Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-18-2007, 05:18 PM   #1
cliff257
Member#: 105655
04 STi
07 spec B
Default advanced multiplier??
i have an ecutek easy ecu for the 04 sti why would my advanced multiplier stay at .88. after resetting the ecu and driving a while it will go back to 1.00 but after i get on it, it goes to .88. ????
cliff257 is offline   Reply With Quote
Old 09-18-2007, 05:49 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
If the engine is pinging (knocking) enough over a broad rev range, it will lower the advance multiplier to run less timing everywhere to stop the pinging.
Airboy is offline   Reply With Quote
Old 09-18-2007, 06:37 PM   #3
cliff257
Member#: 105655
04 STi
07 spec B
figure as much but wasnt sure.
Old 09-18-2007, 07:32 PM   #4
bboylocob
Member#: 151809
2007 WRX
how is yours set to read the iam? i.e 1-16 or 0.01-1.00?
bboylocob is offline   Reply With Quote
Old 09-18-2007, 08:15 PM   #5
cliff257
Member#: 105655
04 STi
07 spec B
.01-1.00 not sure why but its not doing it anymore. ive done about 10 3-4-5 pulls and no problems. no exactly sure what to look for in the logs but i did notice the .88 and not 1.00 earlier. also airboy about what you said what should my knock correction be?
Old 09-18-2007, 11:58 PM   #6
bboylocob
Member#: 151809
2007 WRX
knock correction should be consistant at 6 if im not mistaken
Old 09-19-2007, 12:14 AM   #7
testes1010
Member#: 47145
2012 Gas Saver
NO! it depends entirely on the tuner. There is no common value, hell the values may not be constant, it totally depends on the tuner.
testes1010 is offline   Reply With Quote
Old 09-19-2007, 12:20 AM   #8
bboylocob
Member#: 151809
2007 WRX
thanks for clearing it up.
most that i have seen and the tune i have kc stayed at 6. but like testes1010 stated it all depends on the tuner.
Per johnnytran's request...Dynamic Advance & Dynamic Advance Multiplier Explained Christian. Rocky Mountains Impreza Club Forum -- RMIC 121 10-01-2005 09:05 AM
Ignition Advance Multiplier question gpatmac Engine Management & Tuning 50 02-28-2004 12:00 PM
Just did the Shiv advance multiplier reset thingy... Camperguy New England Impreza Club Forum -- NESIC 8 07-20-2003 08:53 PM
deltadash no show advance multiplier? Equilibrium Tuning Engine Management & Tuning 12 07-14-2003 10:04 PM
Ecutek users... what's your advance multiplier? Equilibrium Tuning Engine Management & Tuning 7 06-28-2003 06:06 PM
