Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 09-18-2007, 07:56 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Awesome Deals-Clutches-Flywheels-Exedy-ACT-Cusco LSD-Short Shifter-Bushings From $20
Time for some super Drivetrain deals! Dont miss out on these super awesome clutch/ flywheel deals guaranteed to sell out!
Also now available Gruppe-S Shifter Bushings! Cusco LSD from $899 Shipped Best deals anywhere!
Choose a Flywheel...
Pair with one of the following clutches.
EXEDY STAGE 1 + Flywheel
-Torque Capacity Increase 44%
-Clamp Load (lb): 2300
-287 wheel ft-lb torque capacity WRX
-321 wheel ft-lb torque capacity STi
-Light pedal feel, mild engagement
-Recommended for Stage 1-2 applications (Stock Turbo)
WRX 02-05
Combo w/
-Gruppe-S Flywheel $549 Shipped!!!
-ACT Flywheel $599 Shipped!!
WRX 06-07
Combo w/
-ACT Flywheel $649 Shipped!!!
STi 04-07
Combo w/
-Gruppe-S Flywheel $565 Shipped!!!
EXEDY STAGE 2 (3 PUCK) + Flywheel
-Torque Capacity Increase: 96%
-Clamp Load (lb): 3010
-326 wheel ft-lb torque capacity WRX
-364 wheel ft-lb torque capacity STi
-Light pedal feel, crisp engagement-
-Sprung Hub, slight chatter
-Recommended for Big Turbo up to GT30R
WRX 02-05
Combo w/
-Gruppe-S Flywheel $625 Shipped!!!
-ACT Flywheel $675 Shipped!!
WRX 06-07
Combo w/ -ACT Flywheel $749 Shipped!!!
STi 04-07
Combo w/
-Gruppe-S Flywheel $640 Shipped!!!
-ACT Flywheel $725 Shipped!!!
ACT Street Clutch + Flywheel
-Clamp Load Increase WRX 32%
-Clamp Load Increase STi 40%
-420 flywheel ft-lb torque capacity WRX
-515 flywheel ft-lb torque capacity STi
-Aggressive pedal feel, retains streetability
WRX 02-05
Combo w/
-Gruppe-S Flywheel
$599 Shipped!!!
WRX 06-07
Combo w/
STi 04-07
Combo w/
-Gruppe-S Flywheel
$649 Shipped!!!
CUSCO TWIN PLATE
-Recommend for Big Turbo Applications
-430 wheel ft-lb torque capacity
-Includes Flywheel, twin disc, pressure plate
-Light pedal feel, smooth engagement,
-Very Low Price
$1199 Shipped!!!
EXEDY TWIN PLATE (6MT available)
-Recommended for BIG POWER CARS GT35R+
-Very Low Price
PM FOR PRICE!!!
STi Group-N Mounts
The STI "Group-N" Mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine
Group-N Engine Mounts $95 shipped
Group-N Pitch Mount $45 shipped
Group-N Tranny Mount $69 shipped
Group-N Engine/ Tranny/ Pitch Mount Combo $199 shipped
Kartboy/ Gruppe-S Short Shifter Combos
These components replace the stock shift lever and shifter mount bushings in the WRX, STi, Outback Sport, Legacy and Forester. Overall shift throw is decreased by 40% while also eliminating excessive play in the system for a more solid gearchange. This provides a noticable difference and a solid feel. Constructed of CNC'd and TIG welded 4130 Cr-Mo steel. Gruppe-S shifter Bushings are 95A durometer polyurethane. Installs with simple mechanic's tools in under 30 minutes. Made in USA.
Kartboy/ Gruppe-S WRX SS Combo $99 shipped
Kartboy/ Gruppe-S STi SS Combo $150 shipped
Gruppe-S Shifter Bushings WRX $20 shipped
Kartboy Shifter Bushings WRX $30 shipped
Gruppe-S Shifter Bushings STi $20 shipped
Kartboy Shifter Bushings STi $32 shipped
Kartboy Rear Shifter Bushing $35 shipped
Cusco LSD
The Cusco limited slip differential is designed to provide maximum traction that is most often lost in hard off-the-line acceleration, these L.S.D. kits are designed to integrate with your factory transmission. The unit will sense when one wheel starts losing traction due to track/road conditions, hard cornering, and/or torque steer. Once it detects the slippage, it will compensate by shuffling the power from side to side to overcome the loss of traction. This translates into better track or quarter mile times, and more efficient use of the engines power.
