Old 09-22-2007, 04:04 AM   #1
rstinut
Member#: 143993
2011 wrx
white
Default 2004 usdm sti cams in a 2L
ok so my setup is as follows.
wrx block
crank
rods
heads
V6 sti pistons
vf30
sti pinks
v7 intercooler
ecutek
v7 intake rail
255lph fuel pump.
right now i have the stock cams and last time i was on the dyno my powercurve falls off sharply after 6600rpm, would changing to the usdm sti cams give me a better powercurve, i dont wan to lose lowend but more top end would be nice! with the avcs delete mods obviously on the cams.
experts and mod motor nuts chime in please. thanks
John
rstinut is offline   Reply With Quote
Old 09-22-2007, 04:18 PM   #2
charliew
Member#: 125304
Default torque curve
more than likely you will lose some low end and move your power higher in the rpm scale. do you plan on driving more at 6600 or 3500?
Charlie
charliew is offline   Reply With Quote
Old 09-22-2007, 04:51 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
they are a good "cheap" upgrade and would deliver a good all around cam for 2.0L...
IIRC they are suppose to be 256/256 with 9.6 mm and 9.8 mm lift on intake and exhaust respectively...
stock ej205's are 256's as well but 9.27/9.17 for lifts...so less top end oriented on the lift specs and a noticable amount less overall lift.
so a good little upgrade...but you will need to have the avcs oiling ports plugged, which is very simple for a machine shop.
you've now reminded me that I need to sell mine...thanks
2004 USDM STI with JPN head+cosworth hi-cam?? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-02-2008 06:40 AM
Question about 2004 USDM STI with Jun 272 hi-cam. skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-18-2008 04:50 AM
sti cams in 2L heads wickedwrx2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-03-2007 06:43 PM
2004 USDM STi pedals in '95 Impreza L? Zora Subaru Conversions 6 12-15-2005 12:19 AM
FS: 2004 USDM STI Shortblock In Maine, $500 Dizastical New England Impreza Club Forum -- NESIC 7 02-13-2005 02:32 PM
