Old 09-20-2007, 01:04 AM   #1
superdupersubaru
Member#: 92107
Default SR56/57 thread: post your numbers/ mods/ dyno type
2003 suby wrx
cobb 2.5l block forged internals
stock wrx heads
aps sr 57
aps turbo inlet
aps dr 550 fmic
pe 850cc injectors
walboro 255lph fuel pump
hks carbon ti exhaust
helix dp
dc up
aps bov
aps 70mm cai
koyorad
prodrive boost sylonoid
dont have my dyno to show but I can tell you i hit 303 hp 290lbs torque at 22psi on 91 oct......harmon motives mustang dyno used to aquire..
superdupersubaru is offline   Reply With Quote
Old 09-20-2007, 01:17 AM   #2
Mac323
Member#: 108505
What do you consider to be the SR57? As far as i know aps has yet to relase this. All i know is that the sr57 = sr56 w/ a 3" inlet.
I ordered a 56 w/ 3" inlet. I will have numbers up as soon as i get it and have a chance to install it.
My mod list is as follows
2006 STI
Stock Internals
APS SR56 w/ 3" Inlet
APS Turbo Inlet
APS DR525 Frontmount
Helix 860cc Injectors
Walbro 255lph Fuel Pump
APS 3" Turbo Back Exhaust
APS TGV Deletes
APS Fuel Rails
Custom Intake
Tial 50mm BOV
Tial 44mm EWG w/ Custom Uppipe
Vibrant Exhaust Manifold
Blitz ID3 EBC
Mac323 is offline   Reply With Quote
Old 09-20-2007, 01:21 AM   #3
superdupersubaru
Member#: 92107
yes aps sr57=sr56 with 3"inlet.......and to ad to my list i aswell have the aps fuel rails and tgv deletes......post when you get your tune our set-ups seem comparable im exited to see what you make bump!
Old 09-20-2007, 01:26 AM   #4
Mac323
Member#: 108505
will do.
Old 09-20-2007, 12:01 PM   #5
young j
Member#: 144478
2005 sti
wr blue
what kind of power can this turbo make on a sti without goin to ew?
young j is offline   Reply With Quote
Old 09-20-2007, 01:28 PM   #6
superdupersubaru
Member#: 92107
probably around 350 on 91 but if you run 100 oct map and thorow in some meth then prob around 420....thats what i was quoted anyway all depends on your supporting mods
Old 09-20-2007, 01:41 PM   #7
Mac323
Member#: 108505
i was told around 380-400 on 93 w/ an ewg setup and around 21psi (dyno dynamics) One 100/110/c16 over 400 should not be a problem.
Old 09-20-2007, 01:42 PM   #8
Jhovany
Member#: 137317
2006 STI
Rally Blue
APS SR56 turbo
APS 70mm CAI
APS turbo inlet
APS DR525 FMIC
APS 50/50 BOV
APS Fuel Rails
PE 850cc injectors
Walbro 255 fuel pump
TGV deletes
Invidia DP
HKS Hi-Power Exhaust
Accessport
Protuned by Richard Garcia at DynoComp in Scottsdale, AZ
335whp 320lbs torque @ 19psi on 91oct (dyno dynamics)
**About to get either a 100oct or 103oct tune very soon**
Jhovany is offline   Reply With Quote
Old 09-20-2007, 09:54 PM   #9
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Any of you guys done any 1/4 mile times with a race fuel tune? I am thinking about getting this turbo, but need to know what they can achieve. I have all the supporting mods.
Special is offline   Reply With Quote
Old 09-21-2007, 01:43 AM   #10
stu
Member#: 25768
35R bugeye
Slowbaru
I ran a 12.0 @ 116 on 91 pump gas with a sr55 it was a great turbo.
stu is offline   Reply With Quote
Old 09-21-2007, 04:55 AM   #11
superdupersubaru
Member#: 92107
what were your suporting mods thats impressive.....bump!
Old 09-21-2007, 08:21 AM   #12
Special
Member#: 145585
Yellow
Do these turbos have a lot of lag? I have a 2.0L.
