Old 09-23-2007, 10:07 PM   #1
tedstriker
Member#: 156039
Default Normal driving then CEL and Limp Mode
Hi Guys,
I have a 2004 sti that is stock. I bought if from a guy who had a big turbo on it plus all the supporting mods. I drove it 1000 miles to take it home, and it ran fine, no problem.
I was driving today, normal, spirited driving, nothing crazy, when the car suddenly goes into limp mode, with the CEL and cruise light flashing as well.
I parked and went inside for a while. WHen I got back into drive the CEL was gone, but withing 30sec of driving, it came back on.
Any idea what this could be? the owner had 06 wrx fuel rails and injectors on it, instead of the stock sti. as well, I just had day time running lights installed. could either of these be the culprit? Any help would be appreciated, as I'm pretty stressed about my car having problems now. Thanks.
tedstriker is offline   Reply With Quote
Old 09-23-2007, 11:38 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
you need to get the code pulled and to see what is going on
RexyGirl is offline   Reply With Quote
Old 09-24-2007, 05:53 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just to clarify, the cars fuel rails, injectors, turbo, etc are all back to stock?
Old 09-24-2007, 09:14 PM   #4
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Em????
BBBsti LTD is offline   Reply With Quote
Old 09-25-2007, 10:09 PM   #5
Wheels
Member#: 5410
2008 BMW 335XI
Seems like you may have bought a lemon,
Wheels is offline   Reply With Quote
Old 09-28-2007, 01:40 PM   #6
bo9877
Member#: 31452
1995 Legacy L FWD
Power Windows & Locks!
No, not a lemon. In order to fall under lemon law, most states require that 1)the car be within the lemon law period usually 2 years or 24K miles, 2) that the vehicle was bought new 3) be due to a manufacturer's defect and not something that could have been caused by modifications. This 2004 STi in all likelihood is well out of the lemon law period, is a used car, and has had modifications on it that could have been the culprit (having the codes would help). It's also possible that the DRL install may have resulted in a short somewhere in the wiring, fouling things up.
Could the car have a gremlin in it? Sure. But a lemon? Nope.
bo9877 is offline   Reply With Quote
Old 09-28-2007, 01:59 PM   #7
Member#: 151119
If your CEL is flashing that means you are doing damage to the catalyst. This is ussually caused by a rich misfire. Pull the codes and see they are. Are you running cats? Does it have a stock ecu or custom EM.
nevets87@siu.edu is offline   Reply With Quote
Old 09-29-2007, 02:48 PM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Not only should he have the codes read, he should also fill out his profile. If it turned out that he lives nearby, I'd lug the laptop to his house to read those codes.
Help us help you.
LetItSnow is offline   Reply With Quote
Old 09-29-2007, 11:59 PM   #9
Tim-H
Member#: 65751
'10 VULVA
Believe it or not the CEL is used for more than just cat related problems.
Tim-H is offline   Reply With Quote
normal driving then CEL and Limp mode tedstriker Service & Maintenance 5 09-24-2007 10:39 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 12:29 PM
AVCS and limp mode mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-21-2004 07:14 PM
How to: Drive your car in Limp Mode DeusExMachina Normally Aspirated Powertrain 9 02-03-2003 07:52 PM
EGT's and Limp Mode at Track Event TBreu007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-16-2002 02:09 PM
