Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 09-21-2007, 12:48 PM   #1
redrex2002
Member#: 118915
2002 wrx
srp
Default flat torque curve?
hey guys this is the best place i could thing of to put this. but what i am wondering is, i have read a coupple times on these boards about people with flat torque curves. what i am wondering is why that is a good thing i would figure that you would want your torque curve to increase as much as possible to help keep power up top? if someone can explain this to me that would be great.
redrex2002 is offline   Reply With Quote
Old 09-21-2007, 12:53 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
A flat torque curve will net a linear HP curve, the car is very controlled and has a wide power band. Cars don't naturally have flat torque across the RPMs, but they can be tuned to.
This is a tuning question not a built motor one.
bboy is offline   Reply With Quote
Old 09-21-2007, 12:57 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
it actually more a of built motor question than tuning one...the only way to really correct it as far as tuning goes is to have a constantly increasing boost pressure after hitting peak VE...the added boost will then try to keep the VE's at the same level...
so really, for the most part, comes into intake and exhaust manifold tuning, ports, turbo sizing, cams and rod ratio...
what you choose here makes all the difference to how that torque curve will look...tuning can only correct a little.
A flat torque curve will help to maintain a steady acceleration rate and allow for more driveability.
have you ever driven a car where it pulls hard down low and then starts to feel sluggish towards the top end? that is the torque curve falling off...real engine builders, racers and tuners, who know what to look for, read the torque curve, and not the hp curve, as it directly (nearly) relates to exactly what the engine is doing.
Old 09-21-2007, 03:52 PM   #4
Jeremy@Cobb
Member#: 106514
Camshafts and headporting have the most to do with this for Subaru's, tuning also has some effect.
This is really ideal for a road coarse, constantly in and out of gears and fluctating rpm's.
With a broad torque curve the car will be more predictable.
two cars equal, except differnt power bands
1- Having 500ftlbs for 1500-2000 rpms
vs
2- Having 500ftlbs for 3000+ rpms
On a road coarse the second car has the advantage.
It is more likely for the second car to be pushing more power at all times, in and out of turns with rpms fluctuating.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 09-21-2007, 07:45 PM   #5
redrex2002
Member#: 118915
2002 wrx
srp
thanks for the responses that helped alot
Old 09-21-2007, 10:25 PM   #6
Blueghost6789
Member#: 159900
Default sa
sa sa sa
Blueghost6789 is offline   Reply With Quote
Old 09-21-2007, 11:50 PM   #7
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I want a flat torque curve
modaddict is offline   Reply With Quote
Old 09-22-2007, 01:28 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
well, I'm trying to make a big, flat torque curve
had a small on already...flat from 3500-7000...was quite nice
Flat torque curve antonch Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 09-21-2009 01:27 AM
anybody have a flat torque curve on thier dyno map? wagonmasta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 12-20-2006 03:14 PM
Hunting for Idle? Flats Spots in Torque Curve? Costas Normally Aspirated Powertrain 0 08-23-2003 09:42 PM
What's the best Kit for flat-high power/torque curves? ngenear Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-08-2002 10:10 AM
('93-'01) Graph of horsepower/torque curve for phase I 2.5L? 2.5GT Impreza Forum 3 06-08-2001 12:00 AM
