#1 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Was breaking the motor in untuned (runned rich across the map) and the new motor seems to be monster in the making.
13.6 @ 100 @ 11 psi 13.4 @ 102 @ 13 psi 13.1 @ 105 @ 14 psi. Then I ate 1st gear. haha The motor in question is Phase 1 block 2.5 pinned cylinders 100 mm Mahle pistons Stock STI crank and rods 820 cc injectors, modded STI sidefeeds Twin turbo DOHC heads and intake manifold Using a PerfectPower6 piggyback on the stock 1990 NA ECU.
#2 |
Member#: 56203
Vehicle:00 RSTI Coupe |
isnt running rich to break a motor a bad thing to do?
any idea on CR? |
#3 |
Member#: 64673
NWIC
Safe rich, not black smoke rich.
Compression should be 8.2-1 or somewhere close. |
