Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 09-13-2010, 11:43 AM   #26
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Don't know if this will help, but i've taken a log of my OCV & AVCS activity... Here's the link: OCV & AVCS Log
If the link doesn't work please let me know and i'll try and host it elsewhere.
g00fy is offline   Reply With Quote
Old 09-13-2010, 11:46 AM   #27
ktmrider
Member#: 125687
2005 Legacy GT - 6MT
Can't view link unless member of the board...
ktmrider is offline   Reply With Quote
Old 09-13-2010, 12:02 PM   #28
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Edited, please try again.
Old 09-16-2010, 01:33 PM   #29
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Edited: Irrelevant Post
Old 09-23-2010, 01:59 AM   #30
Maverick7531
Member#: 234291
2002 WRX - '04 EJ257
w/ ECU & Fuel -'04 5MT
Originally Posted by takeshi999 View Post
my car is currently putting out these 2 codes for the avcs...i did a search and all i was really to find was that the filter in the avcs causes it sometimes...but i checked mine and mine are gone allready..i changed one of the avcs solenoids with a friends and still got the same codes...so what else could it be?
Hey guys... Im thowing those 2 codes... been very confused. I was wondering if anyone has heard an active noise from their valves/cams... I can hear at least one side trying to move/work... The sound of an electric motor having a hard time.
Might I need to get a new solenoid?
Maverick7531 is offline   Reply With Quote
Old 10-01-2010, 02:22 PM   #31
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Got tuned this past saturday. CEL's came back, and left, and came back, and left again and came back again... This is getting incredably frustrating...
Old 11-05-2010, 03:36 PM   #32
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Found the source of my CEL's, turns out the guys at machineworldNY.com royally messed up my heads (cut the valves wrong, messed up the valve seats, glass beaded the heads, didn't remove all the glass beads), and a leak down showed pretty much all of my intake valves severely leaking.
Old 11-05-2010, 11:54 PM   #33
slovak
Member#: 168922
07 STi
Obidissian Black
I got the same issue, I hear it every once in a while.
I got the same crappy problem with the idle being choppy and stalling, but im going to search for any vacuum leaks that I may have, have a good idea of where it might be.
The weird thing is that I am also throwing timing codes and checked and even re-did my timing belt twice and all is good there. If cams have anything to do with then a tune is in order, even though I just start it from every once in a while since I am waiting on more parts to come in.
slovak is offline   Reply With Quote
Old 11-08-2010, 10:55 PM   #34
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
I had this issue....
(both codes at once) First removed the AVCS screens, CEL came back.
btw - I highly recommend buying new $2 copper gaskets if removing the AVCS screens as the old ones will be pretty deformed and may not seal properly.
Final fix - changed the oil to some fresh oil... good to go.
z is offline   Reply With Quote
Old 03-30-2011, 11:13 AM   #35
shes_a_rally_girl
Member#: 146711
2004 STi
The best advice I can give...when the CEL comes on, get the codes pulled ASAP. If the codes are p0011 and p0021, change your oil and oil filter ASAP.
These codes popped up on me over the weekend. I seriously doubted the timing, as I just recently had the belt replaced, as well as the pulley kit (this was about 5,000 miles ago). I changed the oil and filter, and within about 25 miles of driving, the CEL cleared on it's own. I had been running Royal Purple, but after reading post after post about how that stuff is crap, and my recent experience, I have switched to Castrol EDGE (formerly Castrol Syntec). I plan on changing again after about 1,500 miles, just to get out any extra crap that may be in the car, and start new.
I've read several places where people have lost turbos and engines, and can't help but wonder how long they drove around with the CEL on and these codes. This is why I can't stress enough, get the codes pulled ASAP when the CEL comes on. AutoZone does it for free. I also found out my usual mechanic will also pull codes for me free of charge, as well as help me decipher what they mean.
shes_a_rally_girl is offline   Reply With Quote
Old 04-28-2011, 12:56 AM   #36
ltommer
Member#: 154340
2007 Impreza WRX STI
07 STI threw these codes so I came here and started reading.
Just got back from deployment, the car had gone 6k miles w/o oil change so I ran to a sit in your car place and had it changed as soon as I found out. 3 weeks later the codes pop. After some reading I decide to change the oil and I find the drain plug 1/2 a turn loose and the oil filter on tight enough that it took 10 minutes and 2 busted knuckles to remove. It was around a quart low.
