Old 09-21-2007, 05:44 PM   #1
TheMainFrame
Member#: 104251
2002 Impreza WRX
Pearl Silver Metallic
Default Failed Inspection for monitors "Not Ready"
So i took my suby to get oil, rear diff, and manual tranny fluid replaced as well as an inspection...
The car failed the inspection cause the "Catalyst", "Evap.", and "02 Sens" Monitors came back as "Not Ready"
They asked me if i had unplugged the battery latley as this will cause you to need to cycle the car for 50-100 miles before these monitors reset to "Ready"
I havent had it unplugged but very recently i used my Actron to clear some codes... does that consitute as a reset of the entire system causing it to need to cycle again? If yes how many miles do i need to get them back to ready? If no what could be causing this issue and how can i get them back to "Ready"???
TheMainFrame is offline   Reply With Quote
Old 09-21-2007, 05:54 PM   #2
TheMainFrame
Member#: 104251
2002 Impreza WRX
Just FYI, i use a UTEC and the codes cleared where fake misfire codes i get from time to time related to my overly lightened flywheel
Old 09-21-2007, 05:58 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
Clearing the codes probably would have done it. I did that once and it blew away my AP Realtime Map.
Try taking a long drive, then letting it idle for a couple minutes afterwards. If you search around you should be able to find the specific drive cycles that will trip the readiness monitors.
jays05 is offline   Reply With Quote
Old 09-21-2007, 06:01 PM   #4
TheMainFrame
Member#: 104251
2002 Impreza WRX
OK, is there anyway, short of returning for another inspection, to tell if they have reset to the "ready"?
Old 09-21-2007, 06:25 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
I have an Actron OBD2 scanner and it tells the status of the readiness monitors. Could be that you have a cheaper model maybe.
Old 09-21-2007, 06:32 PM   #6
TheMainFrame
Member#: 104251
2002 Impreza WRX
Atchually now that you mention it there are a bunch of stuff after the codes it reads but i never paid it no attention... ill have to check that!
Old 09-21-2007, 06:59 PM   #7
TheMainFrame
Member#: 104251
2002 Impreza WRX
Yes it does tell me the status of the monitors... Thanks Jays05!
Your the man
Old 09-21-2007, 08:18 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ding-ding-ding
Old 09-21-2007, 08:35 PM   #9
TheMainFrame
Member#: 104251
2002 Impreza WRX
Originally Posted by Uncle Scotty View Post
ding-ding-ding
Thanks for the confirmation Scotty... oh hey!
Thanks for the cocktail!
Old 09-25-2007, 05:39 PM   #10
TheMainFrame
Member#: 104251
2002 Impreza WRX
Gosh darn my o2 and Evap monitors but that pesky catalyst monitor is still "Not Ready"!
I hope its soon as i hate driving with a expired inspection sticker!
Any tricks to speeding up the catalyst monitor?
Old 09-25-2007, 09:16 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Drive at greatly varying speeds and throttle positions is best. Find a lot of stoplights and heavy traffic . Do this after the car has fully warmed up.
Old 09-25-2007, 09:58 PM   #12
jays05
Member#: 78165
05 STI 35r + e85
Cobb AP sets the catalyst monitor to be ready. My car shows the catalyst as ready immediately after an ecu reset
Old 09-25-2007, 10:05 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
...try this one
edit: ...I found the whole thing in a different section of the FSM...too big to post up...PM me if ya want all the subaru obdII readieness procedures....there are 6 total...quite elaborate
Old 09-25-2007, 10:07 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
...if ya got any 'wired in' rear o2 'cel fix'....THAT can cause a permanant 'not ready' condition as that is how the 'wired in' fix works to keep the check engine light OFF....the test it 'pending' all the time...so NO CEL on
Old 09-26-2007, 01:08 PM   #15
TheMainFrame
Member#: 104251
2002 Impreza WRX
Nope no fix...
I use a Cattles DP with a Invidia High Flow Catted Downpipe and borla hush catback and nothing with its configuration has changed from the last inspection in which the setup was fairly new.
Im hoping i just havent hit the proper cycle to enable the cat monitor
Old 09-26-2007, 04:41 PM   #16
TheMainFrame
Member#: 104251
2002 Impreza WRX
...try this one
Those all need to be completed in order with nothing in between? that might be tricky.. ill need a road i can stop on... and vary my speed from 40 to 60 mph... will be tough to do legally
How can you idle for 1 min and then do 0-60 in 20 sec... should i pull over on the highway for a min?
And some people say to accomplish this from a cold start but i live a good 8-10 min from the highway and im not doing 60mph on these 30mph roads around my house
Old 10-23-2007, 07:22 PM   #17
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
US, how can I get a copy of this obdii.pdf file?
...try this one
chimchimm5 is offline   Reply With Quote
Old 10-24-2007, 12:48 PM   #18
TheMainFrame
Member#: 104251
2002 Impreza WRX
Originally Posted by kozloski
Go to www.airchecktexas.com for details. It varies for different areas of your state but it looks to me that you can have two monitors not set as long as the CEL is out and there are no codes pending.
upon checking out this site i found that my area can have upto two monitors "Not Ready" and still pass OBDII test...
I failed with 3 "not Ready" but i only have one (catalyst) that is not ready right now so I should pass the OBDII test!
Thanks to kozloski on OBDII Forums
Old 10-24-2007, 10:48 PM   #19
TheMainFrame
Member#: 104251
2002 Impreza WRX
Yay, im now sporting my new sticker
Mission accomplished thanks to US and the sharp guys on the ODBII Forums
Old 10-26-2007, 08:46 PM   #20
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
do the drive cycle or drive alot with premium gasolina!!
EJ20_lee is offline   Reply With Quote
Old 10-26-2007, 11:15 PM   #21
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
Exclamation
Not quite sure exactly how they do it there, but here in PA if your vehicle is older than 2000 MY, you are allowed two monitors not set, and still pass, 2001- current, are allowed one. For all of you guys with code readers.. clearing codes automatically resets ALL monitors to 'not ready' status. And the ones that are most found; evap, catalyst, and O2 sensors.. are obviously the three hardest to set.. there's really no fast and easy way to do it.
BTW, if your car has previously failed for monitor status, most OBDII emissions analyzers have a Dx mode where you can check them before actually running a test. In most states, the law is written that we must test cars 'as presented', but in a lot of cases, if we know of the previous fail, we will do this first to save ourselves, and the customer a lot of aggrivation.. it also helps to be tight with the guy doing your inspection
thunder_lizard_1976 is offline   Reply With Quote
Failed Inspection for "Tire Splitting"?? wanalaugh74 Mid Atlantic Impreza Club -- MAIC 13 07-02-2009 07:28 AM
Failed Inspection for Stock Hoodscoop! WOOT! TravisSTi Mid Atlantic Impreza Club -- MAIC 49 04-02-2009 06:07 PM
Inspections and "Not Ready" codes Brock31 Open Source Reflashes 9 12-29-2007 07:57 PM
I/M Monitor O2 "Not Ready" for how long? z&cobb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2002 10:32 AM
Girlfriend's car failed inspection for NOx emissions LUME Tri-State Area Forum 5 05-26-2001 09:56 AM
