Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 12-05-2007, 08:12 PM   #101
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Two and 4 typically are the cylinders that fail in all EJ engines and some of it has to do with uneven cylinder flow through the intake manifold and some of it due to cylinder cooling. I have done individual cylinder tuning on a couple of customer's cars via 4 egt probes. Typically on an OEM engine the differences don't result in significantly different EGT readings. I think I made changes on the .2 to .5% range so it's hardly worth it. You would be better off having you injectors flow tested and putting the high flow injectors in 2 and 4 and calling it a day.
With ported heads however the cylinder flow discrepancies can be huge. I had one car that needed about 1.5% more fuel in cylinder 2 with the head package he had. If your heads aren't CNC ported then request a cylinder flow chart so you can make and educated decision to invest in EGT probes for individual cylinder tuning.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
95PSI compression tested cyl 4 How long will it hold? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-13-2004 05:33 PM
CEL P0304 - cyl 4 misfire, want people's thoughts edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2004 04:44 PM
How common is it to blow Cyl 4? Lee Chun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-12-2004 09:13 AM
Cyl 4 misfire, no drivability concerns... munkis Normally Aspirated Powertrain 11 03-28-2004 10:48 PM
Cyl 4 misfire only with borla headers munkis Normally Aspirated Powertrain 9 02-17-2004 11:10 PM
