Old 09-18-2007, 01:33 PM   #1
mmaster
Member#: 127681
2006 VF 39'd Wag
Default Newb Questions: Advice, Sway bars or Struts???
Here it is folks, as new as it gets:
What would make the most drastic handling improvement...Sway bars or Struts (not strut tower bar, just regular struts)
Need advice...
mmaster is offline   Reply With Quote
Old 09-18-2007, 03:25 PM   #2
Homerisking
Member#: 79164
2005 WRX
tHe Silver one
Front and rear sways is a nice start...but just changing out the stock tires and a nice alignment makes of world of difference on these cars. Strut bars depending on who you ask make little difference...however you have a wagon so the rear may add some noticeable difference. Wagon owners should chime in with this statement.
Homerisking is offline   Reply With Quote
Old 09-18-2007, 03:57 PM   #3
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
^ he meant sturts/shocks...
I'd also consider lowering springs, like Prodrive...
rexman2002 is offline   Reply With Quote
Old 09-18-2007, 04:48 PM   #4
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
swaybars my friend. they = night and day difference... and yes, you WILL notice a HUGE difference. It will completely change the way you drive your car. I'm not joking. by far.. the most noticeable mod I have done. I cannot tell you how many times I said "Oh my god" when driving the car right after i put the swaybars on.
--J
TheSilverFox is offline   Reply With Quote
Old 09-18-2007, 04:51 PM   #5
mmaster
Member#: 127681
2006 VF 39'd Wag
Thanks guys...much appreciated. I picked up some wagon specific eibach's but the body roll in the car is unbelieveable. Don't get me wrong, the springs helped significantly...maybe the swaybar concept is the way to go...Any recommendations?
Old 09-18-2007, 04:54 PM   #6
mmaster
Member#: 127681
2006 VF 39'd Wag
I meant recommendations in regards to specific companies (ie cusco, perrin...etc....)
Old 09-18-2007, 06:16 PM   #7
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
Impreza WRX STi
um... the most popular brands the scoob community utilize are COBB, WHITELINE, and CUSCO. Check your local classifieds for used ones.. b/c it's just a damn piece of metal, so no need to purchased new ones when you get get used ones for cheap. but BOY... do they make a huge difference.
--J
Old 09-18-2007, 06:17 PM   #8
mmaster
Member#: 127681
2006 VF 39'd Wag
Well said on the used concept, I just may head that route. Thanks for the knowledge bombs!
Old 09-18-2007, 06:17 PM   #9
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Whiteline swaybars is the way to go. 24mm in the rear and 22mm in the front for a daily driver.
Rudywrx04 is offline   Reply With Quote
Old 09-18-2007, 07:21 PM   #10
mmaster
Member#: 127681
2006 VF 39'd Wag
24mm across the board or am I looking for something "wagon specific" I imagine??
Old 09-18-2007, 09:50 PM   #11
575rider
Member#: 112024
03 WRX vf34 wagon
6 spd, track & dd duty
get the sedan eibach prokits, the car is a little lower than the wagon ones. I put springs and sways on at the same time, totally different car. Upper rear strut tower can definitely be felt with the wagon. I had the springs, sways, rear end links, cusco lower H brace and upper front cusco along with a -1.2 degree camber up front and I still really felt the difference when I added the rear strut.
575rider is offline   Reply With Quote
Old 09-18-2007, 10:19 PM   #12
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
Setup-wise, you could go with identical sizes between the sedans and wagons. However, you need a wagon specific front swaybar and wagon specific endlinks to make it work, since we've got a narrower track up front.
flyboymike is offline   Reply With Quote
Old 09-19-2007, 08:40 AM   #13
96accord
Member#: 145105
2007 WRB WRX Limited
I was thinking about that setup with Kartboy Endlinks....
What do you think about 24mm/24mm
96accord is offline   Reply With Quote
sway bars or strut bars? mtnbikeracer Brakes, Steering & Suspension 5 01-25-2005 05:59 PM
sway bar or strut bar? streko Brakes, Steering & Suspension 2 06-02-2004 07:01 PM
Rear Sway Bar or Strut Tower Jesse Lorenzen Brakes, Steering & Suspension 6 02-04-2002 01:06 PM
Sway Bar or Strut Tower? Viv Brakes, Steering & Suspension 7 08-15-2001 09:53 PM
rear sway bar or rear strut tower bar? Impreza25RS Brakes, Steering & Suspension 11 04-29-2001 12:55 AM
Message Board Statistics All times are GMT -4. The time now is 07:39 AM.
