Old 10-26-2007, 11:00 AM   #276
992.5RS
Member#: 72004
1999 2.5RS w/V5 Swap
*subscribed*
Cool project, Kosta!
992.5RS is offline   Reply With Quote
Old 10-26-2007, 03:06 PM   #277
johndingk2
Member#: 72499
04 Impreza STI
WRB w/Silver BBS's
What about front spoilers and side skirts? DO you know if that was ever a mod for this car.
Definately looking like a great hopeful final product.
Love all the black accents. Flat black wheels would fit the bill Ithink.
johndingk2 is offline   Reply With Quote
Old 10-26-2007, 03:58 PM   #278
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
There were never any aftermarket or OEM front spoilers or sideskirts for this car that I've found.
Old 10-26-2007, 07:22 PM   #279
Tuning @ FLI
Member#: 162699
02 GDB WRX STI
WOW, that is one of the rarest Subaru in North America...!
Tuning @ FLI is offline   Reply With Quote
Old 10-26-2007, 09:19 PM   #280
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Originally Posted by NALegacy101 View Post
I think the B-pillar blacked out would look really nice.
Seconded. Try a photochop with the window frames and B-pillar blacked out. I think it might look more hardtop retro.
linsavy is offline   Reply With Quote
Old 10-26-2007, 09:50 PM   #281
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Alright, here are some ideas for exhaust setups i've had...
#1 is a dual setup, side exit exhaust... Probably would be hard to do and might look ugly, but it was an idea none the less.
#2 is what i'm leaning the most towards at this point, using a X over muffler with the dual setup exhaust going along both sides of the car keeping it a true "dual" exhaust still.
#3 is using a 4-1 collector going into a 2" pipe and straight back to a regular muffler, the headers would be complicated with this setup but the rest would be very simple.
#4 has headers based on the FF-1 1300G Sports exhaust, which apparently has the front and rear ports seperate instead of each side seperate... Don't know why, but they got 95hp out of that setup so there might be a reason for it.
Let me know if you have any other ideas, I can post the templete I used for these pictures if anyone wants to have fun
And no, this exhaust doesnt need a catalytic converter so feel free to leave it out
Old 10-26-2007, 09:51 PM   #282
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
http://forums.nasioc.com/forums/show...&postcount=215
Old 10-26-2007, 10:28 PM   #283
CASSPER
Member#: 105397
any more pics?
CASSPER is offline   Reply With Quote
Old 10-26-2007, 11:29 PM   #284
cegpcola
Member#: 97987
The Wagon shaped
paper weight
Nice project!
To answer the thought you had on Exhaust # 4, they would have done this because of the Firing order and the pulse of the exhaust through the manifold. They made it that way that it does not allow exhaust gases from one cyinder firing to impede the flow/run at the same time through the same section of pipeas a cylinder ahead of it in the firing order. I hope the way I worded that makes sense.
I would actually do #3 or #4, but you could also do #2, but with the Manifold area setup like that of #4. They found something in that manifold setup, or they would not have been making it that way. I would imagine the exhaust pulse is the reason for them doing this though.
cegpcola is offline   Reply With Quote
Old 10-26-2007, 11:44 PM   #285
5spdfrk
Member#: 46407
blew
Needs a cage!
lol
5spdfrk is offline   Reply With Quote
Old 10-27-2007, 12:40 AM   #286
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That is actually correct. The firing order is 1-3-2-4 (1 being left front, 2 being right front, 3 being left rear, 4 being right rear) so having the front and rear exhaust ports running together makes more sense, but i'm not sure if the extra length of the pipe due to the far locations of the exhaust ports has an effect on that...
So really, the 4-1 collector is still probably the best performance wise.
