Old 09-19-2007, 05:04 PM   #1
outlawz7469
Member#: 33144
Default THinking about by a Legacy..DD..Track duty????
Hi, I am thinking about buying a legacy for a DD and will probably do some track events in it. It works for me because I can fit my Kart and its AWD. I was wondering what if any aftermarket upgrades these cars have? are Impreza parts work?
outlawz7469 is offline   Reply With Quote
Old 09-19-2007, 05:53 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Subaru uses pretty much the same engine between the Impreza and Legacy, so most engine upgrades will work.
1999 and older, a lot of GC8 Impreza suspension components will interchange too.
Wheels will interchange except for the STis that don't have the 5x100 bolt pattern.
If you have anything more specific in mind try a search and if you can't find it someone will have the answer around here...
jey is offline   Reply With Quote
Old 09-19-2007, 08:20 PM   #3
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Virtually all Impreza parts work - what year Legacy are you looking at?
Are you on LERSOC.com - that's the local Subaru forum for anyone in Cleveland...
Huffer is offline   Reply With Quote
Old 09-20-2007, 09:06 AM   #4
outlawz7469
Member#: 33144
its a 1995, I just signed up for that site
Old 09-20-2007, 09:25 AM   #5
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
the '95 2.2 Liter engine is not a real athlete. However, it's unbelievably tough, as long as you don't try to turbo it. It's peppier with a 5-speed.
There are parts for it, but they're getting harder and harder to come by.
Interior pieces: Carpeting (With some work), and Seats from an STi will fit (with a little work, If you're less than 6 feet tall).
deadlydave is offline   Reply With Quote
Old 09-20-2007, 09:45 AM   #6
outlawz7469
Member#: 33144
II am looking to upgrade it suspension wise and probably get a cheap air intake, any tips where to pick this stuff up cheaply? would WRX suspension parts and intake fit?
Old 09-20-2007, 04:26 PM   #7
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
I haven't heard of a cheap Subaru intake that actually yields gains above and beyond the snorkus removal. Maybe if you go used?
WRX suspension parts are almost a direct fit - that has been discussed and you can search on that. Intake - no, since the WRX is turbocharged.
Old 09-20-2007, 11:17 PM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Ebay intake is like $30 new. I would change the crappy cone filter with a KN or something just in case you live in an area with a lot of dust or plan to rallyx the thing.
Otherwise, get tires, brakes, then suspension (in order of importance for track duty). Each can be gotten fairly cheaply if you're not picky and don't care about the new-part smell Sticky tires, some WRX brakes, good fluid, track pads, and an agx/ground control semi-coilover setup and I think you're good to go.
Engine parts...not really the best bang for the buck in modifying an NA subaru, unfortunately.
rougeben83 is offline   Reply With Quote
Old 09-21-2007, 12:59 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Bigger brakes do bolt on.... But you might need a bigger brake booster.
Suspension bits swap over.
Struts/coils swap over.
MOTORS swap over.
Piggyback EM DOES work, but not the greatest 100% of the time. But it does work SOME of the time. haha.
Power wise, you can also build a "stock" motor to be turbo/supercharged and do that with some piggyback EM....
Old 09-21-2007, 09:22 AM   #10
linsavy
Member#: 11620
1997 GF4-STiV3 clone
It will still be pretty slow no matter what you do.
Just spend the money on tires, brake pads and entry fees and have fun with it. Make sure the cooling system is in A1 condition so you keep the headgaskets from popping. It's not a big concern with the 2.2l but you are talking about a 13 year old car and track abuse.
If you want to go crazy get it aligned with as much front camber as possible and a little toe out.
You can get some Porterfield RS4 drum shoes if you have rear drums.
linsavy is offline   Reply With Quote
thinking about buying a Legacy dusterbd13 Legacy Forum 10 08-12-2009 12:10 AM
Thinking about this for new DD jstalford Off-Topic 15 06-08-2009 12:22 PM
What ya think about a '94 Legacy Turbo? tbcboo General Community 25 04-20-2009 04:17 PM
Thinking about lowering the Legacy. 02REX4LIFE South West Impreza Club Forum -- SWIC 28 01-10-2009 01:05 PM
Thinking about buying a Legacy Bugeye_Freak Legacy Forum 5 08-31-2008 05:42 PM
