Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-20-2007, 05:57 PM   #1
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Default 2006 sti tranny into 2006 wrx
I have the sti tranny drive shaft shifter linkage and axels... What else do I need to do the swap!!
renosubby is offline   Reply With Quote
Old 09-20-2007, 06:07 PM   #2
flystiguy14
Member#: 74416
91 SS leggy
pearl white
do you have the rear diff?
flystiguy14 is offline   Reply With Quote
Old 09-20-2007, 06:12 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I have the wrx rear diff do I need the 3.90 ratio
Old 09-20-2007, 06:49 PM   #4
verdee
Member#: 113772
2006 WRX Wagon vf39
I pretty sure you are going to need the clutch slave cylinder. The 06 wrx as a different clutch operation. Push vs. pull
verdee is offline   Reply With Quote
Old 09-22-2007, 01:02 PM   #5
hrdansk779
Member#: 146722
you will need everything from flywheel back and still have to wory how to wire your dccd controler
hrdansk779 is offline   Reply With Quote
Old 09-25-2007, 03:32 PM   #6
InsatiableAmos
Member#: 92706
2000 Swapped 2.5 RS
Silverthorn Metallic
I don't think he'll need a different clutch slave, as they're both turbo clutches (should be the same style, IIRC).
You WILL need compatible final drives though, and which rear diff you get depends on what year STI tranny you have. Some have a 1.1:1 center diff in them, while others are straight 1:1...so some years you'll need a 3.545 and some will need a 3.9.
www.northursalia.com has a chart of transmissions and final drives...definitely worth investigating.
InsatiableAmos is offline   Reply With Quote
Sti tranny into 04 WRX StealthfishWRX Transmission (AT/MT) & Driveline 3 01-19-2013 12:07 AM
2005 wrx Engine and jdm sti tranny--into 2002 wrx wagon tuningnoob Subaru Conversions 8 05-15-2009 06:42 PM
06 sti tranny into 02 wrx AWDWRXLOVER Subaru Conversions 5 05-02-2007 06:47 AM
06 sti tranny into 02 wrx scarsofterror Transmission (AT/MT) & Driveline 26 01-04-2007 10:13 PM
sti tranny into 04 wrx wagon? sakebomb Subaru Conversions 1 07-08-2004 03:34 PM
