09-17-2007, 09:49 PM | #1 |
Member Sales Rating: (16)
Member#: 22879
Complete JDM Sti version 8 engine/trans/suspension/brakes P.O.
Update-Parts are now for sale!
Hi all, time has come to get serious about parting out my car. PLEASE READ ALL OF THIS BEFORE REPLYING OR POSTING! If there's enough interest in parting out the engine and transmission kit, then i'll do that, but they must be paid for or deposits inplace before doing so. So here's the terms and condtions of the partout on my end: Parts must be paid in full before i'll send. I will part out the engine and transmission kits *BUT* Most of the items must be spoken and paid for before turning a wrench on them especially the engine. All parts will be professionally taken apart and packaged properly. I'm doing this to make sure i don't have a bunch of parts on my hands from non serious buyers wasting my time. If you don't like the terms, then please don't buy my stuff. Also, if you're in a huge hurry to get the parts, then again, please go somewhere else! It will take several weeks to get the car torn down, parts pulled apart, boxed and then shipped. Not to mention a ton of time replying to people and getting deals finalized, so again, if you're in a hurry, impatient or the whinner type please don't waste both of our time. So here's what i have: 1996 subaru legacy sedan with FULL 2003 JDM STi version 8 swap By full, i mean full! Car is NOT WRECKED! This is the NON RA sti engine. All parts have less than 12k miles on them total (9k from me, 3k when new). Engine- JDM STi version 8 with: 2.0 block-semi closed deck-forged crank, rods, hyper cast pistons AVCS big port heads Tumbler vale LESS intake manifold Sti tmic with forged BOV red silcone intake hose(s) Matching jdm sti ecm VF37 Twinscroll turbo system with gutted downpipe-this is all stock All related sensors, engine harness, heat sheilds-Basically a complete engine as it came from japan with no mods. This engine makes 355whp at sealevel on a mustang dyno on only 19psi with race gas brew. Redlines at *8K RPM (355 with utec, 19 psi, free flowing exhaust-must have utec which is NOT included to get to these numbers which could vary) Complete engine with everything above including matching ecm Newest price 5k NEW PRICE 5500.00- 5999.00 Without turbo system, Intercooler, jdm pink injectors 4100. *If* i decide to part out beyond this, then prices will be listed then. I will give serious consideration to doing a complete engine part out if i can get the heads, intake manifold and the twinscroll kit spoken and paid for. Prices on this stuff: Heads 2200. Intake manifold w/o injectors, but complete otherwise-550 One piece design twinscroll kit with brand new gasket kit 1800. 6 Speed conversion kit: All parts are jdm 6 speed parts and NOT 5 speed stuff Includes following in the kit: 6 speed transmission dccd model NO electronic controller to make dccd work! startor clutch, pressure plate, flywheel shifter assembly-i think this is the sti short shifter, but not a 100% sure R180-viscous type, not the loud and clunky gear one axles front and back x4 Hubs front and back x4 ebrake cables Compete rear subframe assemble including-subframe with sti mounts, lateral links, transverse links, sway bar, end links Rear brembos-minor chips in paint-only cosmetic What's not included or available-main driveshaft or dccd controller. Completet kit 5000.00 New price 4800 Newest price 4600 Without rear brembos 4600 Transmission alone 3200 Suspension: Jdm sti take offs: These are suposed to be 15% stiffer than the usdm sti and i would agree with that! Top hats, black springs (not pinks or aftermarket) red sti struts, front are inverted, camber bolts/nuts- New price 495. 550.00 *sold*Aluminum front A arms x2 200.00 Brakes Front brembos complete with calipors, pads, rotors (pads are good and rotors only have minimal signs or wear) 1000.00 New price 900.00 Newest price 795. Rear brembos are a part of the trans kit, but will be for sale if the buyer doesn't want/need them. Will be complete as above-500 Electrical 2002 wrx harness. Stripped of all but the engine stuff needed to make engine run. Avcs wires added. This is the bulkhead, rear car harness to fue tank and engine compartment up to the engine. The engine harness IS NOT a part of this. Price will depend on what all you want with this harness. Stuff like the fuel pump controller, relays, and stuff of the sort. 02 wrx maf 150 02 wrx boost controller- 75 03 jdm sti ecu-this is part of the engine kit, but could be available if buyer doen't want it Misc. parts: 02 wrx cluster with under 20k miles on it. Face plastic not included! You can take your cluster apart and use your plastics with it very easily. 100.00 03 jdm sti Front crossmember without rack or sway bar-X member only 150. with 93 turbo legacy steering rack add 50 with sway bar add 25. 02 wrx stock air box with k and n filter NO mods to air box ( air box only, no snorkis or other stuff) Aftermarket stuff: jdm/aus spec utec with switch-like new condition with everything that it came with including user guide and box! Will work on 02-05 wrx For other applications please call turbo xs and ask them if it will work with your car as i don't know. New price 675 775. Turbo XS Tuner pro-brand spankin new-never used! With vw sensor and everything that it ever came with 450. Car body parts are not for sale currently. All prices are part prices and do not include shipping! With stuff that i will have to pallet, crate or take a long time to box there will be a charge for that, but it will be small and reasonable. Pictures might be hard depending on what you want to see as the car is still 100% intact. Payment has to be made in full before anything gets shipped. I will put this on ebay if you're the untrusting type and need that kind of security, but it will cost you more. Everything of course is open to offers, but please be reasonable or don't expect a reply. Payments can be made in cash, paypal and certified money orders; no personal checks. If paying through paypal, then you must be verified and i will only shipp to that address. Also, please add 3% to total price if using paypal for their fees. Thanks Brent [email protected] or PM me
09-17-2007, 10:05 PM | #2 |
Member#: 22879
General Photos can be seen here until 9/20/07
http://new.photos.yahoo.com/brent2401/ |
09-18-2007, 12:54 AM | #4 |
Member Sales Rating: (3)
Member#: 110115
BAIC
Vehicle:2005 FXT |
i'll take those a arms, if I'm still looking for a set once you decide to part out.
let me know when you've decided what you're gonna do. thanks brandon |
09-21-2007, 02:20 AM | #6 |
Member#: 22879
Bump to the top and some new lower prices on some stuff. Car is apart and most stuff will be ready to ship by friday or at the latest early next week. Parts are open to offers as well.
Thanks Brent |
JDM STi Version 8 Engine 1 in Stock | JDMspecC | Engine/Power/Exhaust | 44 | 11-11-2009 01:38 PM |
JDM STi Version 8 Engine 4200$ + Shipping ! | JDMspecC | Engine/Power/Exhaust | 21 | 07-30-2009 03:14 AM |
!!! JDM STi Version 8 Engine !!! 4200$ Unbeatable Price ! | JDMspecC | Engine/Power/Exhaust | 10 | 02-26-2009 07:09 AM |
Jdm sti version 8 heads for sale,sti 820cc injectors | superflysteiny | Private 'For Sale' Classifieds | 7 | 10-14-2004 06:56 PM |
eBay: JDM STi Version 8 suspension...great condition. | MK2TMR2 | Private 'For Sale' Classifieds | 2 | 10-01-2003 06:18 PM |
