Old 09-20-2007, 09:34 AM   #1
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Default external oil cooler
I was planning to run an external setup on my car, but I've come across a few issues.. For one, the stock lines. I'm pretty sure I'm just going to run them together with some aluminum hose, but I'm open to ideas.(picked up a few ideas from Mick's build thread) The biggest issue is the adapter plate. The Subaru main bolt that holds the stock cooler is way too long to fit a sandwich adapter.. What are people using in place? We even scavanged a few other ones from random motors we had in the shop, but none of them would fit the Subaru threads. Any ideas? Who's running an external setup?
bigmike25rs is offline   Reply With Quote
Old 09-20-2007, 11:21 AM   #2
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Your sandwich adapter should come with the appropriately sized center bolt. Did yours get lost or did it not come with one?
Russ
rlavalle is offline   Reply With Quote
Old 09-20-2007, 12:03 PM   #3
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
The stock oil cooler is going to be eliminated, so the male end is out of the picture. I need to replace the main bolt to make up for the size difference. Basically, I need a double male end thread that is smaller than the stocker.
Old 09-20-2007, 01:03 PM   #4
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Oh, I think I get it now!
I am at work now, so can't see my sandwich plate bolt, but if I recall correctly, it's female on one end (that connects to oil cooler) and male on the other (where the filter connects). But when you remove the oil cooler and it's bolt that has male threads on both ends, you're left with nothing to connect your sandwich plate bolt to.
What you'd need is a replacement stock bolt that's used in cars without the oil cooler. Ought to be something available from a Subaru dealer.
I still haven't decided whether to remove the stock cooler or not. I'm installing a lower temp thermostat, so if the oil ends up at 180 degrees instead of 200+,that ought to be OK.
Russ
Old 09-20-2007, 01:38 PM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Subaru RS bolt shoud work, the RS does not have an oil cooler
mick_the_ginge is offline   Reply With Quote
Old 09-20-2007, 01:46 PM   #6
sick1.8t
Member#: 22345
2003 RSX
black
or any other subaru that isnt turbo.
sick1.8t is offline   Reply With Quote
Old 09-20-2007, 11:36 PM   #7
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Great, thanks for the help guys.. I've got a 2.5RS main bolt on order..
Custom built external oil cooler patrick smith Member's Car Gallery 74 04-12-2010 10:52 PM
FS: BNIB Canton Oil Cooler Converted STi Engine/Power/Exhaust 9 03-16-2010 10:07 PM
External oil cooler? Boost4life05 General Community 1 10-10-2009 09:07 AM
FS: external oil cooler and oil pressure gauge EntrustXXXX Private 'For Sale' Classifieds 1 01-13-2005 11:31 AM
External Oil Cooler Kit ChAi North West Impreza Club Forum -- NWIC 11 03-28-2003 02:22 AM
