Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 09-23-2007, 05:06 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default i need a wrx power steering pump banjo bolt in MKE asap
it looks like my major power steering pump leak is from banjo bolt since its a different style bolt. It looks like I need a tappered bolt for it to seal in the pump correctly. If anyone has one laying around in the milwaukee area I'll buy it from you asap if it looks like what I need.
scobaru is offline   Reply With Quote
Old 09-23-2007, 05:36 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Are you sure it's the bolt, and not a missing crushwasher?
Old 09-23-2007, 09:12 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I've never taken a wrx pump apart so its possible. I have the oem washer that the RS's use that looks to be teh same as the wrx ones. the oem washer is the 1 piece design one that slides onto the bolt from the top nothing near where i believe it needs to get sealed. Now if theres a crush washer that belongs where the bolt touches the pump at the bottem I'd need that I guess. I don't have a diagram that I can look at to really know for sure
Old 09-24-2007, 01:19 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Danny, Sorry I could'nt get back to you via pm's earlier. Remove the bolt and look to see if it has been stretched or has any thread damage. Take the bolt to a parts store and get a couple copper or aluminum crush washers that fit it. It should do the trick.
You may also want to check the threads in the pump. Look for cracks in the casting.
Tim Sanderson is offline   Reply With Quote
Need help with power steering pump banjo bolt assembly hybrids220 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-20-2010 09:38 PM
wtb: power steering pump banjo bolt scobaru MWSOC Private Classifieds 1 05-19-2008 03:36 PM
Do I need a WRX power steering pump?? (02 USDM ej20 > 99RS swap) Stg2lgcy00 Subaru Conversions 16 07-23-2005 12:10 AM
Need a WRX power steering Pump ASAP! BlackSnake Mid West Subaru Owners Club Forum -- MWSOC 0 07-06-2005 07:44 PM
Power Steering Pump banjo bolt socket is FUBAR NavyBlueSubaru Service & Maintenance 4 03-26-2004 10:49 AM
