Old 10-29-2007, 10:06 PM   #301
Chris05STi
Member#: 88248
2005 Subaru STi
In the engine bay, you could triangulate that main brace going across to the firewall. Maybe some subframing? I would def do a 6-point with a harness bar.
Chris05STi is offline   Reply With Quote
Old 10-29-2007, 11:26 PM   #302
992.5RS
Member#: 72004
1999 2.5RS w/V5 Swap
I don't think this car will "need" a 6 point cage. If you wanted it for added saftey just do a 4 point behind the front seats. I personally wouldn't worry about a cage at all.
Nice progress! Love this project.
992.5RS is offline   Reply With Quote
Old 10-30-2007, 02:31 AM   #303
arfrce
Member#: 126130
06 Subaru STi
To bad it's not rear wheel drive. That thing would move with a hyabussa engine in it. lol
Like I said before a rally replica but with rear seats so you can take it around town and so forth. Heck you could even enter the vintage races in your area. I am sure they have some. If not you could start them at a road race track. I am sure some older datsuns would like to get on the track some time. I get a kick out of racing the subaru 360 on Gran Turismo. lol
arfrce is offline   Reply With Quote
Old 10-30-2007, 03:29 AM   #304
Krud
Member#: 155249
1998 2.5 RS
Rally Blue Pearl
eh, my exhaust idea.
Use it or not, just having fun.
Either way, awesome project, good luck
Krud is offline   Reply With Quote
Old 10-31-2007, 07:40 PM   #305
adoinfl
Member#: 79269
Wow..! great find-I bet if you buffed the paintwork and detailed it as it is you could quadruple your money in Hemmings or similar..Rust free Cali car too! g luck
adoinfl is offline   Reply With Quote
Old 10-31-2007, 08:29 PM   #306
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I'm not in this to make money. And if you read the thread, you would see its not a "rust free" car at all...
Old 10-31-2007, 08:31 PM   #307
Brainchild Customs
Member#: 127343
NCCA #1 Car '08
www.brainchildcustoms.com
this would look really good with some 15x8's and fender flares... do it
Brainchild Customs is offline   Reply With Quote
Old 11-01-2007, 03:44 AM   #308
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
very cool project....
I love exhaust #4! could be pretty sweet!
Numbchux is offline   Reply With Quote
Old 11-01-2007, 10:59 AM   #309
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
STiShawn is offline   Reply With Quote
Old 11-01-2007, 12:31 PM   #310
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
All right, I think the big thing to do now is pick the tires so I can figure out what offset I need for the wheels... So the big question is: Go with 14" or 15"?
For 14" tires, I will definatly go with the Khumo V700's that are on closeout at Tire Rack (Khumo Ecsta V700 185/55/14, Section width - 7.6", Tread width - N/A, Diameter 21.9", Weight 18lbs). The smaller rotational diameter will make fitament easy, as will the narrower section width. I don't know the tread width though because Khumo doesn't list their tire tread width (although it is a less accurate form of measurement).
For 15" though, I've got it narrowed down to 2 choices...
1) The Khumo SPT 15" (Khumo Ecsta SPT 195/45/15, Section width - 7.7", Tread width N/A, Diameter - 21.9", Weight 17lbs, Cost - $90.00) It has the lowest weight i've found, plus isnt too expensive, AND has the same diameter as the 14" V700's which will make for a nice lower profile on a 15" wheel.
2) The Advan A043 15" (Yokohama Advan A043 185/55/15, Section width - 7.5", Tread width - 6.6", Diameter - 23", Weight 21lbs, Cost - $109.00) This is actually a specialty tire for the MR-S. Its good because its narrow for a 15" tire but not too narrow, probably has a better chance of clearing everything than the Khumo... However, its taller than the Khumo (almost the same diameter as my current tires) so there might be more clearance issues there. Its also the most expensive option.
I'm still not sure which one I want the most right now, but I think i'm leaning towards the V700 due to the price... Thoughts?
Old 11-01-2007, 01:34 PM   #311
Chris05STi
Member#: 88248
2005 Subaru STi
Old 11-01-2007, 01:56 PM   #312
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Too wide and too tall
Old 11-01-2007, 03:55 PM   #313
Br0wnb0y
Member#: 109147
2005 LGT Not
BSM
Here's is a hybrid exhaust setup that I worked up. All I had access to was MSPaint, so it's crappy, but gets the point across. Oh yeah. I love this project! Of course, this piping could also run all the way to the back for a more conventional setup. I thought the side exit would be interesting, as long as it's just a subtle exhaust pipe, and not gaudy quad tips or a large 3" tip or something.
Br0wnb0y is offline   Reply With Quote
Old 11-01-2007, 07:25 PM   #314
Paranoid Fabrications
Member#: 140712
2008 WRX STI
well, looking at your tires, you need to roll those fenders looking at all the other pictures, i see the other cars all have flairs. better et to work
on th exhaust, down either side is best, as it looks like it you ran it down th center you would lose some ground clearance.
and good luck on the project, working on old cars is fun
Shane
Paranoid Fabrications is online now   Reply With Quote
Old 11-01-2007, 09:18 PM   #315
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I do want to flare the fenders a little, but its a little different than normal since these fenders already have a bend in them already, and the side of the car is completely flat otherwise...
The exhaust piping can pretty much go anywhere, is the same clearance regardless
Old 11-01-2007, 10:11 PM   #316
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thoughts?
Old 11-01-2007, 10:12 PM   #317
flystiguy14
Member#: 74416
91 SS leggy
pearl white
So how do you deal with all the rust, just get some sheet metal and weld it in? as far as fenders go how do you get those when you need them?
flystiguy14 is offline   Reply With Quote
Old 11-01-2007, 10:13 PM   #318
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Thoughts?
Not bad, but it still looks like its missing something. Body kit perhaps maybe?
Old 11-01-2007, 10:16 PM   #319
dvon1981
Member#: 101442
2008 Impreza 2.5i
Dark Gray Metallic
Thoughts?
can't say i'm a fan, needs something with spokes. a BBS style multispoke would look nice
dvon1981 is offline   Reply With Quote
Old 11-02-2007, 02:30 AM   #320
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Anyway, I think I found where to get the right seats for this car from: http://www.classiccarseats.com/
Old 11-02-2007, 03:12 AM   #321
thejaredhuang
Member#: 86206
2006 WRX Wagon
Thats cool, but I'd make it easily swappable for a modern seat so you have some more support when you track.
thejaredhuang is offline   Reply With Quote
Old 11-02-2007, 08:49 AM   #322
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
Thoughts?
Ewww.
SjpWrx is offline   Reply With Quote
Old 11-02-2007, 09:28 AM   #323
Drnkirishm
Member#: 87386
03 Sonic WRX
02 Blaze 4AT
13 or 14" Panasports would look good or old school BBS. The black trim doesn't flow with the white paint.
Drnkirishm is offline   Reply With Quote
Old 11-02-2007, 10:28 AM   #324
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Those are classic "look" seats with modern support. Look at the detail photos, they have very good bolstering and leg support compaired to lots of other newer seats.
None of which can be found in a useable offset or bolt pattern for this car...
Old 11-02-2007, 12:48 PM   #325
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Thoughts?
I think it looks amazing / would look more amazing in real life than the chop. So far this is my favorite wheel style for the car because it matches the contrast of the white against the shadow trim, while still keeping a classic look
This thread is SWEET. First I've checked back since it was at page 7. Stickied ftw
silverF4turbo is offline   Reply With Quote
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 10:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 06:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 01:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 08:58 PM
