Notices
Old 09-19-2007, 01:05 PM   #1
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Default EWG or STI cams on hybrid?which to buy first
first off my set up..
2.5l Hybrid STI block with WRX heads (w/30* back-cut valves)
Turbochargers.com TD05-18g ^7cm turbo
Un-equal length 1 piece header/up-pipe
MRT 3in downpipe
Stromung dual-tip catback
Mr. Josh Lightened crank pulley
TGV port and polish
Perrin short ram intake with Simoto Carbon Fiber MAF tube
Silicone Turbo inlet hose
Modded stock injectors flowing 825cc
Walbro 255lph fuel pump
JDM Sport 31*11*3 FMIC
NGK Irid. plugs one step colder
now, i can either buy a set of sti cams and have them installed before my tune in 2 weeks, or i can buy and make my EWG set up..
which is more important before the tune?
which will i see/feel more results?
Twiztidunreal is offline   Reply With Quote
Old 10-01-2007, 06:01 PM   #2
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
bump?
Old 10-01-2007, 06:11 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
the cams will be a bigger power adder properly tuned....
the engine pretty much has to be pulled to get to the cams so that alone is a chore.
testes1010 is offline   Reply With Quote
Old 10-02-2007, 02:47 AM   #4
r0n
Member#: 91839
Yeah, id opt for the cams man...
r0n is offline   Reply With Quote
Old 10-03-2007, 01:40 PM   #5
Spec V to Wagon
Member#: 129715
03 Wagon
I'm in the same boat here and I'll tell you what I did.
On my 2.0 I already had ewg set up (Element Tuning Uppipe with Tial 38mm) I bought used STi cams for $250 and plugged the holes for the AVCS (check this section I made a how to post.
Anyway, if the engine is already in do the EWG. You have to basically pull the motor to do cams and that is a TON of work although the STi cams will def give you some better top end.
Spec V to Wagon is offline   Reply With Quote
Old 10-03-2007, 03:19 PM   #6
rustyzipper
Member#: 79175
2004 FXT
Red
I would do the cams if you plan on going bigger on the turbo. If you are going to stick with the 18g , just do the EWG. Sounds like you will do both eventually anyway.
rustyzipper is offline   Reply With Quote
Old 10-03-2007, 05:40 PM   #7
remowgn
Member#: 41149
09 FXT
SSM
Originally Posted by LiquidForce View Post
This is a dyno of a hybrid before sti cams and after sti cams. No other head work was done.
Cams for sure. I don't know what the setup was on that car, but the cams were worth 60whp on the top end. Even if you ended up making half that in gains, it's still more than you'd get from an EWG.
remowgn is offline   Reply With Quote
Old 10-04-2007, 09:23 PM   #8
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
well i opted for the ewg, i would rather get rid of any thought of boost creep before it happens.. cams will be my next power upgrade though...
Old 10-04-2007, 09:59 PM   #9
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
Default cams vs ewg
Where are you in Houston? I am in Spring. I had an 02 hybrid before my sti. the wrx cams with the 2.5 block really die out at 5-6K rpm. I have some stage 3 dpr cams that would bring your motor to life. 300. i am not posting just to sell cams. you will really tell a difference if you use cams. 60 plus hp is a lot.
Texy32 is offline   Reply With Quote
Old 10-05-2007, 12:05 AM   #10
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
well i'll take em, lol
Old 10-05-2007, 12:14 AM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd do cams first.
Old 10-05-2007, 12:15 AM   #12
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
shoot I sold my Stock STi cams for $100
THE-95-STi is offline   Reply With Quote
Old 10-05-2007, 11:36 PM   #13
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
ok, so with my set up as listed in post 1, adding a 38mm wastegate, stage 3 dpr cams(Lift: .421in / .421ex Duration: 319in 319ex)w/crower springs and retainers, running 19 psi on 93 oct, what HP range should i be in
Old 10-06-2007, 07:55 PM   #14
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
are those cams a good size for a hybrid??
they do require the springs and retainers and say have a slight lope at idle
Hybrid intake build help on which to buy one ebay??? smithrcing17 Normally Aspirated Powertrain 5 04-08-2009 09:59 PM
Which to buy first? Sideskirts, Grill, Hoodscoop... kirkeemonster Interior & Exterior Modification 14 02-25-2007 12:14 AM
ABQ: Who needs WRX or STi oil filters? I'm going to buy a dozen ImportVenom South West Impreza Club Forum -- SWIC 10 02-02-2004 03:14 AM
which to do first on a 4eat? dp or up? showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 09-26-2003 11:38 PM
