Old 08-04-2011, 05:25 PM   #2401
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Originally Posted by pheonix991 View Post
Wish I was in cali, I'd help out. Do you have a schematic? Do you know how long your wires need to be?
I have the factory schematics. My problems range more in the area of trying to sort out the things I've added like the MSD, the new horns, etc.
Here is a good example of what I'm trying to do with the new Alternator, which has an internal voltage regulator unlike the factory one:
Originally Posted by RS drifter View Post
you need fans? I have a dual fan core from a fluidyne radiator, I'd be more than happy to donate it to the cause.
I'll take measurements to see if it will work for you.
Ya, let me know the dimensions of the fan. I'm not sure what size of fan I'll need for the radiator in terms of diameter, but I do know I don't have a lot of depth to work with...
Old 08-04-2011, 05:40 PM   #2402
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
okay cool, well it looks like the height is about 14.5 the length is about 25 and depth is around 3.5
RS drifter is offline   Reply With Quote
Old 08-04-2011, 09:13 PM   #2404
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Thats way, way too big!
Originally Posted by bue car View Post
May I suggest Keener from Iwire for help? He is in Lake Forest I think?
Socal isn't exactly close for me.
Old 08-04-2011, 09:17 PM   #2405
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
Hahahaha! nevermind then, will a single WRX fan work? I have a couple of those laying around.
Old 08-04-2011, 10:29 PM   #2406
jgartland
Member#: 185401
2004 Forester XT
JBP
mentioned your build to another tech at my dealership the other day, hes been with subaru since 1970, he said he had an FF-1 sedan in lime green when they came out. so jealous hahha. speaking on terms of old gems, this came in for service the other day:
1983 GL-10, all originial, 46,000 miles.
good luck with finishing everything up! i know its a long journey haha
jgartland is offline   Reply With Quote
Old 08-05-2011, 02:11 AM   #2407
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
My guess is that will probably be too big as well. I've been looking at the "slim" fans from various companies so I have an idea of whats out there but won't know what will fit until I see the radiator in person.
I do have one of the EA81 A/C fans thats shaped for tight spaces, but its a little large too and I might want to run two fans.
Old 08-05-2011, 09:44 AM   #2408
Hubbard 0
Member#: 155366
Only R1
Do you have room for pusher fans? Could increase overall room and even keep the engine bay cleaner. Mounted up front, they're not quite as efficient but I don't think that engine will be generating massive amounts of heat.
Hubbard 0 is offline   Reply With Quote
Old 08-05-2011, 04:33 PM   #2409
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
I have less room in front than in the back.
Old 08-05-2011, 08:46 PM   #2410
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Does anyone know what this is?
The black dot on the front is supposed to be where a bulb shows light through, and there is a switch underneath. It has 3 wires going to it, but I can't find it on any of the factory diagrams or parts/service manuals.
Old 08-06-2011, 12:59 AM   #2411
b00st3d
Member#: 9891
2015 RC-F
Ultra White
high beams + indicator maybe?! i know older cars used to put the high beam switch on the floor and you would hit it with your foot...just a guess?
b00st3d is offline   Reply With Quote
Old 08-06-2011, 01:16 AM   #2412
Dex
Member#: 163775
2014 Ford Fiester ST
Murica Red
Sounds funny, but it may be a seat belt light lol. My Nova has one low on the dash like that. Doesn't work anymore, but it's funny that it's there for how old it is. For the longest time I had no clue what it was until I shined a light through it.
Dex is offline   Reply With Quote
Old 08-06-2011, 04:36 AM   #2413
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
High beams might be possible, I'll have to trace the wires and see if that might be it.
Its not seat belt lights, there aren't any wires to/from the belts
Old 08-06-2011, 08:17 PM   #2414
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
OK, I traced back the wires for that thing...
