Old 09-17-2007, 04:43 PM   #1
vnmvx-0
Member#: 49438
03 Snoobie
Default does the ecu learn after protune?
i just got my 03 wrx protuned
it has uppipe/catted downpipe
and made 215awp @ 6000rpms and 204wtq @4750rpms
does the ecu still take a little while to learn the tuning parameters or is it the way it is when it rolls off the dyno?
vnmvx-0 is offline   Reply With Quote
Old 09-17-2007, 05:36 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
depends on the tuner & where he set the initial IAM at.....
testes1010 is offline   Reply With Quote
Old 09-17-2007, 06:24 PM   #3
vnmvx-0
Member#: 49438
03 Snoobie
can you explain what that means?
Old 09-17-2007, 06:32 PM   #4
Not-EWRX
Member#: 158043
2013 Wrx Hatch
IAM(initial advance multiplier) is what the Ecu uses to advance timing and boost and what not. Basically it multiplies everything on the map so it runs at it's optiumum settings. Stock this number sits at like 8 and it learns it's way up to 16<<the happy range. Some tunners can change this so there is no learning so it's allways at 16 after a hard reset. Look up the ecu learning trick. It's real easy to do once you get the hang of it.
Not-EWRX is offline   Reply With Quote
Old 09-17-2007, 06:42 PM   #5
vnmvx-0
Member#: 49438
03 Snoobie
thanks for the info ^ i guess the only way for me to figure out what my ecu is set at is to ask the protuner
Old 09-17-2007, 06:51 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
If you reflash it with the tuned map, it'll start out exactly the way it came off the dyno [unless the tuner made some changes post-dyno] and then it will learn both timing and fuel trims from there as necessary.
flycaster is offline   Reply With Quote
Old 09-17-2007, 08:50 PM   #7
vnmvx-0
Member#: 49438
03 Snoobie
what do you mean "start out"..the car was reflashed with the new map after tuning..but is there still some learning involved?
i heard some people saying to reset the ecu every couple of weeks to erase pulled timing from the memory and then there are the people that say to reset the ecu when weather conditions change drastically and elevation/humidity etc
Old 09-17-2007, 08:56 PM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Well those people are dumb as bricks, the ecu pulls timing from knock and if there is no knock it will add it back in on its own. If it is severe knock and it learns, and then you reset it back into knock territory which will eventually kill your engine.
THE ECU IS CONSTANTLY LEARNING!!! There is no need to reset it EVER unless you fixed an issue that set off a CEL.
Old 09-17-2007, 08:59 PM   #9
supermarkus
Member#: 6971
2008 WRX STi
SSM
I hope you aren't listening to such "people" because erasing your learned timing and fuel trims all the time is a stupid and unnecessary thing to do if your car is properly tuned.
supermarkus is offline   Reply With Quote
Old 09-17-2007, 09:00 PM   #10
supermarkus
Member#: 6971
2008 WRX STi
SSM
exactly. If you have the CEL, fix the issue, don't mask it.
Old 09-17-2007, 09:14 PM   #11
vnmvx-0
Member#: 49438
03 Snoobie
so i guess i will just drive it and leave the ecu alone...thanks for clearing this up
yea i know thats a problem with these boards is there is lots of mixed info..i think one of the users adamantly said that the ecu stops learning after a short period of time and if you are to change weather conditions or elevation you are getting more of a benefit if you reset it prior to those situations and let it learn
the tuner didnt tell me to go out and do some WOT runs or anything so i wonder if im just supposed to drive it normally after the tune or go on some heavy runs to get the ecu to adapt..AHH a little confused
Old 09-17-2007, 09:26 PM   #12
testes1010
Member#: 47145
2012 Gas Saver
Master2192 is 100% correct. The ECU constantly learns, adjusting to different weather conditions, fuel changes, etc. If the ecu has the same intial IAM as stock (which is 8 after a reset), it will learn quicker to 16(assuming the tune is safe) driving aggressively. It will learn slower babying it.
Old 09-18-2007, 12:01 PM   #13
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Just to add a bit more info here, the concept is called hysteresis. Basically, the system makes adjustments based on the history of what the system has seen. When you reset the ECU, it basically hasn't seen anything so any new information has a higher priority than it would otherwise. Of course, it's not an infinite system and can only remember so much and older stuff falls out of relevance so it can always adapt. It just does so slower so it's more stable as time goes on.
Maybe think of it analogous to the way we see the history of the world. It's been around for 4.6 billion years. For around 3 billion years life evolves which diverges into different kingdoms and specialization of those over the next 1 billion. This is all before people were here. Even 500 million years ago, dinosaurs weren't around, but 250 million or so, they died, but 150 million years ago, birds came about. Then just 2 million years ago, apes became "people". Then two thousand years ago, a Jewish carpenter walked around Europe and started the largest religious change the world had seen. Around 500 years ago, some crazy guy decided to sail around the world and ran into America. About a century ago, we invented the car. 30 years ago, a crazy guy named Steve invented the personal computer. 10 years ago, we had the internet revolution. A couple years later, the dot com crash. Then we went to fight in Iraq for the 2nd time, you bought a Subaru, sub-prime mortgages are a problem, you had cereal for breakfast, now you're reading NASIOC.
What does that trip thru the history of the world?(btw, forgive an inaccuracies, I'm not a historian and that's mostly off the top of my head). Look what you remember about today? And this week? And this year? And the last decade? And then the century? Then the millennium? Probably about the same for both, even tho, as you go back, time spans increase exponetially. It's just less important to how you live your daily life the farther you go back.
Man I talk to much.
mrbell is offline   Reply With Quote
Old 09-18-2007, 03:36 PM   #14
vnmvx-0
Member#: 49438
03 Snoobie
Man I talk to much.
wow talk about a tangent, lol
good post to think about, the tuner told me he set the IAM to its highest after the tune
ecu learning after protune k-pac Newbies & FAQs 8 08-10-2009 11:28 AM
Why Does The ECU Dump Fuel In After Shift? williaty Commercial ECU Reflashes 15 12-12-2007 01:15 AM
Is it time to Reset the ECU now after the HKS Full exhaust system starBug Transmission (AT/MT) & Driveline 0 07-26-2004 02:12 PM
What does the computer learn? SuperWRX03 Newbies & FAQs 3 11-24-2002 06:06 PM
How does the ECU learn? WRX_man20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-25-2002 01:25 AM
