Old 01-13-2002, 09:24 AM   #1
FastRedWrx
Member#: 11773
2002 Imprezza WRX
Sedona Red
Question Another boost gauge install question
I've searched several times but have yet to find a definite answer. Question is, If using the nylon hard line to connect the boost gauge, what type of 'T' fitting is used. I'm having trouble finding out what others are using. Is there some type of T-fitting that has a NPT connections on it? Any help will be greatly appreciated.
FastRedWrx is offline   Reply With Quote
Old 01-14-2002, 09:25 AM   #2
143paul
Member#: 12967
Default I'm haveing same problem
Up
Come on guys lend a hand - Thanks in advance
143paul is offline   Reply With Quote
Old 01-14-2002, 09:48 AM   #3
BullsWRX
Member#: 12097
2003 Ford Mustang GT
Dark Shadow Grey
i got a VDO boost gauge.. and.... if you get the install kit with it.. it has an adapter. screws right onto a normal sized T.... i say normal.. cause i looked forever before figuring out it came witha peice to adapt to it. Theres just no way you'll ever find a T small enough to go in the nylon hose... least i couldnt. if you still need help tonight... I'll take a picture and show you what i did.
BullsWRX is offline   Reply With Quote
Old 01-14-2002, 10:28 AM   #4
Cjchaps
Member#: 3181
07 Rav4
The auto-meter guage I ordered came with connectors for both sides of the vacumm, that screw into regular sized NPT fittings.
Cjchaps is offline   Reply With Quote
Old 01-14-2002, 02:26 PM   #5
STi2001
Member#: 5789
Why can't you find a tee-fitting? I just went to PepBoys and got a tee-fitting variety pack with all sizes, 1/8, 3/16 and the like. I was just wondering what size the stock vacuum hose is, I think it is 1/8 if I am not mistaken b/c I am going to use vacuum hose instead of the hose from the Autometer gauge b/c that nylon tubing will eventually break down/wear out. Thanks for the help.
Koz
STi2001 is offline   Reply With Quote
Old 01-14-2002, 05:52 PM   #6
FastRedWrx
Member#: 11773
2002 Imprezza WRX
Sedona Red
Default Nylon hose
I chose to go with the nylon hose since it is much smaller and therefore seems easier to route through the engine compartment and firewall. I had initally bought 1/4" rubber hose but when I looked at it I thought it to bulky to route to the steering column, maybe I was wrong.
The problem is in my kit I saw the npt adapters, 1 went to the back of the gauge but the other end looks as though it needs to screw into something with npt threads. The problem is finding a tee that has female npt threads so the compression fitting will screw into. I've seen on the web were some used a standard tee (no threads) and ran a short piece of hose from the tee to the nylon hard line and used zip ties to secure it. Not sure if that would work.
Well I went to a local hardware store and I think I found a workable solution. They gave me a plastic tee (1/4") that has 1/4" npt threads on the middle port. I then used a 1/4" to 1/8" coupler. The 1/8" male npt compression fitting that came with the gauge is able to screw into the 1/8" female coupler.
Sounds complex but I think it'll work and be more secure than inserting the hard line into the vacuum hose.
another newb boost gauge install question suzysube Factory 2.0L Turbo Powertrain 4 02-17-2006 01:39 PM
Boost gauge install question ScubieTheFierce Factory 2.0L Turbo Powertrain 5 03-24-2003 05:14 PM
OEM boost gauge install - question WRXVII Service & Maintenance 6 12-08-2002 03:51 PM
Boost gauge install question Tex-WReX Factory 2.0L Turbo Powertrain 15 06-07-2001 12:42 AM
Message Board Statistics All times are GMT -4. The time now is 08:09 PM.
