Old 09-20-2007, 01:59 PM   #1
planet01
Member#: 44704
99 Legacy Wagon Br
Default Where is the PCV valve?
Does anyone have a photo of where it is in a 2.2 ltr legacy?
I'm thinking of switching mine out to see if it helps with oil consumption.
planet01 is offline   Reply With Quote
Old 09-20-2007, 05:23 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Right on top of the intake manifold. Pretty much directly on top. It has a tube going into it. Pull the clip off and use a socket to take the valve out. I could get you a picture if you still have a problem.
runninstrong is offline   Reply With Quote
Old 09-20-2007, 05:54 PM   #3
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
jey is offline   Reply With Quote
Old 09-21-2007, 01:51 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Here's another shot:
The arrow marks the flow of air, and the block highlights the valve.
Wiscon_Mark is offline   Reply With Quote
Old 09-25-2007, 12:41 PM   #5
planet01
Member#: 44704
99 Legacy Wagon Br
Thanks for the help!
Old 09-25-2007, 03:38 PM   #6
white_darkness
Member#: 160176
2000 Subaru Legacy
Green
Is it bad that the PCV valve is rusty?
white_darkness is offline   Reply With Quote
Old 09-25-2007, 04:34 PM   #7
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Nah, it rusts within the first few weeks of installing a new one.
Old 09-26-2007, 10:38 AM   #8
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
That's just surface rust on the casing. The actual valve won't be rusty. Mine still works just fine.
Old 09-26-2007, 06:35 PM   #9
white_darkness
Member#: 160176
2000 Subaru Legacy
Green
Gotcha... thanks!
Old 09-27-2007, 10:56 AM   #10
ebayking90
Member#: 159428
Were you able to replace it?
ebayking90 is offline   Reply With Quote
Old 09-27-2007, 07:52 PM   #11
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
I've never seen a rusted PCV valve. Are you using OEM ones?
Always use OEM PCV valves by the way. Heard stories of aftermarket ones having too weak of springs and allowing too much of a vacuum pull from the crankcase and thereby pulling excess oil into the intake manifold.
Which is what you're trying to avoid
DerFahrer is offline   Reply With Quote
Old 09-27-2007, 09:55 PM   #12
white_darkness
Member#: 160176
2000 Subaru Legacy
Green
For me, I haven't tried to take the hose off the PCV valve, but yes I have an OEM one that does have rust outside (just like in one of the previous pictures). I've had the car for almost 8 years and 130k now, so most likely that outside would rust.
Old 09-28-2007, 12:04 AM   #13
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It's OEM, and it rusts if you drive in WI. Spoiled southern car owners
Old 09-28-2007, 05:59 PM   #14
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Come to Pennsylvania
-Matt
Shik is offline   Reply With Quote
Old 09-29-2007, 05:41 AM   #15
Chi_San
Member#: 53558
2002 WRX Wagon
Everything rusts in WI. :P
Chi_San is offline   Reply With Quote
Old 09-29-2007, 10:20 AM   #16
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, even rubber
Where is the PCV valve and the EGR Psychopat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-10-2007 10:37 PM
Where Is The Pcv Valve? gingertooth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-07-2006 12:47 PM
dumb question; where is the pcv valve? doubledribble Service & Maintenance 19 07-10-2005 10:23 AM
where is the PCV valve? phat50 Service & Maintenance 4 07-16-2004 11:59 AM
('93-'01) Where is the PCV Valve on a EJ18? SubaruImpreza_power Impreza Forum 3 07-11-2003 03:22 PM