With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower.
* One way L.S.D.
Specially suited for front wheel drive cars and 4WD car front axles. Activates under acceleration, and acts as a true LSD when the throttle is off. A great chance for improved lap times. A CUSCO original design.
* 1.5 way LSD
Activates under acceleration while the understeer is less than on the 2 way LSD.Recommended for drivers having difficulty with 2 way LSD understeer and one way LSD braking.
* Two way LSD
Recommended on the rear axle for rear drive cars. Activates on both acceleration and deceleration. Recommended for those who prefer hot driving action and big angle drift.
Cusco Type RS LSD - Front - 02+ WRX 1.5 Way
$899 shipped
Cusco Type RS LSD - Rear - 02+ WRX 1.5 Way
$899 shipped
Cusco Type RS LSD - Front - 04+ STi 1.5 Way
$899 shipped
Cusco Type RS LSD - Rear - 04+ STi 1.5 Way
$899 shipped
Cusco Type RS LSD - Center - 04+ STi 2 Way
$999 shipped
CLICK HERE FOR DRIVETRAIN SPECIALS -- UPDATED DAILY
Call in to order!
We accept Visa, Mastercard, and paypal.
[email protected], please specify vehicle, part, and your info.
Thanks,
Gruppe-S Sales
www.gruppe-s.com
20521 Teresita Way
Lake Forest, CA 92630
949-457-1234 x 2
Gruppe-S is offline
Old 09-18-2007, 09:59 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey Guys some more awesome drivetrain stuff.
Carbonetic LSD
The CARBONETIC LSD (Limited Slip Differential) responds to the demands of the novice or the professional driver seeking the most dependable control when competing in road racing, time attack, drifting competition or a rally event.
A vehicle’s kinetic performance is largely determined by the potential of the selected LSD. CARBONETIC release the Carbon LSD and the Metal LSD. Those LSD have different character. Quiet operation makes this unit excellent for street use.
Carbonetic Carbon LSD - Front - 02+ WRX 1.5 Way $1225 Shipped
Carbonetic Carbon LSD - Rear - 02+ WRX 1.5 Way $1233 Shipped
Carbonetic Carbon LSD - Rear - 02+ WRX 2 Way $1233 Shipped
Carbonetic Carbon LSD - Front - 04+ STi 1.5 Way $1225 Shipped
Carbonetic Carbon LSD - Rear - 04+ STi 1.5 Way $1233 Shipped
Carbonetic Carbon LSD - Rear - 04+ STi 2 Way $1233 Shipped
ATS CARBON CLUTCH KITS
Introducing the ultra-high performance carbon clutch from ATS. The carbon clutch features a twin or triple carbon clutch that is capable of supporting applications up to 650HP. The Carbon clutch features smoother engagement, better heat resistance for increased durability, and superior power transfer over that of standard clutches. This clutch kit is also lighter than the stock clutch reducing rotational mass, and is an excellent drag-race / road race clutch.
ATS Twin Carbon Clutch/Flywheel Kit - 02-05 WRX
-1350kg (2970 lbs)
$1989 Shipped
ATS Twin Carbon Clutch/Flywheel Kit - 04+ STi
-1350kg (2970 lbs)
$1999 Shipped
Gruppe-S is offline
Old 09-19-2007, 10:29 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 09-20-2007, 01:58 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 09-21-2007, 08:42 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 09-24-2007, 03:58 AM   #6
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
do you have any rear differential upgrades? I still have an r160 and the spider gear keeps breaking.
ilivas is offline
Old 09-24-2007, 03:33 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I dont have any rear differential gear upgrades. I honestley suggest a Cusco unit if you expering breakage.
Thanks
Ben
Gruppe-S is offline
Old 09-24-2007, 06:57 PM   #8
ilivas
Member#: 56056
2004 wrx
How does that work? Is the Cusco unit an entire diff? If so, will it sustain drag racing abuse? I have a 3.90 ring gear in my r160 diff, will it be geared correctly?
ilivas is offline
Old 09-25-2007, 08:39 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry I read the post wrong. I missunderstood the post and thought you meant the LSD was busted.
