#1 | |||
Member#: 84517
SWIC
Vehicle:05' Imprezilia CruiseControl Warrior |
EDIT: Problem has nothing to do with any modifications
Its a sending unit problem and only the sti's are cursed with it Well, When the gas light turns on 10miles later I go in for a fill up, and I'm only able to get 10.987gal. our tanks are 15.9 Its been going on for awhile now, thought i was paranoid. and the gas indicator hand is one bar under the F. So now I know thats not reading incorrectly. I've told the mechanics at the dealership about my problem; there tech line suggested: The float level indicator may be stuck in a higher than normal position. second would have to be a problem with the evap canister reading a wrong value. But no one has gotten back to me yet.. anybody have issues similar to this?(still: 3/08) I gotten 60+miles after the gas light turn on. Oh, and you got about 1mile & some left to go when your gas light indicator starts blinking haha My warranty period is done. but problem started happening way before my warranty was up. would they still cover this? I have 4plus months of gas receipt to prove it. JB http://www.iwsti.com/forums/engine-p...rve-light.html
#2 |
Member#: 147895
Vehicle:04 sti blue |
it sounds like the is most likely a block in the vent tube for the filler neck or the filler tube it self
#3 |
Member#: 82153
Vehicle:2012 WRX Sedan SWP |
I can generally only fill about 11 gallons after my light turns on also...I thought it was normal due to the reserve for mileage after E.
#4 |
Member#: 106318
SWIC
Vehicle:11 Zoom Zoom3 |
Yeah we have massive reserves. Mine will have ~4gals left when the light goes on.
#5 |
Member#: 159508
Vehicle:2005 STi Blue |
Once in a very rare while I actually get a full tank, otherwise it's usually only 7/8ths full.
#6 | |
Member#: 84517
SWIC
okay, I remember easily get 300miles to the tank, driving moderately. And 340 driving really conservative(mostly highway, 65mph / slow acceleration / shifting below 3rpm) . Now barely hitting 248mile to the tank with moderate driving. How about the gas indicator hand?when filled up is one bar before F car is completely stock. new tires, new air filter. Last edited by Jim.mEh; 09-19-2007 at 04:42 AM. |
#7 |
Member#: 106318
SWIC
Could be the Arizona heat. I know my car will barely hit 200 before its hovering above E.
Take it back to the dealership or try a different one and see what they say. |
#8 |
Member#: 91423
HIIC
Vehicle:2004 PSM STi on Meth Tuned by Chris Black@AMS |
i also have the same problem. i recently bought a 04sti about 5mths ago and filling up was no prob. now i recently added a turbo back, headers, intake, and got aprotune. after the tune i'm not able to get a full tank as well. only 7/8's as the OP said. prior to the tune, never had any problems. it sucks living in hawaii and gas prices for super here is anywhere from $3.52 to $3.70.
#9 |
Member#: 84517
SWIC
I went to another dealership yesterday.
Service manager said a couple of cars within the past month or so came in and have same problems. only seems like the STi's.. unless the WRX owners are just to careless to notice.. 05' 07' and now yours 04' STi's. Could heat be a factor? its not hot in HAWAII this time of year? We hit above 103degrees everyday. |
#10 |
Member#: 146722
second would have to be a problem with the evap canister reading a wrong value. there is two sensors/floatlevels indicators inside the tank i did replace them on my 05 sti and a problem went away |
#11 |
Member#: 159720
South East
Vehicle:2005 WRX STi OBSIDIAN BLACK PEARL |
Yeah, Whats Up With That? I Just Bought An 05 Sti 10 Days Ago, And Noticed The Same Problem. I Thought I Was Crazy. What Do I Do?
#12 |
Member#: 69241
Vehicle:04 WRX STI Silver |
I also have this problem with my 04 STI. I can only fill up to 3/4 a tank and get around 200 miles until the light turns on. I've had my car into one dealership who placed a faulty sensor in the tank. That did not fix it and the dealership cant figure it out. I am now going to another dealership in Orlando to see if they can fix it.