Old 09-21-2007, 09:22 AM   #13
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
yes, lots of lag on a 2.0L
TopEndPull is offline   Reply With Quote
Old 09-21-2007, 09:32 AM   #14
Special
Member#: 145585
Yellow
Well as it is a bolt on I don't mind if it has lag once I only use it for racing as I will take it off and put back on the VF34 when I am not racing. I haven't been able to get any info on 1/4 mile times on race gas. I want something that can get me a mid 11.
Old 09-21-2007, 02:59 PM   #15
stu
Member#: 25768
35R bugeye
Slowbaru
I would guess it would be pretty laggy on the 2.0 but I would hit hard and pull hard. is your engine built. MZM ran one on a 2.0 and it went 11.6 I believe on race.
Old 09-21-2007, 04:05 PM   #16
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
They've had several that have trapped 122-123 on race fuel
Old 09-21-2007, 09:22 PM   #17
Special
Member#: 145585
Yellow
Well the 2002 JDM STi model actually comes with forged pistons and rods. I bought a wrecked STi so plan on taking out my S202 engine and using this engine and gearbox to race with. I really need a turbo that can get me low 11's, but it seems like the bolt on turbos can only yield mid 11's. As I am against going rotated for the moment, I guess I will have to deal with it. Do you guys think the FP Red is the best bolt on turbo to get? What about the APS turbos?
Old 09-21-2007, 10:57 PM   #18
stu
Member#: 25768
35R bugeye
Slowbaru
I think you are about the top maybe a element gt52.
Old 09-22-2007, 05:10 PM   #19
Special
Member#: 145585
Yellow
How come they don't have the SR57 on their site? What is the difference between it and the SR56?
Old 09-22-2007, 06:03 PM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Here's a car I tuned with an SR56. It has PE850's, APS FMIC with custom blow-through MAF, perrin solenoid, catless TBE. This was tuned on 91 Octane at 5000 feet above sea level and the plot is from my road dyno software which consistantly reads like the lower reading mustang dyno's. 315whp is good for about 112-113mph traps.
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 09-23-2007, 03:40 PM   #21
Jhovany
Member#: 137317
2006 STI
Rally Blue
^^^ Those are HORRIBLE numbers!!!!! even for a low reading dyno!!!!
Old 09-24-2007, 01:47 AM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep, they're definitely low. Of course considering this was at 5000 feet above sea level, on crappy 91 Octane, and extremely conservative 18-19psi as requested by the owner, they're not all that bad. Its about the same as an 8cm Green makes in similar conditions. IMO this turbo is pretty much useless unless you have the octane to back it up. It will really start to wake up around 25-26psi+.
Thanks
-- Ed
Old 09-24-2007, 08:57 PM   #23
STimo
Member#: 110273
450 whp 30R STI
[email protected]
Thanks
-- Ed
I've heard though that once you hit around 24-25psi with the APS SR56 that the tiny hotside wont flow anymore and boost doesnt hold to redline very well, and even pushing the crap out of it are only able to run around 24psi, any truth to this from your experience?
STimo is offline   Reply With Quote
Old 09-24-2007, 10:21 PM   #24
Jhovany
Member#: 137317
2006 STI
Rally Blue
I havent heard that....actually i agree with Vaus. I really like my APS SR56 turbo....its just very nice and very convenient knowing I have the top end when needed! These turbo might not produce insane dyno numbers but they are a very good top end turbo (being a stock location turbo of course)
Old 09-25-2007, 09:39 PM   #25
STimo
Member#: 110273
450 whp 30R STI
[email protected]
The boost threshold of that turbo just looks horrible though, looks like it picks up just like a 35R but without all the power I've never been a fan of the high priced/under performing APS turbos.. Only good ones i've heard of are the SR40 and the new TSR70 as long as you get the bigger hotside..
Post your Cobb Tuning dyno results! 06-wrx-tr Rocky Mountains Impreza Club Forum -- RMIC 129 05-15-2009 05:23 PM
anybody got great stock setup post your numbers EvoWhat? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-21-2006 11:13 AM
Who has the Most powerfull Wagon in the States? Post your numbers! cegpcola Proven Power Bragging 109 09-05-2006 07:03 PM
c'mon g-tech users.. post your numbers! ride5000 Proven Power Bragging 5 11-07-2003 02:59 PM
Dyno day in Atlanta -- post your numbers! sdecker South East Region Forum 64 12-09-2002 06:33 PM