I cleared the codes with accessport (I use stage 1 car is unmodded otherwise) and they have not returned. problem is I am pretty sure the turbo is going out now. I drove it about 2 miles after oil change and warming it up and it had severely reduced boost and I can definately hear noises that I have never heard before. I am somewhat loathe to blame the oil change place totally since blown turbo's seem to be pretty common on '07.
I think at this point I am just going to have it towed into the dealership.
ltommer is offline   Reply With Quote
Old 06-03-2011, 03:35 PM   #37
Ms. Schnell
Member#: 172819
'04 fxt
I've got the p0021 code as of right now, and I've had it for quite some time. I have removed the OCV filters and even replaced the driver's side AVCS solenoid with no luck. Pulled my timing covers off last night and the timing is dead on. I found a thread on the legacy forum of a guy with the same issue as me.
http://legacygt.com/forums/showthrea...em-131462.html
As far as oil goes, I run asmoil 5w-30 in the winter and 10w-30 in the summer and am not burning any oil at all. The car runs smoothly, no stalling, regular idling, perfect gas mileage and no loss in power. After reading that thread I think its time to pull that cam gear off and check to see if there are any issues.
Ms. Schnell is offline   Reply With Quote
Old 12-22-2011, 10:18 PM   #38
Blackwagonman
Member#: 198088
Red
I am at the final stage of my battle ... after 2 years of fighting and nearly 5 to 6K spent on repairs I can not shake the P0001 code from my subaru. I have had one of my cams replace, heads gaskets done, heads completely reworked, timing belt, new turbo, new oil control valves, all the technical service bulletins done, too many short interval oil changes to mention along with oil system cleanings. After all of that work the longest the code went away was for a month and is now back again in all it's crappy idle stalling glory.
The only option I can see now is simply pulling the engine and replacing it. Based on one of the other comments I will do a leak down test before scrapping the engine just to see if one of the shops did crappy work.
I have learned two things from all of this ... I will only run synthetic oil in turbo charged subarus and if the p0001 code shows up on any of my future vehicles I will get rid of the vehicle that very day.
I would not wish this code on my worst enemy.
Blackwagonman is offline   Reply With Quote
Old 12-23-2011, 08:53 AM   #39
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
How many times have the heads been decked? The guys at area1320 found the thickness of the head gasket plays a big roll in the appearance of this code, they found that heads that were decked once or more, although within spec, were still shaved down enough to cause this code. IIRC they fixed it by switching to thicker .045 gaskets and that cured the problem on an STi that was having trouble with this code.
Here's a link to the thread: http://forums.nasioc.com/forums/show....php?t=2115862
Old 12-23-2011, 11:27 AM   #40
Blackwagonman
Member#: 198088
Red
Thanks g00fy! The heads have only been decked once to my knowledge. Do you think a leak down test would show this head gasket issue? I am sending it down to the local subaru dealership to have the leakdown test done next week. Any other suggestions or information from anyone will gladly be taken.
Old 12-23-2011, 02:08 PM   #41
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
I don't believe a leakdown test would show whether or not your having this specific gasket thickness issue, it seems it's one of those things where you just gotta give it a shot and hope for the best. But good luck with it man, I know how it feels to be plagued with problems, I've been having nothing but problems with my forester build for the past 3 years.
Old 12-26-2011, 05:01 PM   #42
Charlesyang55
Member#: 259505
2004 sti
black
well i dont know if this will help anyone but i had a p0011 cel and now just fixed it. mine problem was my oil control valve. after the shop installed a new one it runs smooth like it use to now.