There are many things that can cause this I am told. -Jared 04 STI Now Cobb Stage 1 |
#13 | |
Member#: 84517
SWIC
So how much are these parts? What is the actual part numbers/ or names of these parts? Did you replace them yourself? How did you do it? how did you go about drain your gas tank safely? We'll need details please!! So yeah, the GAS LIGHT has been on, Ive been drive 40+ miles now. I have a extra container of gas in my trunk. Im hoping that maybe when I drive it to empty, some miracle will happen, that when i fill her back up everything will be fine.. |
#14 |
Member#: 146722
i see if i can get the part #'s tommorow
you dont have to drain the tank |
#15 |
Member#: 112167
South East
Vehicle:2004 WRX STi WRB |
I would like to know this too I just picked up an 04 STi in Tampa that has this same weird issue. I had an 04 before this and when the gas pump would click I could normally get another 2 gallons in the tank if I went slightly slower the rest of the way and thought that this 04 was the same way and that was causing it...well tried and guess what...nope...lol I only got about half a gallon more in before I could tell it was really full and didn't want anymore (no I did not overflow it onto the ground) after owning numerous STi's I have learned little tricks to tell if its full or not yet mainly thanks to that other 04 I had that was weird at the pumps.
#16 |
Member#: 91423
HIIC
#17 |
Member#: 83054
Vehicle:'11 SWP STI |
Mine has done this since day 1. It used to be intermittent now it's all the time. Fill it up. I get 3/4 of a tank. Drive for 10-15 miles. then it's up to full or close to it. My dealer is too stupid to know how to fix it so I said screw it and I just deal with it.
#18 |
Member#: 159745
South East
Vehicle:2007 drunkman tuned mega meth |
I can usually get about 400 miles to my tank highway driving and like 280-320 in city slight agressive driving and i live in south alabama where its hela humid and hot. I dont see how the heat would affect it too much.
#19 |
Member#: 92588
Vehicle:2005 STi Silver |
At the pump when filling up does it 'click' and shut off the fuel at the pump?
The click has nothing to do with the float sensor... it is the pressure that is in the tank that shuts off the fuel input, not the float sensor. - I had the same problem where I would 'fill up' and it would only bring my gauge to about 1/2 full. But if I drove the est 290 miles I get on a tank the gas gauge would be below E and throw a P0462 (463?) fuel sensor out of spec error. |
#20 |
Member#: 92588
For the part number... call you dealer and they will ask for the VIN of the car and they can look it up. There are two different part# for the same thing... its based on what they lookup with your VIN.
#21 |
Member#: 84517
SWIC
maybe we will get RECALL?
can anyone wisper sweet nothings to a Subaru of America reps for this? |
#22 |
Member#: 71718
W. Canada
Vehicle:07 STI LTD SWP |
Another 07 STI with the same problem... but I just go off my odometer now and my perceived level of "spirited driving" per tank.
My gauge usually goes in cycles of being retarded for a few months, then normal for another few months. Right now, the reserve light comes on and I can only get ~11 gallons in the tank. So, I just base it off miles and I know that at ~240 miles, I'm ready for a fill. |
#23 |
Member#: 112167
South East
Any idea how much the sending unit cost?
#24 |
Member#: 92588
#25 | |
Member#: 18308
NWIC
Vehicle:2005 WRX STi Silver |
Recalls are only for safety issues. A bad fuel gauge sender would be a TSB, not a recall. And there has to be a large enough percentage of them to warrant the TSB, not just a couple of cars. That’s just standard warranty coverage territory. |
| Thread Tools | |
| Display Modes | |
| Need to get a full tank out of my car in a day..... | lavid2002 | Newbies & FAQs | 22 | 12-18-2009 04:41 AM |
| How many MPG and not able to get a full tank | leeswrx | Factory 2.5L Turbo Powertrain | 24 | 12-21-2007 03:53 PM |
| anybody else not able to get on flscc.com? | wako29 | South East Region Forum | 7 | 12-19-2003 01:41 PM |
| Anyone have problems w/ not being able to get into gear when the car is cold? | GTBGUY | Normally Aspirated Powertrain | 27 | 12-21-2000 10:43 AM |