1 wire goes straight to the brake proportioner (passanger footwell)
The other wire goes to a spot where it splices into 3 other wires:
1 goes to the gold fuse/turn signal switch thing
1 goes to the dome light wiring
1 goes to the old radio/cigarette lighter area
Any ideas???
Old 08-06-2011, 09:28 PM   #2415
AWDPilot
Member#: 25058
'15 Legacy 3.6R
10 Subarus...and counting
Separate dimmer switch maybe?
AWDPilot is offline   Reply With Quote
Old 08-07-2011, 08:27 PM   #2416
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
For those who were asking, here are some wiring diagrams. None of them exactly match the car:
Old 08-10-2011, 08:31 PM   #2417
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Question:
I don't have a positive or negative wire yet. What should I do for that?
Old 08-10-2011, 08:39 PM   #2418
pheonix991
Member#: 154173
2006 STI
What ever you do, be sure to use a fairly large gauge wire. You don't want to have to do a "grounding kit" on your rebuilt car.
pheonix991 is offline   Reply With Quote
Old 08-10-2011, 10:30 PM   #2419
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
NAPA sells these nice pre-built positive and negative wires in specific lengths, but I don't have a good enough understanding of how they work to know what to get yet...
Old 08-11-2011, 12:54 AM   #2420
GuamSTI
Member#: 210071
04 STI
Are you completely re-wiring or are you using the old harness and maybe tidy it up and upgrade a bit by installing relay's to take some of the load on the switches?
GuamSTI is offline   Reply With Quote
Old 08-11-2011, 02:58 AM   #2421
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Well I don't know, I don't know anything bout relays so... Don't know. The hella horns have a relay, and I think my power socket kit has a relay, so I can add those I guess.
All I know is the original positive/negative wires from the batter are useless. Not only did I move the battery but they were falling apart due to age/use.
Old 08-11-2011, 08:10 PM   #2422
GuamSTI
Member#: 210071
04 STI
The car has a negative ground system right? If you search relays they are many diagrams and they are used for different things like headlamps, horns, electric fans etc. it is very simple. They can be wired into an existing system.
An example:
Starter, I positive wire from the battery (+) and one wire from the ignition switch to the solenoid.
Ignition coil, 1 wire from the ignition switch or fuse box to the + terminal of the ignition coil and the (-) marked terminal to the contact point and condenser inside the distributor.
Alternator, 1 wire goes to the battery from the alternator this is the larger gauge terminal usually round. The smaller contacts are for a wire that also goes to the ignition and another goes to the charging light.
I hope some of these help. Good Luck having a tester would be of great help.
Old 08-11-2011, 09:03 PM   #2423
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
For the starter, you mean the large red cable goes straight to the starter from the positive terminal, correct? And there is a second wire that goes to the Ignition from the starter? I found that in my wiring harness.
For the ignition, everything goes straight to the MSD. Both the distributor AND the coil according to the diagrams from MSD. It also says one wire goes to a switched source and another to the positive battery. For the switched source, where should I be connecting it in according to those diagrams a couple posts up?
For the Alternator I'm having more issues. The new alternator has 3 wires basically (1 plug, 1 which connects to the screw spot which is I presume the "Insulated" wire as its thicker and white) while the old one had 4. I can't figure out what should be done to correct this and eliminate the voltage regulator.
I'm also not sure about eliminating the interior lighting I'm not using. I'm also not sure about the tachometer.
The horn I figure I can use the old wiring but add the Hella relay, would that be the correct thing to do?
And the power socket, should I use a relay for that? The socket I have came from a "kit" for like a 2000+ double-socket Forester so it has a wiring diagram and such inside. But the old power socket was just ONE wire going to it as per the diagrams.
Old 08-11-2011, 09:11 PM   #2424
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Oh, and where the heck does the negative terminal lead to???
Old 08-12-2011, 10:05 AM   #2425
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
oh wiring...how wonderful! Keep up the good work!
King of Poop is offline   Reply With Quote
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 11:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 07:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 02:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-30-2008 12:32 AM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 09:58 PM
