Old 02-16-2012, 04:49 PM   #2626
Hubbard 0
Member#: 155366
Only R1
I'd look at extended cab trucks. They all have those type of windows.
Hubbard 0 is offline   Reply With Quote
Old 02-16-2012, 06:01 PM   #2627
SplatZ400
Member#: 84377
2011 335d
And earlier minivans had those in the back also.
SplatZ400 is offline   Reply With Quote
Old 02-16-2012, 06:11 PM   #2628
AWDPilot
Member#: 25058
'15 Legacy 3.6R
10 Subarus...and counting
AWDPilot is offline   Reply With Quote
Old 02-16-2012, 08:22 PM   #2629
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
http://www.jbugs.com/product/113847080C.html
These were the style I had on my VW bug. All metal construction.
cal_look_zero is offline   Reply With Quote
Old 02-17-2012, 03:03 PM   #2630
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Originally Posted by AWDPilot View Post
That might actually work, although its pretty ugly. I'd have to remove that last bit too for it to match up.
What year of trucks is that from?
Thats for an all-glass window, not a framed window.
Old 02-17-2012, 07:05 PM   #2631
Dex
Member#: 163775
2014 Ford Fiester ST
Murica Red
Dex is offline   Reply With Quote
Old 02-18-2012, 02:04 AM   #2632
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
510 latches look to be the best bet so far, but damn thats expensive!
Old 02-18-2012, 04:16 AM   #2633
Sidewindor
Member#: 166609
2013 Outback
http://www.ebay.com/itm/Rear-Window-...-/330401667908
I know that these are plastic also, but they are much cheaper than the Datsun replacements. Not sure if these would fit or not.
Sidewindor is offline   Reply With Quote
Old 02-18-2012, 02:00 PM   #2634
mechanizeddeath
Member#: 203335
2012 Ford Focus
Fleet Silver
Well at least there are plenty of sources for the latches, so you should be able to find something that will work.
I continue to check on this thread every couple weeks or so, and like everyone else here I'm keeping my eyes open for a block, though I doubt I'll find one here in Michigan.
mechanizeddeath is offline   Reply With Quote
Old 02-19-2012, 10:00 AM   #2635
Wolf700
Member#: 310760
1996 Impreza
Black & Blue
bump!
Wolf700 is offline   Reply With Quote
Old 02-22-2012, 06:08 PM   #2636
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Found some latches at Pick'n'pull on a 70's Corolla that should work. They mount nice and flat and their bolt holes are far away from the stock ones on the FF-1 so I won't have any overlap issues (FYI, the stock screw holes were just drilled into the frame, no actual threads for bolts or anything).
Also took the window squeegees from the Corolla since they were in perfect shape. Gonna take some work to get them to work, but I think they will do just fine.
Still waiting for my window channels though...
Old 02-22-2012, 08:09 PM   #2637
MdWstSubi
Member#: 310430
2003 WRX
has this build been going on for 5 years now? just joined nasioc btw!
MdWstSubi is offline   Reply With Quote
Old 02-22-2012, 10:33 PM   #2638
Dex
Member#: 163775
Murica Red
Can you post pics of the squeegees? I have no clue what you're talking about .
What company did you end up going with for the channels?
Old 02-23-2012, 02:06 AM   #2639
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Squeegees are the rubber bits that press next to the window as it goes up and down so rain doesn't get in.
The channels I ordered at O'reilys were some universal ones. Not sure if they will work until I actually see them.
Old 03-05-2012, 02:57 PM   #2640
Konrad02ts
Member#: 260009
2002 Impreza
Red
Sweet find! Yeah, I bet you don't have to worry about a check engine light popping up unexpectedly!
Konrad02ts is offline   Reply With Quote
Old 03-07-2012, 12:42 AM   #2641
importdriver
Member#: 96927
Found this in the local Kijiji ads.
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ354484669
importdriver is offline   Reply With Quote
Old 03-07-2012, 04:55 PM   #2642
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Toronto? Someone should pick that up, thats pretty clean.
Old 03-07-2012, 05:02 PM   #2643
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
And right hand drive.
RALLYT-WRX is offline   Reply With Quote
Old 03-20-2012, 07:24 PM   #2644
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Just got the window channel felt finally, and cut it to the correct dimensions for the frame and even test fit it. It doesn't fit 100%, but I tested it with the window in place and it slides nicely.
However, I do need to get some sort of adhesive to stick it on properly so it doesn't shift. What should I use for this?
Old 03-20-2012, 07:44 PM   #2645
asaturn
Member#: 166269
86 Standard
Alright folks, I'm having issues installing the rear side windows, one of my levers is broken and I'm concerned the non-broken one is about to break. They are made of REALLY brittle plastic and I'm concerned, so I'd like to replace them.
try the ones from a mid-80s GL or Standard 3-door hatch. mine has pop-out windows and look just like that.
they fit into holes in the glass and then have 2 set screws in the frame for the window. then the other side of the window is on 2 hinges.
I believe the correct name is pop-out window latch.
you could also go fancy and just get ones that work. vintage VWs use nice metal ones.
you could go even fancier and get replacements made out of aluminum:
http://ultimatesubaru.org/forum/showthread.php?t=113869
asaturn is offline   Reply With Quote
Old 03-20-2012, 07:45 PM   #2646
njwrxman21
Member#: 132568
03 wrx
wrb
How about spraying some 3m adhesive into a small cup and using a Q-Tip to spread it into the channel?
njwrxman21 is offline   Reply With Quote
Old 03-25-2012, 10:25 AM   #2647
Einimas
Member#: 176111
Look at 1988-1991 civic hatchback, rear windows open this way and the must be many at salvage yards.
Einimas is offline   Reply With Quote
Old 03-25-2012, 03:54 PM   #2648
Dex
Member#: 163775
Murica Red
No need for that. There is one specially made for this. I've used it before, it's called Super Weatherstrip and Gasket Adhesive from 3M.
http://www.3m.com/product/informatio...-Adhesive.html
Old 03-26-2012, 01:16 AM   #2649
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I'll see if anywhere local has that tomorrow.
Old 03-26-2012, 12:49 PM   #2650
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I was about to suggest that exact same product.
LOVE that stuff! Definately get that stuff. Some shops only carry yellow though, if you care.
BeBop86 is offline   Reply With Quote
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 10:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 06:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 01:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 08:58 PM
