Old 09-23-2007, 12:17 PM   #1
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
Default Stage 2 04 wrx 13.2
04 wrx with 70k miles
AP stage 2 flash - not custom tuned
TXS RFL tbe catless
TXS up
TXS mbc
perrin lwcp
greddy timing belt
exedy stage 1 clutch+lwfw
PPG 1-4 helical cut synchro
Str8Gone is offline   Reply With Quote
Old 09-23-2007, 10:16 PM   #2
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
oh yea no powershifting and plenty of wheelspin in 1st
Old 09-23-2007, 10:34 PM   #3
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
Nice. Looks like that run on the left could have been your best but it looks like you might have messed up the 2-3 shift briefly?
turbo tecnica is offline   Reply With Quote
Old 09-23-2007, 10:40 PM   #4
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
The run on the left I had worn out yoko es100s on stock wheels, the two on the right I had 7.5 rotas with p-nero zeros worn out and most of the interior removed. For some reason I got more wheelspin with the wider wheels, I think they are all seasons though
Old 09-23-2007, 10:44 PM   #5
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
nice setup, how does that clutch hold up to the dragstrip, Im thinking of swaping clutches to the exedy stg. 1
clemsonteg is offline   Reply With Quote
Old 09-23-2007, 10:54 PM   #6
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
like every other one
hmmmmm nice
qUicKnesS05 is offline   Reply With Quote
Old 09-24-2007, 06:55 AM   #7
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
A new set of tires, a bit of work on the 60ft, and youre doing 12's.
cucamelsmd15 is offline   Reply With Quote
Old 09-24-2007, 07:04 AM   #8
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
nice job... you should see a 12.9 with that trap
very impressive for OTS map
FCmaniac is offline   Reply With Quote
Old 09-24-2007, 07:11 AM   #9
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I wish I had those gears...
rexman2002 is offline   Reply With Quote
Old 09-24-2007, 07:51 AM   #10
STi-Spec C
Member#: 75923
2004 18g WRX
do you know how much weight you saved from removing the interior?
STi-Spec C is offline   Reply With Quote
Old 09-24-2007, 09:24 AM   #11
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
I don't know how it went for the OP, but for me it is a disaster. Definately upgrade your clutches or you'll burn them sooner than you expected. I don't usually launch hard, but this past saturday, I tried to launch a bit harder than usual and burned my clutch. I didn't check what rpms I launched but when I checked the video, I launched @ 5.5k, a bit extreme for stock clutch.
WRX4eva is offline   Reply With Quote
Old 09-24-2007, 09:39 AM   #12
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
if you burned your clutch that bad then it means you held it in too long. the higher the rpm, the faster the slip should be.
AWDWRXLOVER is offline   Reply With Quote
Old 09-24-2007, 09:50 AM   #13
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
i've done close to 100 auto-x launches on my stock clutch at 5k and my clutch still holds like no other. You not slipping quick enough!
r0nzar is offline   Reply With Quote
Old 09-24-2007, 10:07 AM   #14
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 [email protected]
nice man!!! wish i had those gears as well...
boostdog is offline   Reply With Quote
Old 09-24-2007, 11:19 AM   #15
WRX4eva
Member#: 103343
You are 100% correct. I was doing fine till I decided to launch without checking my rpm's also with a passenger and blasting music LOL. I should have been more careful. Oh well here we go exedy clutch+flywheel.
Old 09-24-2007, 11:27 AM   #16
AWDWRXLOVER
Member#: 50267
02 built hybrid
is your clutch slippn now?
Old 09-24-2007, 11:48 AM   #17
Newera09
Member#: 125294
how much did you end up paying for your gears total. Trying to get some prices before I make the move to either an even bigger turbo than the VF39 or just go for the new STi.
Newera09 is offline   Reply With Quote
Old 09-24-2007, 01:14 PM   #18
WRX4eva
Member#: 103343
Its not that bad yet. After Saturday's attempt, I smelled clutch burn. I can feel the clutch slip when I try to push a bit on depart. (Not launch).
Old 09-24-2007, 01:25 PM   #19
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Great times man.. your traps are good your engine is making good power with the stock turbo
PaulRex is offline   Reply With Quote
Old 09-24-2007, 01:34 PM   #20
Crazy D
Member#: 35927
02 wrx
Nice job...for sure you'll be in the 12's soon.
Crazy D is offline   Reply With Quote
Old 09-24-2007, 01:50 PM   #21
WRX4eva
Member#: 103343
Sorry, didn't mean to steal your thread, back on topic~!!! Great times, really. I don't know what I'll be running on my 20g set up this wednesday.
Will let you guys know. I hope my clutch holds up couple of runs.
Old 09-24-2007, 01:50 PM   #22
bjonesy
Member#: 150820
how much did you pay for those gears? im lookin into strenghtening my tranny up before i start making more power.
bjonesy is offline   Reply With Quote
Old 09-24-2007, 05:50 PM   #23
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
Thanks alot guys I appreciate the compliments, the clutch is awesome for the track, it gets me very consistent launches and its relatively new..installed last Oct. The weight removed was about 100 lbs. I also have a perrin y-pipe that I didnt list. Im planning on getting a perrin afta maf hose, hard inlet, apexi induction box and air filter since I have a ram air from the foglight hole, some headers, fuel rails, other misc. small stuff and then a custom tune at agile. Brakes and tires are on the list next though since Im in dire need.
Old 09-24-2007, 06:07 PM   #24
qwkwrx
Member#: 56096
2005 WRX
psm
nice runs...is it bad to run a lightened pulley AND flywheel??
qwkwrx is offline   Reply With Quote
Old 09-24-2007, 06:39 PM   #25
AWDPirate
Member#: 131427
burn, shmurn. its the manliest scent of them all!
AWDPirate is offline   Reply With Quote
1998 Stg. 2 04 wrx swapped 2.5 RS!!!! 6500!! civicej8 Private Vehicle 'For Sale' Classifieds 27 03-11-2009 06:18 PM
Low Boost on Stage 2 04 WRX jeffk182 AccessPort 2 11-10-2007 08:10 PM
So CAL: Gauging interests Stage 2 02' WRX wagon 2 tone paint, extras. unfadeable wagon Private Vehicle 'For Sale' Classifieds 11 01-16-2006 06:33 AM
For sale: Stage 4+ 04 wrx norexyet Tri-State Area Private Classifieds 4 01-15-2006 01:24 AM
First time at the track thread Cobb Stage 2 04 WRX elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 53 11-10-2004 12:02 AM
