Old 09-23-2007, 04:13 AM   #1
bnb_lee
Member#: 142327
06 sti
steel gray
Default 93 fwd to 6 speed awd swap how much?
i have a 93 L fwd want to convert to awd w 6 speed set up. just something i've been tossen around, love the car just want to know what price to expect. parts and wiring, everything except interior. need motor, trans, driveline ,breaks. want a nice project. dont really know if a 5 speed is a better idea just because its cheaper or if 6 speed is overkill. by no means do i want to just replecate my sti with an L but knowing the life span of a heavly used 5 speed why not just spend the extra. want opinons thanks
bnb_lee is offline   Reply With Quote
Old 09-23-2007, 05:50 AM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
well it really depends on your plans for the car.
if you are upgrading ur 1.8L to a 2.5L NA, then a 5speed is still okay. but if you are thinking about going with a turbo motor like a WRX or STI, then i suggest a 6-speed for the extra assurance that it most likely wont break.
bottom line, it all depends on your power goals and what you plan on doing with the car.
vinceGC8 is offline   Reply With Quote
Old 09-23-2007, 10:00 AM   #3
bnb_lee
Member#: 142327
06 sti
steel gray
i gess my question is really not what is stronger i want to do a sti swap and wondering about price. 6G's ? 10G's?
Old 09-23-2007, 10:18 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
in a FWD
option A
04-06sti 6speed
6 speed cluch
3.9 rear diff & axles
rear subframe
gas tank
peddle box
Master cyl
clutch hose
front axles
4-4500
option b
07sti 6speed
6 speed cluch
3.54 rear diff & axles
rear subframe
gas tank
peddle box
Master cyl
clutch hose
front axels
5-5500
option c
04-07sti 6speed
6 speed cluch
04-07 rear diff & axles
rear subframe
gas tank
peddle box
Master cyl
clutch hose
sti hubs brembos and wheels that clear
front axles
6-7000
Old 09-23-2007, 10:37 AM   #5
bnb_lee
Member#: 142327
06 sti
steel gray
Thank you i have a lot of planning to do and some money to save just want ideas.
Old 09-23-2007, 12:56 PM   #6
Spilner
Member#: 63977
2005 STi
Jaxx where did you get those prices from? I've been looking into a sti 6 speed in my L(already AWD though)
only thing is I dont want to sue the brembos since I dont want to have to run 17" tires year round
Spilner is offline   Reply With Quote
Old 09-23-2007, 01:53 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
missing some custom rear axles or rear hubswap and axles in those parts lists...take your pick
I did an R180 with DSS stage 5 rears with the r180 inboard stub and standard outside hub...
then used the subaru stubs upfront and standard sized subaru fronts (customs stage 5's still being made)...6-spd driveshaft...you can use a 6-spd or 5-spd turbo clutch setup but must use the appropriate flywheel as well.
you will need to convert to a hydraulic pedal assembly too...tried to use my cable clutch but had to give into the ****ty hydro conversion
sourced my entire 6-spd swap for $4200 shipped excluding the axles...the rears retail for $1200 a set and the fronts, well just stick with the stubs unless you plan to make big power
93 l fwd to 04 wrx awd sense of nature Subaru Conversions 63 06-26-2011 10:35 AM
What will I need to swap wrx to 6 speed subadupa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-03-2008 10:12 AM
5 speed to 6 speed swap zipossible Transmission (AT/MT) & Driveline 3 10-16-2006 01:38 PM
wtb 93-98 gc 5 speed awd or svx or legacy gt turbocolin Tri-State Area Forum 4 02-18-2005 11:57 AM
AT to MT swap during JDM STi swap, how much extra wiring? garface Subaru Conversions 9 08-09-2003 06:59 PM
