Old 09-17-2007, 10:47 PM   #1
325boi
Member#: 140629
06 STI
Default tranny and lsd oil question
im going to do change my tranny oil, i have been searching and the best meens to be motul gear 300 and use subaru lsd for the diff. this is correct right? also im a bit confused.... is it called just motul 300 or motul 300 75w-90 or something else.....?
is it in here... going to buy it at a local speed shop but just want to make sure i get the right one...
http://www.motorspotstore.com/gearboxfluids.html
i have a 04 sti
325boi is offline   Reply With Quote
Old 09-17-2007, 10:57 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
'Gear 300' is the full synth, afaik it's only available in a single viscosity range so you can't get the wrong one
'Motylgear 75W-90' is semi-synth
UkNuck is offline   Reply With Quote
Old 09-17-2007, 11:10 PM   #3
ryanwrxduksa
Member#: 114031
can you let us know how you like it?
ryanwrxduksa is offline   Reply With Quote
Old 09-17-2007, 11:38 PM   #4
325boi
Member#: 140629
06 STI
^ sure... i got the car with 9k on it and it would shift like butter, now has 30k and have track it a few time. shifthing is not bad but not like when i frist got it. will let you guys know what i think about it.....
so which one should i get.... gear 300 or motygear 75W-90.....?
edit: that link that is say that gear 300 is Semi-Synthetic and motygear is full syn....
Old 09-18-2007, 07:45 AM   #5
bluesubie
Member#: 767
04 FXT
It's wrong. Click on the link for technical information to open the pdf.
http://www.motorspot.com/Gear_300_Auto_3178_(GB).pdf
-Dennis
Old 09-18-2007, 12:37 PM   #6
325boi
Member#: 140629
06 STI
^ thanks.....
Old 09-18-2007, 12:40 PM   #7
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
man I opened this thread thinking something else.
if you had a 5spd I would say try scotties cocktail, but nevermind.
Sorry don't know much on the STi trannies. I need to learn considering im going to be putting one in.
darksc00by is offline   Reply With Quote
Old 09-18-2007, 08:32 PM   #8
325boi
Member#: 140629
06 STI
whent to the local subaru dealer right now and they told me that they dont carry lsd diff oil. were can i find it? or is there something tha is the same thing?
Old 09-18-2007, 09:21 PM   #9
bluesubie
Member#: 767
04 FXT
If you want to use Motul, use the 90 PA Limited-Slip Differential for an STi. It's a conventional diff oil, but you probably won't notice the difference anyway.
-Dennis
Old 09-19-2007, 02:26 AM   #10
325boi
Member#: 140629
06 STI
i was by super autobacs and got 5 qt. motul 300 for 75 bucks..... i will put in tomorrow and let you guys know what i think.... also still looking for real diff. oil. do i have to change the the tranfer case oil..?
Old 09-19-2007, 09:13 AM   #11
bluesubie
Member#: 767
04 FXT
The oil that I posted above is a Motul oil for the rear diff and it's real.
-Dennis
Old 09-19-2007, 10:59 AM   #12
vinithing
Member#: 59414
05 STi
Just got Motul 300 in the tranny. It's AWESOME!
vinithing is offline   Reply With Quote
Old 09-19-2007, 11:08 PM   #13
325boi
Member#: 140629
06 STI
did the tranny oil change today and i didnt see any difference from what my tranny felt before i did the change..... also only 3 full qt. whent in fine and only 3/4 of the 4th qt whent in. it also whent pass the full line.
question: should i take some out or will it be fine? thanks
Old 09-20-2007, 09:03 AM   #14
bluesubie
Member#: 767
04 FXT
I would take some out. In my experience, too much fluid caused the synchro action to be slower. Try to get something to remove it from the filler tube so it won't be as messy. I used a bottle pump (an idea I got from scoobymods for filling the rear diff) connected to a long plastic tube.
I used Gear 300 and thought it was ok, but not as good as I expected.
-Dennis
Old 09-20-2007, 11:16 AM   #15
325boi
Member#: 140629
06 STI
^ ya same here maybe i expected to much....? ill take some out right now
lsd oil question young j Service & Maintenance 1 05-06-2008 08:05 PM
Help me find Motul fluids for STi tranny and LSD AlxSti Transmission (AT/MT) & Driveline 15 03-04-2007 04:12 PM
tranny and diff oil change info needed subliminal Transmission (AT/MT) & Driveline 3 01-20-2004 11:15 AM
How much oil to I need to purchase to change my WRX tranny and diff oil? kenshiro Transmission (AT/MT) & Driveline 6 03-13-2003 05:51 PM
Immediate help needed: '00 RS Tranny and LSD with axles on '99 OBS? Geoff Normally Aspirated Powertrain 22 11-22-2000 06:43 PM
