Old 09-22-2007, 10:04 AM   #1
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Default AMS FPGreen Test! 2007 STi, 8cm housing
In the midst of our very chaotic move we were able to get my car on the dyno and finally test this bad little boy. The results were very nice and we are really impressed with the turbo. The car is now making 75 more WHP at Redline on pump gas!
On with the test
The Vehicle: 2007 Subaru Sti
Modifications:
AMS Custom Catback
Turbo XS Downpipe
AMS Test Pipe
AEM Cold Air Intake
Vibrant Header with up-pipe
Deatschwerks 850CC top feed injectors
Walrbo Fuel Pump
Forced Performance FPGreen with an 8cm turbine housing and 2.4" Inlet
Forced Performance High PSI internal wastegate actuator
STOCK TOP MOUNT INTERCOOLER
pump Gas
21 Psi tapering to 18psi
Mid to low 11's AFR's
The First graph here is just the numbers. Here is what she did last night on the dyno. we are pretty impressed!
Now here is that same graph in STD Correction for those that are used to using the "Standard" Correction factor
And last but not least here is the HP curve outlined over the tune with the stock tubro. All that was changed was the FPGreen and the fuel modifications to support it. Look at the HP increase at redline!!!
All in all we are very happy with the results and considering the spool time we will deffinetely be recomending this turbo to our subaru customers.
Next on the modification path is to try this same combination with our AMS Top Mount Intercooler, Remove the Tumbers, Try an FP 3" Cover and toss an External Wastegate actuator on it. Oh, and of course throw some real gas at it
We think with some better boost control and a little less heat soak we can squeeze close to 400whp out of this little bolt on turbo.
Eric Gaudi
Sales Manager
AMS Performance
AMS is offline   Reply With Quote
Old 09-22-2007, 10:34 AM   #2
fourmicah
Member#: 128760
2015 STI
Nice to see people still using the TMIC. So many people say you can't make power with them and I've heard many instances were this is not the case. Good Work.
fourmicah is offline   Reply With Quote
Old 09-22-2007, 12:03 PM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Before you guys try your own TMIC, do you think you could get ahold of a JDM STi TMIC? I wonder if there are any true gains to be had with it over the USDM STi, being as it is 15% larger.
wrxfactor is offline   Reply With Quote
Old 09-22-2007, 12:20 PM   #4
AMS
Member#: 27854
STI, WRX, GTR, EVO,
if anyone has one to send we would be willing to try.
Eric
Old 09-22-2007, 12:52 PM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
This Opensource or Cobb?
DoctorNick is offline   Reply With Quote
Old 09-22-2007, 06:11 PM   #6
AMS
Member#: 27854
STI, WRX, GTR, EVO,
This was with open source. I have an AP on order for it but its not in just yet
Eric
Old 09-22-2007, 07:23 PM   #7
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Typical power range for this 2003 turbo is 360 to 380whp on pump gas. The only issue I see is that its comming on real late. THis turbo should be on by 3600 to 3800 full out. A retune of the AVCS system will help. Good job guys!
Clark
AZScoobie is offline   Reply With Quote
Old 09-22-2007, 09:55 PM   #8
MattPersman
Member#: 139385
I dunno, I still think TMIC is a compromise, especially when you go to this size turbo. consistency wise FM should prevail
nice numbers. EWG should make a nice difference. do not know if the 3" is worth it.
MattPersman is offline   Reply With Quote
Old 09-22-2007, 11:29 PM   #9
Member#: 136023
2005 STi
Clark
For some reason on the log it's showing full boost by 3850-3900 and i was ending the pulls just short of 7K. There might be some offset on the ignition pickup for some reason.
I tuned it last night in a hurry Clark and I tried only about 2 iterations of AVCS timing before we called it a night. Once Eric gets' his AP and we finish up our move I'll have some time to play with it.
Thanks! We'll be testing an 18g on our shop car next, I'm very curious to see how that does.
Martin@AMS is offline   Reply With Quote
Old 09-22-2007, 11:42 PM   #10
Jeremy05sti
Member#: 142040
2005 STI
HTA Twisted
lookin good guys.....keep it up......this now confirms that I'll be going for the Green
Jeremy05sti is offline   Reply With Quote
Old 09-22-2007, 11:58 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Fpgreen Ftw!
mxpunk is offline   Reply With Quote
Old 09-23-2007, 12:20 AM   #12
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
any plans to do a test on the 20g? that's what i'm leaning towards. also tell Chris to hurry and come back to the big island! my 04sti needs some more AMS love
Spec_C is offline   Reply With Quote
Old 09-23-2007, 01:52 AM   #13
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
+1 I agreee. That's an awesome power curve and looks great for a daily driver/autox/drag stip car and of course (hopefully) it's realiable too.
