #16
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
so, I guess these #'s look ok to you guys? Ithought they were really low
Old 10-01-2007, 04:42 PM   #17
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
I made 275whp and 296wtq on my setup
vf22
txs tbe
txs fmic
txs uppipe
enginuity tune at 19psi
coolingmist water injection
txs sri
I would say the OP's numbers are on par, there maybe some more left on the table for him, there definitely is for me, but Im not about having the highest possible hp, but having a smooth power curve and good driveability
Old 10-01-2007, 04:44 PM   #18
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
double post
Old 10-02-2007, 02:23 AM   #19
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
added the baseline dyno chart.
my tuner still hasnt sent me my final
Old 10-02-2007, 02:39 AM   #20
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
some pretty respectable nice numbers there man, congrats! +1 on the vf-22
i want one for my 2.5 =] i wonder what she'd do on a 2.5 with a fmic meth and 20 psi =]
sexyyrex is offline   Reply With Quote
Old 10-02-2007, 02:53 AM   #21
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
That was my baseline prior to tuning. You gotta remember this was well over 100 degrees during my tune. 280whp at over 100 degrees at only 18psi is pretty good on a vf22 if you ask me.....
05 wrx wagon and 05 wrx sti 05yoshi Transmission (AT/MT) & Driveline 2 09-08-2008 02:36 AM
WTT 04/05 sti wing and trunk for 04/05 wrx wing and trunk plus cash (WRB) impreza_wrx_2003 Private 'Wanted' Classifieds 0 08-04-2006 03:30 PM
Want to buy front and rear sway bar for 05 wrx, front and rear end links for 05 wrx mrtrex Private 'Wanted' Classifieds 3 08-26-2005 09:25 AM
so cal: 05 wrx turbo and Sti Ic,vf22 P&P and more sil&duckswrx&legacy Private 'For Sale' Classifieds 56 03-21-2005 02:53 PM
Need sum help getting my 05 wrx tuned right Suba_Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-24-2005 11:55 PM
