Old 09-23-2007, 06:53 PM   #1
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
Default Brembo Caliper mounting threads slightly stripped what to do?
Well, I was taking off the brakes today to replace the rotors and pads and it looks like one of the PO's had a gorilla put the mounting bolts in. The top one was tight, but came out fine. The bottom one appears to have taken about half a thread in the middle of the caliper with it. I am off to find a replacement bolt now, but I am unsure what to do about the caliper. I ran the threads with the good bolt from the top and it threaded right through. I looked up the torque (114 is insane!!!) and using the good bolt bolted the caliper back on and ran it to 80ft. lbs(the limit of my torque wrench - I will try to borrow one tomorrow) and then gave it a bit more and it held. So the question is, if I can either clean the threads on the bolt or get a different bolt at the auto parts store, do I need to worry about it? It is tempting to torque them down and see if they hold... What do you guys think? I am afraid of doing more damage if I try to get a helio coil(which I've never even seen). What does a Brembo run from Subaru? Are they usually available or is the car toast for a long time? Thanks in Advance.
dogfrndnew is offline   Reply With Quote
Old 09-23-2007, 10:15 PM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
This is a common occurence, it's happened to me twice (and I always use a torque wrench). I used Helicoil in the damaged threads and it worked perfectly. It's very easy to use, just make sure you drill and tap the hole perfectly straight.
boost junkie is offline   Reply With Quote
Old 09-23-2007, 10:31 PM   #3
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
So your vote would beto go ahead and drill it out? Is this something you can do while it is on the car? If not can I do it with a regular drill and bench? Ihave a vice, but it is probably not big enough for the whole caliper and it would chew it up I think anyway? Also, on heli-coil website the mention a variety of types ie standard, screw lock, tangless and thread repair kit. Any idea what you bought? Did you have to order it or are they carried in auto parts stores? I went to advanced auto tonight and they had about 4 sizes just none as big as I needed. By the way I think the bolt is m12x1.50 does that agree with what you bought? I am calling Subaru tomorrow to find out whether they have a bolt and also what the rotors run if nec. and if they are avail. Thanks for your help. I wanted to go to my first subie meet the 29th, but now the chances are starting to look dim.
Old 09-23-2007, 10:34 PM   #4
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
As an addendum, I was thinking about it and if I have the rotor off and bolt the top bolt in, wouldn't it hold it tight and straight enough to drill for the helicoil?
Old 09-23-2007, 10:40 PM   #5
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Yes the thread pitch is M12x1.5 and I got the kit at NAPA. Call around to some local auto parts stores and see if they have it in stock, it shouldn't be too hard to find. I got the thread repair kit, which comes with a tap, 6 inserts, and the insert tool. You have to buy the drill bit on your own but it says what size to use on the package. You can do it with a hand drill, just get a friend to help you. One person hold the caliper steady (I used a block of wood underneath it to lean on) while the other drills. Just take your time and make SURE you are drilling straight. The aluminum is soft and you will go through it quickly. Same goes for tapping the threads, take your time and keep checking to make sure it's going in straight. As long as you are careful it's a piece of cake, only takes about 20 minutes.
Old 09-23-2007, 10:41 PM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
You could probably do that, although I think it's easier to get it straight with the caliper off the car.
EDIT: On second thought, no you can't. The hole you are drilling is larger than the opening in the caliper mounting bracket so you can't go through it. Take the caliper off the car and make sure you crimp or plug the brake line to prevent too much fluid from coming out and running the reservoir dry.
Old 09-23-2007, 10:57 PM   #7
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
Is it really tricky to get it straight w/o a drill press? I am a little frightened at this point since last night I parked a running car with squeaky brakes and after about an hour this afternoon have a $20k+ pile of junk in the garage. I am wondering whether I should just look into a machine shop or whether it can be done in my garage. I used to have Jeeps...not nearly as neat as the sti but not nearly as fragile either. :-)
Old 09-23-2007, 10:59 PM   #8
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
It's not that hard, I just stood over the caliper with a drill while my friend held it and eyeballed the drill bit to make sure it stayed straight. It would definitely be easier with a drill press but if you have a steady hand you can do it without. If you really feel uncomfortable doing it I imagine a shop wouldn't charge too much to drill and tap it for you.
Old 09-23-2007, 11:19 PM   #9
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
One final dumb question for the evening, Do I need to bleed all four brakes if I am only pulling the front one?
Old 09-24-2007, 11:23 AM   #10
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Can't hurt...it's unlikely that air will work it's way into the other lines but it's worth the few dollars for another bottle of fluid to be sure.