Yoo Shin is offline   Reply With Quote
Old 09-23-2007, 02:08 AM   #14
Foo_Blyat
Member#: 93750
2008 GSX-R600
Massive STi Part-Out
Awesome numbers, does the simplicity (ie:top mount, tumblers, etc) of the system explain the lower tq # then hp?
I thought that was only typical of Evos....
Foo_Blyat is offline   Reply With Quote
Old 09-23-2007, 10:04 AM   #15
AMS
Member#: 27854
STI, WRX, GTR, EVO,
Im sure that has something to do with it. I would of loved to pull out the tumblers and switch to our TMIC or even an AMS FMIC and test the stock turbo out again but time was not on our side with AMS being closed right now for our move.
Torque was a bit lower but the great thing about this car right now is that it pulls to redline like my evo did (only with much more power) and its making just about the same HP as torque. WAY higher then an EVO
Foo_Blyat, just an fyi if an evo were to make about 370whp on pump gas the torque number would be close to about 340 on this turbo, if not lower. The evo doesn't have a tumbler or a top mount to get in the way either. Food for thought.
I would love to get all of this done before the shootout but I just don't think we are going to have any time to do this. I looks as if the way the car sits right now is the way its going to see the shootout. We might toss some better gas in it and kick up the boost just because i'm power hungry and miss the strip
Eric
Old 09-23-2007, 10:58 AM   #16
CatfaceType-R
Member#: 81102
make your ams STi beat your ams EVO and tell us all how you did it...kthxbye jk
CatfaceType-R is offline   Reply With Quote
Old 09-23-2007, 02:36 PM   #17
vaj
Member#: 59136
04/5 APRWidebody STi
Parts all over the state!
Sweet.... This is very similar to my setup minus the 3" inlet, FMIC and deleted tumblers etc.. Can't wait to have the car out of body so we can get Chris on this tune.. Aloha....
vaj is offline   Reply With Quote
Old 09-23-2007, 03:52 PM   #18
BlackSTI2006
Member#: 105404
2006 FPGreenSTI SOLD
04 GMC 2500HD Duramax CC
Looks awsome....cant wait to see results of a better tmic!
BlackSTI2006 is offline   Reply With Quote
Old 09-24-2007, 02:42 AM   #19
slalom274
Member#: 29757
06 STI
Awesome, keep the updates coming!
slalom274 is offline   Reply With Quote
Old 09-24-2007, 01:41 PM   #20
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
I don't see the point to keeping the stock tmic, seems like a huge restriction
lawn boy is offline   Reply With Quote
Old 09-24-2007, 04:58 PM   #21
Pidro
Member#: 105364
Maybe this would answer some of your questions. Plus not everyone likes FMIC.
Eric
Pidro is offline   Reply With Quote
Old 09-24-2007, 09:40 PM   #22
teesutt
Member#: 127940
Evil shenanigans
IVe got a similar setup on an 05 sti.
Green 3"/8cm
Bushur Racing TBE
Helix Big TMIC
Helix 860cc FI
Typhoon Intake
TGV Deletes
Tuned via openecu
biggest problem during tuning was intake temps. i have ordered a turbo blanket as well as taken the stock snorkus intake and cut it right by the intake filter. helped out a little. i have yet to dyno the car but will hopefully get that done this week. i'll post my numbers up in this thread.
teesutt is offline   Reply With Quote
Old 09-25-2007, 02:11 AM   #23
STIheaven
Member#: 122366
nice numbers. are you guys now making your own tbe's?
STIheaven is offline   Reply With Quote
Old 09-25-2007, 05:41 PM   #24
AMS
Member#: 27854
STI, WRX, GTR, EVO,
Thank you again guys, We are planning on making our own Exhuasts and we already have a TMIC we are working on. Im sure a FMIC is not far off.
Eric
Old 09-26-2007, 04:44 AM   #25
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
Eric
Nice.
bubba03wrx is offline   Reply With Quote
07 WRX - Blouch DOM 3 8cm housing vs. 10cm housing! Equilibrium Tuning Proven Power Bragging 51 04-23-2013 07:23 PM
2007 STI SWP Built AMS motor and AMS 30R kit AMS Private Vehicle 'For Sale' Classifieds 34 05-05-2010 11:29 AM
FPGreen IWG 3" Inlet 8cm^2 Hotside moswald80 Engine/Power/Exhaust 14 03-08-2009 12:39 PM
2007 STI, 20g vs FPgreen. Anyone have these? DannyGrant Proven Power Bragging 61 09-25-2008 06:24 PM
Pics of FPGreen w/8cm housing 3" inlet 34mm flapper QuickSilverSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 02-25-2007 12:08 AM
