Old 12-01-2008, 10:32 PM   #1276
messyslick88
Member#: 194878
2004 wrx
love the grateful dead bears
messyslick88 is offline   Reply With Quote
Old 12-02-2008, 08:20 PM   #1277
Subarutex
Member#: 24241
I have a solution to your spacer problems.
Might be costly... but get a set of spacers made like the ones project kics sells.
Those nuts can be bought separately (Armin at W1 looked it up for me) for $2 a piece. By using these special nuts, you can get the thickness of the spacer down, instead of like 1" of thickness, more like 1/2".
So, buy the nuts, have the spacers made with whatever standard studs you want. Then you just may have to cut the stock studs down so they don't poke out of the spacers.
I put a set of these on my 5 lug converted Brat, and they worked out pretty slick.
If you go the custom route, and its cheaper for you to buy more qty. I would be interested in a pair of 4x140 spacers... or a full set of 4x140 to 4x100 converting spacers. If you don't know any machinists I might be able to come up with someone.
Subarutex is offline   Reply With Quote
Old 12-02-2008, 08:42 PM   #1278
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Give me a couple weeks to figure out exactly what I need...
I did think about the "adapters" and going with a more standard bolt pattern, but there aren't any specific wheels i'd want if I did that.
Besides, I only need it for the rear since these wheels will work fine on the front.
Old 12-04-2008, 09:07 PM   #1279
992.5RS
Member#: 72004
1999 2.5RS w/V5 Swap
It's been a while since I checked this thread! Awesome progress man!! Sorry it I missed it, but how is the engine coming along?
992.5RS is offline   Reply With Quote
Old 12-04-2008, 09:34 PM   #1280
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I've got someone pulling some 4-port heads from a '74 up in Washington
I think I might use a 1.6l block with the heads, I know of a brat at a local pick n pull with the engine still intact...
Old 12-08-2008, 11:33 AM   #1281
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
I am so glad you are still going with this resoration. Such a neat car.
MFR Sweep is offline   Reply With Quote
Old 12-11-2008, 11:11 AM   #1282
Einimas
Member#: 176111
What about front brakes?
Einimas is offline   Reply With Quote
Old 12-11-2008, 12:31 PM   #1283
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Been working on the car all day, and even test fit the wheels.
There is a slight problem with the offset...
As you can see, it BARELY clears the suspension, has about 1mm of clearance, but thats NOT including the tire which will be wider.
Have you considered some custom trailing links... I'm sure a decent mini-truck shop could fab some that cut inboard more to clear, some DOM, some TIG and you'd be back in business..
Old 12-11-2008, 12:33 PM   #1284
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Kos.... go pick up a Mini-truckin mag... seriously.. They run adds all the time for suspension parts, and the one which I can't remember off my head, offers custom spacers like above.. if you were to go that route..
Old 12-11-2008, 09:03 PM   #1285
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Front brakes aren't changing. I can't find the JDM disc brakes, and I can't even find the stock drum brakes... So I won't screw with it.
The whole rear suspension would require a re-design to do that. I'm not willing to go that far at this point.
I've got a source for spacers, but the problem still is the studs. I'm still waiting on someone who is getting some '74 rear drums for me to see if they will work.
Old 12-13-2008, 09:56 AM   #1286
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Nice lift kit! Is that a custom 2x4?
Old 12-13-2008, 10:21 AM   #1287
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
its coming along nice!
shadowmd is offline   Reply With Quote
Old 12-18-2008, 09:45 PM   #1288
dan13
Member#: 157726
hunk of metal
Updates!!!
dan13 is offline   Reply With Quote
Old 12-18-2008, 10:57 PM   #1289
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Nothing much to update right now. I'm just mocking up the dash and other bits, and bought a space heater for the garage cause its so damn cold in there now Thats about it.
Old 12-19-2008, 04:32 AM   #1290
TriStar482
Member#: 197884
2008 WRX Sti
haha thats awsome man. good find
TriStar482 is offline   Reply With Quote
Old 12-20-2008, 08:08 PM   #1291
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Did some more "mock up" today to figure out if I needed any more bolt/screw holes and such, and to figure out what exactly I need to do for interior panels. I thought maybe I might be able to re-use some of the press-board pieces, but it looks like thats not a possibility. I can use them as a template though.
The rear panel actually needs to be wider and also shorter so it fits its space better. I don't plan on running a rear seat, so i'll need to cover some areas there that aren't currently covered. I'll also have to extend the rear under-window area a bit to cover some of those holes. I'll probably make that out of cardboard next weekend if i'm not busy.
As you can see, i'm trying to figure out what I want to do about gauges. Since I wanted to run a tach and oil temp/water temp gauge, I figure I might as well do a whole custom dash... I went over which items I'll need to operate the heater/vents, but I figure I can trim off a bit of that lower dash piece since I won't be running a stereo. I can also put some power-plug sockets in the holes on the dash on either side (I have some extra ones from a forester dual-plug kit).
I'm not sure what to do about turn signal bulbs... I havent found anywhere that sells them yet. Other than that, I have a good idea of what size gauges I want to run now. I plan on doing a mechanical speedo, 8000rpm tach, oil temp gauge, water temp gauge, voltmeter and fuel gauge. I'm not sure which fuel gauge to get, I need to figure out what the sensor range is for the stock fuel level sensor. I'm also not 100% sure about mechanical speedos and using the stock speedo wire, so I need to look into that.
But ya, I do plan on keeping the dash like that, except powder coat it black... Maybe do a red vinyl stripe to cover up the holes above where the gauges will go. The "wood-look" surface is completely non-usable, and ugly anyway
Oh, and I still havent decided on a spot to mount the MSD ignition... But there are several options I can see now.
Here are the pics from today:
Old 12-20-2008, 09:24 PM   #1292
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
nice work man!
Old 12-20-2008, 10:43 PM   #1293
myth
Member#: 195705
Default Subscribed.
I love it
myth is offline   Reply With Quote
Old 12-21-2008, 12:47 AM   #1294
02redwagone
Member#: 87067
02 Old but tasty
SRP
Simply awe inspiring.
02redwagone is offline   Reply With Quote
Old 12-21-2008, 03:23 AM   #1295
SILINC3R
Member#: 198052
9105 Legacy SS/SpecB
Rio Red and SWP
yea so it looks like you dont know what your doing lol. very nice find and good progress it looks like. cant wait to see it finished.
SILINC3R is offline   Reply With Quote
Old 12-21-2008, 02:26 PM   #1296
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 12-21-2008, 03:42 PM   #1297
iRick.
Member#: 158155
No offense...
But I'm currently wondering how old I will be when this car is finished
One long ass project you got there...end result will be sick.
iRick. is offline   Reply With Quote
Old 12-21-2008, 03:48 PM   #1298
992.5RS
Member#: 72004
Well it takes a long time to restore a car to this caliber. Took my dad 4 years to restore his car.
Originally Posted by jibtastic View Post
No offense...
Old 12-21-2008, 04:21 PM   #1299
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I want to be done before I turn 30 (February 2010)
It should be possible. Its not exactly a complex car. It will go quickly when the body work/paint is finished.
Old 12-21-2008, 04:26 PM   #1300
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Dang Steve, you're knocking on a little
2.5RSMatt is offline   Reply With Quote
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 10:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 06:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 01:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 08:58 PM