Charlesyang55 is offline   Reply With Quote
Old 02-12-2012, 10:39 AM   #43
kazmihasi1@aol.com
Member#: 185559
05 Impreza Wrx STi
Platinum Silver Mettalic
For guys with p0011/0021 if you have changed or cleaned the ocv, removed the oil screen. You guys might have to open up the cam gear unless you replace them, to do so you'll need a t30 torx plus 5 point bit, preferably with a 3/8 drive and then you can take it apart and clean it, trust me it works.
kazmihasi1@aol.com is offline   Reply With Quote
Old 02-12-2012, 08:03 PM   #44
longjohns
Member#: 232353
2006 STi
having this same problem! my wife was driving the car and she called me saying the check engine light came on. when she got home i pulled the code: P0011. my car has a k&n intake and a GMS catted tbe running stage 2 AP. the turbo was just swapped out(it was blown) 1000 miles ago and the oil was changed at that time as well. im gonna get it checked out hopefully tomorrow by the place that i got it done at (broken motorsports) but should i be worried about another possibly blown turbo?
longjohns is offline   Reply With Quote
Old 02-19-2012, 04:11 PM   #45
leonard5616
Member#: 310792
Default code p011 and sometime p021
I have a 2006 Legacy gt and these codes P0011 and P0021 are coming some time , and what is strange in the same time with cruise light flashing . Can anyone tell me what is all about . Car is running fine , no lost of power or something else . If i reset the codes is running ok for couple of miles and check engine light together with cruise light are coming back again .
thanks
Leonard
leonard5616 is offline   Reply With Quote
Old 03-17-2012, 06:11 PM   #46
jlmillionaire
Member#: 292740
2004 sti
qrb/cf frnt cf rear bmp
I just threw this code p0011 as well with 100200 miles stock turbo just tbe perrin intake but i had one of the hoses disconnected from the turbo for a while so i probably toasted it???
jlmillionaire is online now   Reply With Quote
Old 08-16-2012, 12:00 PM   #47
tricktraxxas3
Member#: 288312
2007 WRX STi
Anything in the means of solutions? I'm having the same problem on my 08 WRX.
tricktraxxas3 is offline   Reply With Quote
Old 05-13-2014, 02:55 PM   #48
VitSTI
Member#: 390716
Unhappy 08+ STI 60k miles Cobb Stage 1
Hey guys, I really don't know what else to do, I recently rebuilted turbo because I saw smoke, and I checked that it has shaft play. I drove maximum of 200 miles and I got random misfire code in cylinder 4, I cleared the code and same day, after a bit of more driving, I got code P0011. Today I removed downpipe, and knowtised that I have turbo shaft play again. I removed intercooler, and there was oil in it. After I removed turbo of my car completely, I removed shaft and I saw few cracks on copper bearing, and shaft looked like it was under high temperature or friction, because it was all blue on the part where bearing goes.I later removed banjo filter from turbo feed line, and I can say that it was too dirty.****Note: before doing all thins I make sure that turbo feed line was not clothed up, I turned car few times, and oil went from it, so I don't think I was not getting any oil into my turbo*** Can someone help me with this issue, I will greatly appreciate it.
VitSTI is offline   Reply With Quote
Old 05-13-2014, 03:34 PM   #49
VitSTI
Member#: 390716
Originally Posted by Bruce Wayne View Post
I had the same cel codes, and mine also skipped 2 on the timing belt. You can take your timing belt cover off pretty easily and take a peak, and if the belt is fine then I'd try this since yours is a 04 model http://www.scoobymods.com/forums/showthread.php?p=20694 I think it only takes 30min or so.
How do I know if the belt has or hasn't skipped any?
Old 08-05-2014, 12:33 AM   #50
Xx05xSTIxX
Member#: 267050
2005 Sti
Hey guys wanted to tell everyone I had these codes and it was
Due To the fact that when I built
My motor the avcs cam gear was internally
Damaged when I removed it because it was so tight I was forced to use a massive breaker bar took the avcs cam gear apart saw it was damaged $250 later installed a
New one and bam both sides of avcs working
You can monitor this on you access port hope this helps guys
Xx05xSTIxX is offline   Reply With Quote
Help with Gun-Metallic paint code ITW2 Interior & Exterior Modification 7 03-26-2010 07:25 PM
P0011 and P0021 Only when Hot- Tried a lot of fixes whitfork Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-25-2009 04:48 PM
Need some help with this check engine code!! pornstar1969 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 12-10-2006 09:55 AM
Re Post: Need help with RS-T ECU Code Malfuctions, and if TEC II will Solve it. yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 14 07-31-2001 05:17 PM
Need help with RS-T ECU Code Malfuctions, and if TEC II will Solve it. yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-31-2001 07:34 PM
