Old 09-20-2007, 06:53 AM   #1
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
Default new jdm heads running no avcs?
I am considering running some jdm v7 heads on my next ej22t build.
If I want to run a non avcs setup is it just a matter of blocking the oilfeed or?
will these heads work with an ej22t block sleeved to 2.5?
oh and who has non avcs cams for these heads?
thanks in advance.
Jon
saintluciascooby is offline   Reply With Quote
Old 09-20-2007, 08:37 AM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
all the oil feed lines are still utilized...
For cams, you might want to contact axis
jigga is offline   Reply With Quote
Old 09-20-2007, 09:01 AM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I thought you were still supposed to use AVCS cams? Don't block off the oil feeds, you'll starve them AFAIK.
wrxfactor is offline   Reply With Quote
Old 09-20-2007, 12:04 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
any ver5 and newer non-AVCS cam or any plugged AVCS cam will work for hose heads...you don't have to block the oiling in the head.
Those heads will work fine with the EJ22 bored out...I'd take advantage of the smaller combustion chamber in the piston design too.
jdm 2.0L non avcs heads wrxzzz Built Motor Discussion 7 02-18-2007 03:03 AM
JDM heads, AVCS cams, UTEC = ? InfamousDX UTEC 4 08-21-2006 12:09 PM
will avcs work on a usdm sti block with jdm heads ryanpietro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-07-2006 04:49 PM
Converting USDM v.7 WRX heads to run with AVCS? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-22-2004 01:08 PM
New JDM spec EJ20 w/AVCS longblock obtainable? BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-06-2001 11:38 AM