Ben
Gruppe-S is offline
Old 09-27-2007, 06:50 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 09-28-2007, 08:57 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 10-01-2007, 09:11 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 10-02-2007, 02:03 PM   #13
chrisarella
Member Sales Rating: (15)
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
What clutch kit do you recommend for a WRX with an STI motor pushing a vf37 twinscroll? I'm estimating this will be putting out 350-360wtq when all is said and done.
Free bump for the best prices around.
chrisarella is offline
Old 10-02-2007, 02:24 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I suggest the
STi 04-07
Combo w/
Gruppe-S is offline
Old 10-02-2007, 02:40 PM   #15
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Originally Posted by Gruppe-S View Post
I suggest the
WRX 02-05
Combo w/
^^^ Fixed, I have a WRX tranny with STI motor.
I should also mention I have 90k miles on my tranny and am afraid a stage 2 would put too much load on everything else. I'll ask my shop though that is doing the work.
Your prices are by far the best though.
Old 10-02-2007, 04:09 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks
Ben
Gruppe-S is offline
Old 10-02-2007, 07:59 PM   #17
05_TurboxSti
Member#: 124460
2007 WRX
wrong thread
05_TurboxSti is offline
Old 10-02-2007, 08:01 PM   #18
kkos06
Member#: 128591
2006 WRX
pm me a quote for the exedy twin plate for an 06 wrx shipped to 48370...thanks
kkos06 is offline
Old 10-02-2007, 08:53 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Pm sent
Gruppe-S is offline
Old 10-03-2007, 10:02 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 10-03-2007, 10:21 PM   #21
Absolut_Boost
Member Sales Rating: (14)
Member#: 117832
2006 WRX TR
Obsidian Black Pearl
can you pm me a quote for the Exedy Stage 1 and Stage 2 for an 06 WRX shipped to 89032...is a flywheel required for this clutch or can i use my stock?
Absolut_Boost is offline
Old 10-04-2007, 02:48 AM   #22
DrewDeezy
Member Sales Rating: (17)
Member#: 160279
2004 STi
Crawford Performance
i have a 2005 wrx stage 4 w/ supporting mods. I have a centerforce dual friction clutch right now that has started to slip. I have an 18g forced performance turbo. pushing ~300WTQ and 350HP... Can I get a quote for a good clutch and flywheel combo? I need it by next weekend. What can ya do for me
DrewDeezy is offline
Old 10-04-2007, 01:29 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Price is in the original post.
Stage 1
WRX 06-07
Combo w/
Stage 2
WRX 06-07
I would suggest a lighten flywheel if you are replacing the clutch. The engine spool up will be much quicker and this is a worthwile investment. Plus since you have the tranny out you might as well and save labor cost and replace it.
For you a Stage 2 would be the best option. This combo is perfect your mods while still keeping the car driveable.
WRX 02-05
Combo w/
Gruppe-S is offline
Old 10-04-2007, 09:56 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-s
Gruppe-S is offline
Old 10-05-2007, 12:14 AM   #25
kkos06
Member#: 128591
2006 WRX
how much for the exedy twin plate clutch for an 06 wrx (push type i believe)...pm for price shipped to 48067
or the 06 act street clutch and flywheel combo...i also need shipping prices for 2 day air saver vs ground if possible....thanks guys
kkos06 is offline
Closed Thread
Installed a cobb short shifter, bushings, and crank pulley it was awesome speedkills1133 Newbies & FAQs 14 03-29-2009 03:52 PM
Kartboy Combos! ACT Clutch/Flywheels! Exedy Clutches! Free Shipping! SpeedElement Drivetrain 55 06-27-2008 07:42 PM
KARTBOY Short Shifters, Bushings, Knobs, tons of Combo Deals!! Spun Autosports Drivetrain 55 05-28-2007 08:46 AM
NJ: Sti short shifter, bushings, Sti clutch/flywheel, B&M SS and much more!!! D Money Drivetrain 55 08-18-2006 05:34 PM
Should my new clutch be Exedy, ACT, or Spec? stephan Transmission (AT/MT) & Driveline 12 09-08-2004 12:47 PM