Heres a diagram of the normal ff-1 exhaust versus the ff-1 "sport" for reference:
Old 10-27-2007, 08:26 PM   #287
thejaredhuang
Member#: 86206
2006 WRX Wagon
I'd go with 4. It has that OEM feeling.
thejaredhuang is offline   Reply With Quote
Old 10-28-2007, 06:55 PM   #288
chadm395
Member#: 161559
exhaust #3 haha
good luck on the car
chadm395 is offline   Reply With Quote
Old 10-28-2007, 07:16 PM   #289
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Day 9:
I spent most of today removing the "sound deadening material" from the driver and passagner footwell... MAN thats some tough work! But I did get most of it off, but theres a bit more that will need to come out once the whole dash is removed. You can also see how bad the rust is on the floorboard in some places...
I also removed a couple of metal clips and wrap things that were in the driver/passanger wells that were not being used or won't be used (plus, those metal clips welded into the chassis will be a pain in the ass when the car gets repainted! Might as well eliminate them)
As you can see, I also removed the seats... The driver seat I kept around just in case, but the passager one (other than the rails) is in the trash.
I ran the car for the whole day too, trying to burn off as much gas as possible. The oil pan is leaking as is the oil temp sensor and the water pump ever so slightly, but thats not a big deal really as I plan on rebuilding all that anyhow. The engine did run good the whole time though, no problems that I saw/heard which is awesome.
Anyway, here are the photos from today... Some interesting things to look at too, including the neat manual vents, and the VERY nice chromed e-brake and the odd shifter:
Old 10-28-2007, 08:31 PM   #290
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Stickied!? OMGWTFBBQ!
Old 10-28-2007, 09:01 PM   #291
rice h8r
Member#: 94524
^ wth......
time to overnight parts from Japan and CF floor boards!!!!!
rice h8r is offline   Reply With Quote
Old 10-28-2007, 09:51 PM   #292
wrxsnowstyle
Member#: 122973
02 WRX wagon
im liking the set up for exhaust 1 and 3, though 1 is a bit too street roddish for me. nice project, cant wait for updates!
after thought...2 is pretty nice looking too...
wrxsnowstyle is offline   Reply With Quote
Old 10-28-2007, 10:11 PM   #293
sharkmonkey
Member#: 118566
2005 WRX
Seriously, exhaust 4 all the way. There's a reason twin scroll manifolds look the way they do.
I'm glad you have this car, after reading some of the posts in this thread. I think you'll do right by it. GL man, if I was in your area, I'd definitely offer up my help.
sharkmonkey is offline   Reply With Quote
Old 10-28-2007, 11:54 PM   #294
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
I'm still shocked at how simple that car is.
Unfortunatly, my girlfriend can't see me driving one. That's gotta mean something.
For the exhaust, are you going just for power, or have you thought about keeping the exhaust manifold unequal-length to keep a bit of a burble? As far as the interior goes and apparent lack of OEM parts available, I think that the stripped out route would be pretty cool. A cage would probably do it wonders too.
t3hWIT is offline   Reply With Quote
Old 10-29-2007, 12:08 AM   #295
FujiHeavyFreak
Member#: 5405
Would you be able to relocate battery towards back of engine bay for better weight distribution?
I like the Peugeot wheels, it reminds me of an old Alfa:
FujiHeavyFreak is offline   Reply With Quote
Old 10-29-2007, 12:51 AM   #296
Chris05STi
Member#: 88248
2005 Subaru STi
Exhaust routing 3! I would say, get the rims that the Datsun 510 runs with, black spokes with a silver/polished lip!
Chris05STi is offline   Reply With Quote
Old 10-29-2007, 01:27 AM   #297
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That was actually my plan, but not because of weight, but because of the currently rusted-out battery mount/fender area. I want to move the fuse box into the interior as well, which will make some room for it.
I will have to go with a smaller-size battery, but thats ok, theres a perfect sized Odyssey battery and billet mount for that location:
Old 10-29-2007, 09:42 PM   #298
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
So... 6-point cage, or a 4-point cage and some extra body supports?
Old 10-29-2007, 09:54 PM   #299
Chris05STi
Member#: 88248
2005 Subaru STi
6-point with a trunk brace, and some bracing in the engine bay.
Old 10-29-2007, 10:03 PM   #300
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Engine bay is plenty braced. Trunk doesnt need bracing, it doesnt do anything
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 10:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 06:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 01:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 08:58 PM
