Old 09-16-2007, 08:38 PM   #1
TreyS
Member#: 42478
2004 WRX STi
White/Gold
PWN3D Need advice removing four lower tranny bolts, I can't get to them.
I blew a head gasket and am in the process of removing the engine (04 STi). I have everything removed/ out of the way but the only thing stopping me from pulling the engine is the lower four bell housing bolts. I have tried six ways from sunday to get to them and nothing I have can get the right angle on the bolts.
Any suggestions? Do I have to also remove the front axles to get to the bolts?
Thanks for looking!
Trey
TreyS is offline   Reply With Quote
Old 09-16-2007, 09:04 PM   #2
Skully
Member#: 48990
98 Impreza RS
RBP
remove the axles, that is the easiest way to get to them from under the car.
Skully is offline   Reply With Quote
Old 09-16-2007, 09:58 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You can get to the top 2 bolts from the engine bay, use a racheting 14mm wrench. It's tight but possible. Get to the bottom 2 nuts using a 14mm on a wiggle. You do not need to remove the axles.
mick_the_ginge is offline   Reply With Quote
Old 09-16-2007, 10:02 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you don't have to remove the cv but if laying on your back on the ground, it may make it easier.
Old 09-16-2007, 10:29 PM   #5
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
+2
Also, the top bolts can be removed by putting a long extension on a socket. You end up resting the extension on the CV joint.
Definately need a swivel for the bottom nuts.
SloRice is offline   Reply With Quote
Old 09-17-2007, 06:07 AM   #6
TreyS
Member#: 42478
2004 WRX STi
White/Gold
I did get one of the lower bolts off with a swivel but the other three are still hard to get to. I'll give it a go again tonight and see how it goes.
Noob question....do I need to remove the tranny fluid if I want to remove the front axles. On my old car I had to do this so I am assuming I will.
Thanks again for all the help!
Trey
Old 09-17-2007, 09:45 AM   #7
SloRice
Member#: 44351
2004 Mitsubishi Evo
yup dffsfsdf
p.s. stupid minimum number of characters crap...
Old 09-17-2007, 11:02 AM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
Originally Posted by SloRice View Post
yup dffsfsdf
Really? I never needed to... my tranny had "stubbies" sticking out.
x99percent is offline   Reply With Quote
Old 09-17-2007, 11:21 AM   #9
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
I pulled my motor this weekend i used a swivel and an extension, it took a little fidgeting but it worked.
ec2k1gt is offline   Reply With Quote
Old 09-17-2007, 08:56 PM   #10
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Trey,
Send me a pm if you get stuck or if you just want an extra hand with the swap.
cheers
Mike
LiquidForce is offline   Reply With Quote
Old 09-17-2007, 11:20 PM   #11
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Thanks Mike. I was actually gonna bug you on WRXATL. I appreciate the offer. Coors Light...right?
Old 09-17-2007, 11:37 PM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
Wasn't it a case of Sam Adams for the radiator?
Swapping heads is at least a bottle of Kettle One
Old 09-18-2007, 12:10 AM   #13
SloRice
Member#: 44351
2004 Mitsubishi Evo
Nevermind...it was early when I posted. You are correct.
Old 09-18-2007, 10:15 AM   #14
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Thumbs up
10-4
Can not remove rear lower strut bolts. OutbackGT Brakes, Steering & Suspension 25 01-19-2007 03:13 PM
Need Advice - Removing Window Tint from my STI... BongMonster Tri-State Area Forum 9 11-28-2005 05:31 PM
just sheared off a lower tranny bolt. dang! kharris4 Transmission (AT/MT) & Driveline 0 08-28-2005 06:21 PM
Can't Break Loose the Lower Tranny Bolts F15DOC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-16-2005 06:12 PM
Need help - half shaft inner part spring pin - can't get it to go in - anyone?? alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-30-2001 09:25 AM