Old 09-24-2007, 11:52 AM   #11
andy sti
Member#: 97350
'08 STI
My threads are getting pretty trashed too. I may be doing this soon. Thanks for the info Dan.
andy sti is offline   Reply With Quote
Old 09-24-2007, 12:18 PM   #12
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
No problem Subaru was dumb to use mild steel bolts for an aluminum caliper since they tend to fuse together. Higher end companies like Porsche use specially treated caliper bolts to prevent them from seizing in there. I'm actually tempted to go with something other than stock bolts but at this point two of my mounting points have Helicoil so I might as well just wait until the others let go and Helicoil all of them. It's a whole lot stronger than the stock threads anyways.
Old 09-24-2007, 01:27 PM   #13
dogfrndnew
Member#: 69615
2004 STI
Hi Ho Silver!
The Auto parts store will have the Helicoil this afternoon. I need to get another bolt since the threads on mine have all that pesky aluminum in them. I guess the proper size/pitch and grade will be OK? All the subie dealers here in town don't carry the bolt. Also, does brand of brake fluid matter? I am in a tight space as far as the rear wheels go, so I would rather not drain/replace all the fluid in it now. I just need to get through the next two weeks. I have a meet on Saturday and a Dyno appointment to be tuned on the 5th. I know every talks up some blue stuff, but I'm thinking it's best to stay with something standard instead of mixing - Correct? Thanks for all your help. Finally, do I need to put some kind of antisieze on them if I am using these Helicoils?
Old 09-24-2007, 03:14 PM   #14
MasterKwan
Member#: 98961
2003 WRX
Yeah, crappy design. On honda's you bolt through the caliper into the cast iron spindle so, you never strip them out. At the very least they should have had thread inserts from the factory. A wire brush or thin screwdriver will get all that aluminum off the bolt. I'd use the stock bolt.
Old 09-24-2007, 03:34 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Not on my RSX. It bolts up the same way as the Subaru setup.
Anti seize is your friend!!!! We also learned the hard way, but anti seize everything now.
Tony
Old 09-24-2007, 04:22 PM   #16
MasterKwan
Member#: 98961
2003 WRX
Well, I'm glad it does on my Civic then.
Old 10-30-2007, 08:37 PM   #17
Nate8409
Member#: 44034
2006 Global Cooler
When it comes to calipers always remember the anti seize unless you don't care.
Nate8409 is offline   Reply With Quote
Old 11-11-2007, 07:35 PM   #18
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
son of a beech! this happened to me today too
How much $$ is the helicoil kit?
z is offline   Reply With Quote
Old 01-31-2008, 08:58 PM   #19
ditch_bound
Member#: 125298
04 STi
I know this thread is a little old but the same thing happened to me the other day. What a *****ty design. Helicoil seems like a good solution.
ditch_bound is offline   Reply With Quote
Old 02-01-2008, 09:55 AM   #20
Turn in Concepts
Member#: 93646
Many Track Records
Make sure you put antiseize on the threads next time and this will not be a problem again.
Tony
Old 02-01-2008, 12:19 PM   #21
ditch_bound
Member#: 125298
04 STi
Tony
Yeah I will Im an antiseize fanatic, but the brakes were done by the previous owner.
Old 02-01-2008, 12:20 PM   #22
ditch_bound
Member#: 125298
04 STi
oops, double post.
Old 02-14-2008, 10:02 PM   #23
unclemat
Member#: 114530
2005 LGT 6MT wagon
Tony
I heard that anti-seize messes up the torquing.... i.e. you'll overtorque it over what you set the torque wrench to.
Perhaps not enough to cause a problem.
unclemat is offline   Reply With Quote
Old 02-15-2008, 08:46 AM   #24
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Yes, a lubricated fastener needs to be torqued less than a dry fastener to achieve the same fastener preload. A general rule of thumb is that Lubricated Torque x 1.3 = Dry Torque.
I just ordered the Brembo BBK with the STi calipers. I'm curious to see if the Brembo installation instructions call for anti-seize on these fasteners.
jac04 is offline   Reply With Quote
Old 03-01-2009, 12:12 AM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
sorry to bump 1 year old thread.
For those who used helicoil, how much did kit & parts cost you and what size drill bit did you need? I want to double check everything before get started on thread repair.
Chicago people, visiting June12 weekend, what to do!?! impreza_GC8 Mid West Subaru Owners Club Forum -- MWSOC 9 06-21-2010 03:30 PM
Thread pitch for rear brembo caliper mount bolt sti robot Brakes, Steering & Suspension 2 11-10-2008 06:32 PM
in the middle of downpipe install...o2 sensor threads messed up. what to do? . M i c h a e l Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-23-2006 08:15 AM
Oil galley threads stripped....what to do? CapeRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-08-2005 09:44 PM
Darn it! The bolts holding the hood are stripped! What to do? bigbird Interior & Exterior Modification 21 11-03-2002 06:49 PM
