Old 09-16-2007, 11:54 AM   #1
puffer
Member#: 152437
Default potential oil leak
after oil change I was ready to put back the bottom cover then I noticed oily areas on the engine block near the bottom of the coolant spillover tank. Upon closer examination I found that the oil slowly drips through the spongy gasket under the black cover attached to the engine block (timing belt cover?).
My car does not seem to have excessive oil consumtion, but dripping oil worries me. Can you guys comment is this a serious issue. Here is a couple of pictures I took today.
this is the cover from above
puffer is offline   Reply With Quote
Old 09-16-2007, 09:35 PM   #2
Ironmansixx
Member#: 117003
02 Bugeye
Are you sure its just not oil that missed the oil fill tube and it's running down the side of the block?
Ironmansixx is offline   Reply With Quote
Old 09-16-2007, 10:06 PM   #3
whateverwrx
Member#: 99653
05 WRX
peek inside the t-belt cover and see if the belt is wet. looks like some spillage from a whoopsy pouring it in the last time. but maybe a cam seal? i dont think it would be on top like that if it were a cam seal :S
whateverwrx is offline   Reply With Quote
Old 09-19-2007, 09:09 PM   #4
puffer
Member#: 152437
I'm sure I did not spill oil during a previous oil change, since I always use funnel.
how difficult is to remove t-belt cover? and how to check camshaft seals?I'm thinking the oil comes from the area under the black t-belt cover.
Old 10-27-2007, 09:18 PM   #5
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
did you fix your problem? if so, what did you do?
anthonyrb98 is offline   Reply With Quote
Old 10-28-2007, 09:34 AM   #6
quazimoto
Member#: 70395
Cam seal or oil pump seal maybe
quazimoto is offline   Reply With Quote
HELP with possibly compressor oil leak? TWR3CKS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-04-2010 02:00 PM
Expert advice needed: potential air leak/starting problem bulletSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-20-2009 04:29 PM
Another Potential Vacuum Leak Issue STi.CC. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-13-2008 02:43 PM
Potential Boost leak on my04 nyngbld Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-28-2005 11:32 AM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
